Old 04-16-2003, 03:09 PM   #4786
glide 1- if you want to use washers to compensate for bump steer put them under each ball stud on the steering arm on the knuckle for both sides. before you add the washers measure your toe at ride height, then compress the suspension half way or so and measure the toe at that point. i use a good dial caliper to do this. then repeat this after adding bumpsteer washers. try to find the right amount to give you the most consistent toe amount throughout the suspension travel. this is the way i do it. hope that helps.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 04-16-2003, 03:55 PM   #4787
glide 1's Avatar
spaz456, thanks a lot. i'll give it a try.
glide 1 is offline   Reply With Quote
Old 04-17-2003, 08:42 AM   #4788
Send a message via ICQ to Ih8 RiCeRoCkEtS Send a message via AIM to Ih8 RiCeRoCkEtS Send a message via Yahoo to Ih8 RiCeRoCkEtS
hey guys
i am about to pick up my FT tc3, from a local guy. It has Everything from factory, then he added niftech bearings, blue aluminum driveshaft. Plus a perfectly painted Volvo body.
Woohooo!BTW its only $100, and it is in perfect condition!!!!!!!!!!!!!!!!!!
anyways, since it has niftech bearings, should i remove the seals on my bearings? so it can free roll for a long time? or does free rolling not afffect much on the track?
the only thing i can think of putting on it is the Wide bumper, i think its made by BRP, right?
this thing kicks major *** !
its soo beautiful!!!lol
nate
Ih8 RiCeRoCkEtS is offline   Reply With Quote
Old 04-17-2003, 09:07 AM   #4789
Go for the RPM bumper!! it looks way cooler and doesn't bend/break!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-17-2003, 11:04 AM   #4790
rcdougie's Avatar
Definately go with the rpm bumper and add the trinity foam bumper on top. With this combo I havent broke yet (knock on wood!)
rcdougie is offline   Reply With Quote
Old 04-17-2003, 11:44 AM   #4791
that sounds great then
thanks
nate
Old 04-17-2003, 12:11 PM   #4792
Sigearhead's Avatar
Trader Rating: 68 (100%+)
ricerockets: don't mess with the bearing seals, niftech bearings are real smooth and don't need the seals removed. Besides those things are expensive enough as it is, don't ruin them.
You can clean them out with motor spray periodically and relube them with Trinity Royal Oil and they'll be fine.
The key to a free drivetrain is in the diff cases and the shims on the drivecup/input shaft assembly not so much the bearings.
Sigearhead is offline   Reply With Quote
Old 04-17-2003, 01:00 PM   #4793
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default 200mm conversion
what would the 200mm conversion for the tc3 do? what does it make better (other than fitting the better bodies i want)?
-Ryan-
rdub202 is offline   Reply With Quote
Old 04-17-2003, 03:33 PM   #4794
hey
Sigarhead could you elaborate on what you said about the diff cases and shims? i really want a smooth drivetrain.
AND is there any other companies that make carbon fiber chassis's other than IRS and Megatech?
thanks
nate
Old 04-17-2003, 04:18 PM   #4795
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default Carbon fiber
Warpspeed makes one. Looks nice. I'm just not too willing to drop $200 on the slight advantage you may get (depending on who you talk to) with a CF chassis. I do think they look bad ass.
Jon Kerr is offline   Reply With Quote
Old 04-17-2003, 06:28 PM   #4796
does anyboady know where i can get a factory team tc3 cheap. or used in good conditioned thanks peace
jiggamacdaddy is offline   Reply With Quote
Old 04-17-2003, 06:56 PM   #4797
There's a ton of TC3's on ebay
DOTMAN is offline   Reply With Quote
Old 04-17-2003, 07:09 PM   #4798
what wording do you use for your search engine
Old 04-18-2003, 04:57 AM   #4799
IMM maybe........................
TC3
Old 04-18-2003, 07:54 AM   #4800
jta
Default HELP!
Hi guys, i need help with my tc3. How do I get more on- power steering? Off-power, my tc3 has lots of steering but on-power it pushes a lot. As a result, I am very slow in the corners because I have to fully release the throttle in order for my car to be able to make the turn.
jta is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
