Old 04-18-2003, 08:56 AM   #4801
Mike D's Avatar
Send a message via Yahoo to Mike D
jta - What is your current setup? Are you racing on asphalt or carpet? Are you using foam or rubber tires?
Mike D is offline   Reply With Quote
Old 04-18-2003, 09:11 AM   #4802
jta
Mike D- We're racing on a cement racetrack. I use sorex 36R tires all around with med. inserts. I used green springs in front and silver at the back, ball diffs front and rear. I also use F+2 mounts in front and R+2+2 at the rear.
jta is offline   Reply With Quote
Old 04-18-2003, 09:25 AM   #4803
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It sounds like you're transferring too much weight to the rear on accelleration - this is taking all the weight off the front tires so they aren't giving you any traction.
Try stepping your rear springs up a notch (use one color harder) and see if that improves it. This would reduce the amount of weight transferred to the rear.
You could also try stepping up the oil in the rear shocks a touch. This won't reduce the AMOUNT of weight transfer, but would SLOW it down.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 04-18-2003, 09:40 AM   #4804
Mike D's Avatar
jta - For more steering exiting the corners try a front 'spool' diff, tighten your front ball diff, use less caster, or use R+2+0 rear block. Those changes are listed in the order of most steering to least steering increase on turn exit.
BTW - Your springs sound very soft... have you tried stiffer front and rear?
Old 04-18-2003, 09:58 AM   #4805
theisgroup's Avatar
I would agree with boomer. But from your setup, it seams that the front end is a little soft. Green is the lightest spring you can get and that seams way too soft for the front. I would try the stock setup and work from there. It may be as simple as too much droop in the front. If you have too much droop, this would allow the front end to lift too much under acceleration and would transfer too much weight to the back.
Also, are you seeing a push when you enter a corner or on exit or while in the corner?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-18-2003, 10:55 AM   #4806
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default 200mm conversion
what would the 200mm conversion for the tc3 do? what does it make better (other than fitting the better bodies i want)?
-Ryan-
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 04-18-2003, 10:57 AM   #4807
rc-zombies's Avatar
Default Re: 200mm conversion
-Ryan-
A little bit more stable at high speeds. but not legal for sactioned races... you also have to chech with your track if they will let you race 200 EP cars.
Old 04-18-2003, 11:01 AM   #4808
rdub202's Avatar
i also read on competitionX that a larger wheelbase gives u better steering. ill have to email my track and see what they say. thx Ramon.
-Ryan-
Old 04-18-2003, 11:05 AM   #4809
You can try reducing the droop on your front end and/or add rear antisquat (if you're not already running the two degree block). Stiffer rear springs and less front caster may help too.
DOTMAN is offline   Reply With Quote
Old 04-18-2003, 11:27 AM   #4810
You probably started with gold in the front and silver springs in the rear didn't you?? and the car had a slight on-power push, so you went down on the springs until you ended up at greens....right????
Rule of thumb..... Matched springs front to rear at worst, never-never-ever use softer springs in the front, you may get it to work, but it drastically increases the complexity of your set-up..... Do you have the origional chassis or the updated one using fdroop screws?? Definately limit your droop setting on the front, 90% of the time that a slight handling problem is amplified it is an improper droop setting....
Like stated before start with the stock set-up and work from there, but this time start by limiting droop.
Less front droop = more on-power steering
Less rear droop = more off-power rear traction
Limit it 1/2mm at a time until the characteristic you are trying to achieve starts to reverse, then go back 1/2mm, and stay there.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-18-2003, 01:29 PM   #4811
highwayman's Avatar
jta
1. front one ways would help
2. try to alter the shock position, try putting the front and rear shock positions inward, in order for the front to have more side bite, exiting the corner...
3. install losi steering knuckles, and add a little toe-in in the front
4. try all blue springs, or blue front, green rears...
5. remove the sway bars...
highwayman is offline   Reply With Quote
Old 04-18-2003, 01:39 PM   #4812
highwayman's Avatar
NTC3NUT
what was the modifications you had done to your steering and/or shock tower?
also, have you ever experienced in your NTC3, the front and rear shock towers keep on loosening from the bulk head (diff case)... if so, what do you do to remedy this...
thnx...
Old 04-18-2003, 03:18 PM   #4813
When you add toe-in, it decreases steering a lot and makes the car easier to drive. I would suggest trying .5-1 degree of toe-out. Look in the back of your instruction manual and read all of the tuning tips. It talks about a bunch of adjustments that will increase on power steering.
racerdx6 is offline   Reply With Quote
Old 04-18-2003, 03:31 PM   #4814
Actually toe-out increases steering going into the turn, but looses steering everwhere else including on-power....
Toe-in decreases initial steering response, but gives more oer-all steering, and has a smoother feel thruought the entire cycle......
Old 04-18-2003, 03:45 PM   #4815
I stand corrected!
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
