Old 04-25-2003, 08:24 AM   #4876
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally posted by HeavyD
What's a spool? And also what is all the hype with running the rear shock tower on the front? It gives more steering by allowing more of an upright placement of the front shocks? thanks
A spool is a locked front diff, or one that's just solid to begin with (i.e IRS spool). It gives you the onpower steering of a oneway, however less offpower than a diff. But you get the onpower steering and still have 4 wheel brakes unlike the oneway. The rear shock tower moved to the front makes the angle of the shocks even front and rear. And yes, standing up the shocks gives more steering because it allows that end of the car to roll more. Hope this helps
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-25-2003, 09:36 AM   #4877
driftmaster's Avatar
I have CNC made TC3 Alum spools for $20. Also have them
for the Cuda. PM me if you would like to get one.
driftmaster is offline   Reply With Quote
Old 04-25-2003, 11:14 AM   #4878
Cracker78's Avatar
Send a message via AIM to Cracker78
Originally posted by Axiom5B
...standing up the shocks gives more steering because it allows that end of the car to roll more.
Ok I have always been confused by the effects of standing shocks up and laying shocks down. Here is how I think of it:
Lets start with a shock in a "standard" position somewhere between "stood up" and "layed down." At this point, the suspension arm arcs up a distance we will call "D" and the shock is then compressed by an amount lets call "X." If we now put the shock into a "layed down" position and move the suspension arm up the same distance "D", I believe that the shock will be compressed less than "X"... thus leading to a softer front end and more roll. If we put the shock into a "stood up" position and move the suspension arm up the same distance "D", I believe that the shock will be compressed more than "X"... thus leading to a stiffer front end and less roll.
Now this is just how I think about it... I don't know if I am right or wrong or just smoking crack. Comments anyone? I am just in search of the truth :-)
Cracker78 is offline   Reply With Quote
Old 04-25-2003, 11:23 AM   #4879
Cracker - the way I understand it...it's a simple leverage thing. Standing the shocks up requires more energy to compress resulting in a stiffer feel, less bite. Shocks leaned in compress easier giving a softer feel, more bite.
DOTMAN is offline   Reply With Quote
Old 04-25-2003, 11:33 AM   #4880
Mike D's Avatar
Send a message via Yahoo to Mike D
Cracker78 - Dotman is correct. You are not smoking crack but Axion5B may be. The outside hole on the tower will decrease steering and make the steering less aggressive.
Mike D is offline   Reply With Quote
Old 04-25-2003, 11:49 AM   #4881
D_Ames's Avatar
Send a message via AIM to D_Ames
Originally posted by Genetic
Hey do you guys know how much those nice Stainless Steel Spools go for? Thanks
If your refering to the prototype that Barry Baker is running, they are not stainless steel. They are made out of hardened tool steel.
They are about the same weight as a oneway and will never wear out.
I am not ready to sell these yet but if any local So Cal people would like one you can e-mail me here
D_Ames is offline   Reply With Quote
Old 04-25-2003, 12:09 PM   #4882
Default Control tyer for reedy race
Hi guys
Just wonderd if any of you guys in the states are racing at the reedy race over there and can give me a web address of a model shop where i can buy the control tyer from as it is the same one used over here in England two weeks later for the reedy race.Would be very gratefull of any help so i can start testing with them on my TC3.
simo is offline   Reply With Quote
Old 04-25-2003, 12:12 PM   #4883
You should be able to order them at www.speedtechrc.com
Old 04-25-2003, 12:16 PM   #4884
Fred Hubbard's Avatar
Will you be at the track this Sat??? I need to come see you.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 04-25-2003, 12:24 PM   #4885
Cracker78's Avatar
Ok, I absolutely agree with you, but just for the sake of argument lets say we have two setups, one with shocks "stood up" and one with shocks "layed down." Now if we put stiffer springs on the "layed down" setup such that the energy required to compress both setups would be the same. Would there be a difference in handling?
Old 04-25-2003, 12:32 PM   #4886
Default Reedy race
Cheers Dotman
Old 04-25-2003, 12:40 PM   #4887
Trader Rating: 47 (100%+)
Thanks every one for your info on milling the chassi, I have a freind who works in a mill shop I think I can get him to help me out, and if I don't like it I guess I'll just buy a new chassi.
porter is offline   Reply With Quote
Old 04-25-2003, 02:16 PM   #4888
Cracker78 - In the turns, logically, I would say no if the effective stiffness was the same. But the spring stiffness effects how your car handles in different areas (acceration, entering and exiting turns, etc). Your two scenarios may have the same effect entering a turn, but have a different result exiting. Not being a pro driver or an engineer, it would be hard for me to say what the difference would be. Shock angle is just a way to fine tune your setup. If your car had a bad push, I don't think leaning the shocks will fix it. I would probably change springs/oil and/or droop. I use shock angle changes when my setup is good and I'm trying to make it great.
Old 04-25-2003, 04:06 PM   #4889
Mike D, no i'm not smoking crack. All i know is, racing mod a couple months ago i was searching for a little bit more steering. So i go ask Kevin K what he thinks i could do to get just a tad more steering. He says stand the shocks up, it lets the car roll more, which gives more steering. So i put the shocks up one whole (outer hole) and i go out there for my heat. Amazingly, I had all the steering I wanted . Now this was on a XXX-S, but shouldn't the principles stay the same car to car?
Cracker78, you said if you stand the shocks up, the suspension would be compressed more...would that not lead to more roll?
USVTA Member #211
Old 04-25-2003, 04:13 PM   #4890
Standing the shocks up compresses the shocks more than when the shocks are leaned in given the same amount of suspension arm travel.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
