Old 05-04-2003, 04:46 PM   #4996
Hooked's Avatar
ttt
Hooked is offline   Reply With Quote
Old 05-04-2003, 05:12 PM   #4997
Send a message via AIM to ZER01
Originally posted by mab_man20
Yeah, the steering was designed with uneven throw to compensate for a slight torque steer experienced when the steering is maxed. Dont worry about it, it wont slow you donw.
I run on a blown off untreated asfault parking lot and am considering switching over to a front spool. Does anyone have an experience with this and how well it worked? If its already been discused can someone tell me about what page it is on?
thanks
I'm pretty sure i heard cliff say place the servo horn 1/8th-1/16ths of an inch to the right when looking at the servo from the front to help keep the servo from locking up on RETURN from full right. yeah.
No experience with a sppol here but i do know the car is harder than hell on it.
ZER01 is offline   Reply With Quote
Old 05-04-2003, 05:50 PM   #4998
what are the differences in the actual chassis, shocks and moving parts from the rtr vs the racer kit, if any?
rcracer123 is offline   Reply With Quote
Old 05-04-2003, 06:56 PM   #4999
Send a message via AIM to AssociatedRacer
I'm pretty sure(almost 100%) that the RTR is a Racer Kit with low end electronics.
AssociatedRacer is offline   Reply With Quote
Old 05-04-2003, 07:20 PM   #5000
Hooked's Avatar
I agree ... I think the RTR is exactly the same as the Racer kit with cheap electronics added ...
Old 05-04-2003, 07:53 PM   #5001
mab_man20's Avatar
Send a message via AIM to mab_man20
Thanks proudwinner. I figure since the traction isnt as high as most tracks and cuz im running stock, i wont need new cvd shafts and diff outdrives every race day. Maybe every other race day.
Anyone else have experience?
mab_man20 is offline   Reply With Quote
Old 05-04-2003, 08:05 PM   #5002
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
A front spool will give you the on-power steering of a oneway, but you'll still have four-wheel braking. The downside is you lose offpower steering. This means you are forced to stay on the gas in the corner, or use other setup changes to give you your offpower steering back (i.e. more rear droop, more front kickup etc.).
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-04-2003, 08:06 PM   #5003
No problem Mab_Man.
Old 05-04-2003, 08:34 PM   #5004
mab_man20's Avatar
Axiom5B: Thanks. I knew that, but it is helpful none-the-less.
Old 05-04-2003, 09:33 PM   #5005
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default mab-man
I like the spool on the same surface you described but the track was huge. 130ft straight. But on a small tight track, the loss of off power steering really made it tough.
Jon Kerr is offline   Reply With Quote
Old 05-05-2003, 04:50 PM   #5006
mab_man20's Avatar
jkerr0043: Thanks
We run on a track with a 100' straight and 12' lanes so im gonna give it a try.
Ill let you know how it works after i get it.
Old 05-05-2003, 05:10 PM   #5007
How easy is it to fix the diffs and actually get at the diff areas of the car, front and rear compared to a yokomo mr-4tc, because my yok is a pain you have to take like 50 screws out to get to them, I want something easy to fix, run and maintain.
Old 05-05-2003, 05:13 PM   #5008
all you have to do is take out the screws on the diff cases and undo the camber links and the lower shock mounts. It's pretty easy and quick.
USVTA Member #211
Old 05-06-2003, 02:08 PM   #5009
seamus0g's Avatar
Default TC3 One-way
Anyone know what happened to the ae one-way for the TC3? I can't find any info about it on the Ass site, and it doesn't show up searching on Horizon and Tower. Has it been discontinued? I found a part number searching on Google, 3938, but such a part number doesn't show up on the ae parts list or any of the online catalogs. What's the deal? Thx.
seamus0g is offline   Reply With Quote
Old 05-06-2003, 02:08 PM   #5010
not sure if you guys knows about this but there's someone selling a bumper holder on ebay...looks nice
wiley is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
