Like Tree4Likes
Old 04-25-2003, 04:20 PM   #4891
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Perhaps we're looking at it backwards -
if it gives the shock more travel, wouldn't it give a better overall shock action? smoother action? something along those lines?
just an idea
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 04-25-2003, 04:29 PM   #4892
Leaning the shocks in means the shocks compress less given the same amount of suspension travel. That allows the shocks to compress more quickly giving an effect of a softer suspension. I would think if your shocks were built correctly, smoothness of shock movement would be the same and that the shocks would actually be more consistent because they have to work less.
DOTMAN is offline   Reply With Quote
Old 04-25-2003, 05:46 PM   #4893
Cracker78's Avatar
Send a message via AIM to Cracker78
Originally posted by Axiom5B
...So i put the shocks up one whole (outer hole) and i go out there for my heat. Amazingly, I had all the steering I wanted
Dont get me wrong, I dont doubt that you gained steering. I am just after why that is. Its just that my brain says it shouldnt happen, but obviously it did, so i need to fix the way my brain thinks
As for the compressing more and rolling more, I think dotmans post clears that up a lil bit. If i get some ambition I might do a lil math and see what the numbers say about shock angles. (yea i am a dork like that)
Cracker78 is offline   Reply With Quote
Old 04-25-2003, 06:06 PM   #4894
I got this from the Warpspeed thread (thanks Mr. Warpspeed). You might find this very helpful and save you some time doing calculations
http://home.tiscali.be/be067749/58/
Old 04-25-2003, 06:21 PM   #4895
[QUOTE]Originally posted by DOTMAN
[B]I got this from the Warpspeed thread (thanks Mr. Warpspeed). You might find this very helpful and save you some time doing calculations
No problem Dotman. I already have private message to
Cracker 78 before you had posted this. Glad I could help.
Mr Warpspeed is offline   Reply With Quote
Old 04-25-2003, 08:25 PM   #4896
Mike D's Avatar
Send a message via Yahoo to Mike D
Default Cracker78
Originally posted by Cracker78
Ok, I absolutely agree with you, but just for the sake of argument lets say we have two setups, one with shocks "stood up" and one with shocks "layed down." Now if we put stiffer springs on the "layed down" setup such that the energy required to compress both setups would be the same. Would there be a difference in handling?
YES, there is a difference in the two shock setups you just listed. It gets complicated... but I'll give it by best shot. Stiffer springs have a higher spring rate (or spring constant). It is refered to as "k." "k" is a rated value that can be in terms of pounds per inch... or simply, how much weight is required to compress a spring some given length. The load on a spring is equal to the spring constant times the amount of compression, X. (Load = -k * X)
As Dotman stated before:
"Leaning the shocks in means the shocks compress less given the same amount of suspension travel."
If you match the correct 'stiffer' spring (higher k) with the 'layed down' shock (lower X) the result will be the same response to using a 'softer' spring (lower k) and 'stood up' shock (higher X). This proves that the handeling difference does not result from the spring change.
The difference in the two setups you listed is in shock dampening. By laying down the shock, it compresses less. With less shock movement, there is less resistence from the damping. Less damping will cause the car to react quicker and possibly be less stable.
Mike D is offline   Reply With Quote
Old 04-25-2003, 11:42 PM   #4897
THeGame's Avatar
Send a message via AIM to THeGame
uhm I dont get it!!!
THeGame is offline   Reply With Quote
Old 04-26-2003, 05:14 AM   #4898
GAME---- Just stand the shocks up, put the stiffest springs and oil you can find on it and wheel the MOFO!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-26-2003, 07:53 AM   #4899
Fatboy Joe's Avatar
I kept on melting my outdrives and been spending too much on replacement plastic outdrives. I need help on how to do the assembly and adjustments correctly. I've been hearing alot of ways but I guess it is best to hear it from your guys in the TC3 thread. Thanks in advance
Fatboy Joe is offline   Reply With Quote
Old 04-26-2003, 07:55 AM   #4900
lem2's Avatar
Default Spur Gear
Just a question to the TC3 guru's out there.
What will be the difference in performance if I use a bigger spur gear (75) than 72t?
example:
75 spur / 26 pinion= 7.21
72 spur / 25 pinion = 7.20
I both end up with the same ratio but will there be a difference in performance since the spur is bigger? (acceleration??)
I run on stock, and the tracks is big, flowing with some tight turns?
Thanks for the inputs!!!
Lem
lem2 is offline   Reply With Quote
Old 04-26-2003, 08:19 AM   #4901
THeGame's Avatar
I'll try that this weekend with the reflex then...
Old 04-26-2003, 09:14 AM   #4902
Registered User
fatboy joe,
bring your tc3 on saturday at the tracks. let me have a look at it.
beowulf is offline   Reply With Quote
Old 04-26-2003, 10:11 AM   #4903
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Default Re: Spur Gear
example:
Lem
For stock you want a bigger spur. Bigger spur translates into more torque. A smaller spur would make the drivetrain spool up faster though. I ran my tc3 w/ a 100 tooth (64 pitch, equivalent to 75 tooth) and liked it. Your best bet is to just try both and use the one you like better.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-26-2003, 11:28 AM   #4904
RichChang's Avatar
If the spur/pinion ratio is the same, a bigger spur is no different from a smaller spur. What changes is the weight location of the motor. The weight change is more noticible on a 1/12th scale since you are moving the motor's location fore or aft in the motor pod and 1/12th scales are a lot lighter.
To use full-size cars as an example, for tranny gearing they talk about the ratio - they don't talk about the individual gear sizes because all they really care about is the ratio.
-Rich
RichChang is offline   Reply With Quote
Old 04-26-2003, 03:07 PM   #4905
highwayman's Avatar
Default Re: Cracker78
my $.02 worth on the shock angle...
with the shock standing up, there is more constant force on the wheels, therefore it will have more bite, this would account for the fact that you'd feel more steering...
with the shock layed down, the shock feels softer, as discussed earlier; however, it will get progressively harder as it moves up... in my opinion, with the same spring rate, this adds to the initial roll of the car, therby adding steering...
i think shock angle, is at most a tuning device to suit different driving style's... a step up or step down, would just add to the style one drives his car or to suit the track conditions...
highwayman is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
