Old 04-15-2003, 10:11 AM   #4771
Ouch! I think I'll get the Associated graphite chassis and modify it. What would you guys reccomend for a pinion size with the Monster Horsepower stock motor in the tc3 with a 72t 48 pitch spur gear?
racerdx6 is offline   Reply With Quote
Old 04-15-2003, 11:30 AM   #4772
big al's Avatar
Racerdx6: try a 25 tooth pinion. This will give you a 7.2 final ratio and should put you in the ballpark--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 04-15-2003, 03:33 PM   #4773
driftmaster's Avatar
If the stright is any where around a 100' 28t pinion is what I like.
driftmaster is offline   Reply With Quote
Old 04-15-2003, 03:49 PM   #4774
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default NTC3NUT
on page 124 u posted a pic of a rear shock tower mod u got from guys at ur track. i was wondering how that worked out? i never found the answer on the following pages. what did it make better/worse? if it was good lemme knw how its done.
-ryan
rdub202 is offline   Reply With Quote
Old 04-15-2003, 05:15 PM   #4775
NTC3NUT's Avatar
I never really had any luck with all the shock tower mods, or the spool. I always went back to the diffs and original shock towers, with the top of the shocks all the way out, and the bottom of the shocks in their original positions. The car worked great with that set-up. The only mods I was very happy with where the NTC3 steering, and the battery relocating. I think they both worked very well. It's really all subjective though, as I only ran indoor on carpet with foams, almost always in the stock motor class.
NTC3NUT is offline   Reply With Quote
Old 04-15-2003, 05:24 PM   #4776
NTC3NUT - the steering mod...do you think it improved your handling or do you like it because you don't have to worry about it binding?
DOTMAN is offline   Reply With Quote
Old 04-15-2003, 10:45 PM   #4777
Send a message via AIM to AssociatedRacer
Thats over gearing, I would go with big al at 25, thats a pretty good one.
AssociatedRacer is offline   Reply With Quote
Old 04-15-2003, 11:07 PM   #4778
I used a 23t today with pretty good results. The track is not the biggest one and it seems to work well.
Old 04-16-2003, 04:52 AM   #4779
NTC3NUT's Avatar
Both really, I had several other racers try it after the mod, even a factory driver, and they all thought it handled better (the factory driver had it done to his TC3 the next time I saw him). I think the biggest improvement was straight line centering, no slop at all. As far as maintenance goes, it is 100% better, there really is no maintenance.
Old 04-16-2003, 06:43 AM   #4780
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
For those of you talking about gearing don't forget to take into account of the different rpm's the motors have. That could the reason for the different selections.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-16-2003, 09:16 AM   #4781
NTC3NUT - does the steering mod increase the steering travel from the stock rack?
Old 04-16-2003, 12:21 PM   #4782
NTC3NUT's Avatar
I'll check it tonight vs. a stock set-up. I don't know if the rack in itself increases throw, but I know installing the Losi front C-hubs & steering knuckles does. Alot. The wheels will turn in far enough to hit on the bottom shock screws, they almost look like they're capable of going completely straight across, know what I mean. I had to dial out a huge amount of travel after I installed these parts.
Old 04-16-2003, 01:20 PM   #4783
Cool, I'll have to try it. Thanks
Old 04-16-2003, 01:30 PM   #4784
I agree, after changing to LOSI knuckles (not c-hubs) I had to trim down my dualrate to 80%. I think partly because the arms on the losi hubs are shorter than the Associated ones. One thing i've noticed after changing to Losi knuckles is the presence of bump steer. I have yet to try putting on spacers.
DRIVEN is offline   Reply With Quote
Old 04-16-2003, 02:58 PM   #4785
glide 1's Avatar
Default bump steer with losi knuckles...
Did not notice that the losi knuckles were shorter when i changed to them. Where would you want to put the spacers? Please let us know how you did it. thanks
glide 1 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
