Old 04-18-2003, 05:09 PM   #4816
NTC3NUT's Avatar
Originally posted by highwayman
NTC3NUT
what was the modifications you had done to your steering and/or shock tower?
also, have you ever experienced in your NTC3, the front and rear shock towers keep on loosening from the bulk head (diff case)... if so, what do you do to remedy this...
thnx...
I installed a NTC3 steering rack in my electric TC3. As for the shock towers, other than putting a rear tower up front, I extended the rear tower allowing the upper shock mounting position to be further out (standing the rear shocks up straighter).
And the NTC3 shock tower coming loose, common problem. The least you should do is install longer 4/40 screws in the center hole, and the hole on the ring gear side. And use thread locker or CA. If you want to go heavy duty buy "The Fix" and a set of aluminum diff cases.
NTC3NUT is offline   Reply With Quote
Old 04-18-2003, 08:16 PM   #4817
Default Prices on tc3
what is a good asking price for a factory team tc3 roller mint with no tires and 1 body custom painted?lmk asap -gg
1FaStClubRaCeR is offline   Reply With Quote
Old 04-18-2003, 08:43 PM   #4818
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
How mint, i may be interested.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-18-2003, 09:52 PM   #4819
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
me 2!! email me some pics or post some on here ( r_dub2002@msn.com )
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 04-18-2003, 11:55 PM   #4820
highwayman's Avatar
NTC3NUT:
i didn't know that there were aluminum diff cases for the NTC3, can you tell me where i can buy them?
i used longer screws on 2 of the 3 holes of the shock tower, but i didn't put c/a in them, will try it out next time around...
What's " the fix "
thnx...
highwayman is offline   Reply With Quote
Old 04-19-2003, 01:29 AM   #4821
driftmaster's Avatar
What's " the fix "
ebay search term, it should bring up the diff cases.
driftmaster is offline   Reply With Quote
Old 04-19-2003, 02:16 AM   #4822
jta
I installed the green springs in the front to allow more weight transfer to the front hoping that it would eliminate the push. I don't have any problem at turn in, my problem is when I start to apply throttle, the car pushes to the outside of the turn instead of taking the turn.
jta is offline   Reply With Quote
Old 04-19-2003, 02:19 AM   #4823
jta
Hey guys, thanks a lot for all your tips and suggestions, I really appreciate it a lot.
Old 04-19-2003, 04:51 AM   #4824
NTC3NUT's Avatar
NTC3NUT:
What's " the fix "
thnx...
"The Fix" is a set of 4 long 4/40 screws, and 4 machined aluminum screws (or tubes), that come together from the top & bottom of the car thru the 2 open holes in the shock towers. It increases your shock tower mounting screws to 5 vs. 3. Search "The Fix" under "gas powered cars" on Ebay and you'll find it, $25 for the set shipped.
Old 04-19-2003, 06:10 AM   #4825
theisgroup's Avatar
if you problem in mid turn and exit, then you should soften the back and possibly stiffen the front
also, increase front droop
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-19-2003, 08:01 AM   #4826
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default tranny cases
try rdlogics web site they have alloy diff cases for 20 a piece ....silver or blue ...
www.rdlogics.com
dynoman007 is offline   Reply With Quote
Old 04-19-2003, 10:14 AM   #4827
highwayman's Avatar
thanks.. will definitely check them out...
Old 04-19-2003, 02:24 PM   #4828
TC3
TC3's Avatar
TC4
are ther any news about a tc4 coming out?
or maybe an upgradekit will be released?
thx
TC3 is offline   Reply With Quote
Old 04-19-2003, 02:30 PM   #4829
Why would they upgrade it? It's still winning and is probably the most competitive TC out there right now.
USVTA Member #211
Old 04-19-2003, 02:36 PM   #4830
Maybe they are learning from past mistakes..... Associated is well known for setting on their heals and waiting too long to release new cars, normally by the time they do the old one is so outdated they almost have to rewrite the book!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
