Old 04-13-2003, 07:13 PM   #4756
OK, but it's my fault Associated doesn't know how to rate their parts properly??... it should be R+4-2 and R+6-2...ect... agian it was my understanding that the R+2 meant 2 deg. total.... not until I actually just put my car on my set-up station and actually checked the rear toe did I know..... Sorry.... GEE... now I DO know it all...LOL
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-13-2003, 07:25 PM   #4757
Coolrcdad--- OLD, probably one of the first releases... have him check to see if it has equal rear-toe per side becase the origional releases had rear hub problems.....
Old 04-13-2003, 07:51 PM   #4758
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Impactplayer- I've owned a ton of cars and every single one I've had has always had the toe as 'per side'... So it's not just associated. I am a mechanical engineering student. Maybe I'll get a masters in race car dynamics so I can know a car sucks, haha
Muffin- OB42tc3 is a mechanical engineer that designs suspensions all day. So I guess he is the expert.
pimpedaccord is offline   Reply With Quote
Old 04-13-2003, 10:39 PM   #4759
Wouldn't you have to make sure the car was "perfectly" upright when checking the rear toe with the RPM camber gauge? Because if you started to put the car at an angle wouldn't the amount of toe change?
racerdx6 is offline   Reply With Quote
Old 04-14-2003, 02:28 AM   #4760
Sigearhead's Avatar
Trader Rating: 68 (100%+)
when you check the toe, we're not using camber gauges you're using the Hudy or the"hudy type" setup system to check the toe in which the car is suspended in blocks like in the picture I posted.
You can roughly check your toe with an RPM camber gauge and yes you would want to make sure that the car is perfectly upright or the toe readings will be inacurate.
ImpactPlayer: there was no one closer in the discussion there was either right or wrong. RBLove was right and was proven if you looked at the pictures. All of the cars that I have ever owned measured toe per side and all the markings are per side not overall toe divided in half.
Sigearhead is offline   Reply With Quote
Old 04-14-2003, 09:57 AM   #4761
RBLove's Avatar
Trader Rating: 71 (100%+)
IMPACTPLAYR,
You are right. The slightly raised roll center "could" be a good thing. It also "might" not. I personally think the Warpseed kit looks great and if the new Yok is no good I will be trying the Warpspeed.
RBLove is offline   Reply With Quote
Old 04-14-2003, 10:14 AM   #4762
Well I based my conclusion on my previous cars---
Associated off-road cars (1 block per side labeled 3= 3 deg. per side)
HPI RS4 pro-pro2 (each side marked 2 on pin carriers 2 deg. per side)
schumacher---- ohh yeah...LOL infinate toe....LOL
even my old TC3 had infinate adjustable toe...... maybe that it wasn't as "point and shoot" because The most I have ever use is 2-4 deg. total toe on any on-road car, even my old TC3..... HMMMMMM
Old 04-14-2003, 10:19 AM   #4763
High, Guys. I have the Warpspeed chassis conversion on one car and a stock chassis with the slots cut closer to the centerline on another. I just got a good test of the Warpspeed chassis yesterday and I have to say that it does feel a little more stable than stock. Acceleration felt about the same. It didn't corner quite as well with the diff as the stock with a one-way. I was very competitve though with the other cars on the track. I can't say yet that it's better or worse than my other car. I still get around the track better with it, but I've been driving it for two years. This weekend I'm going to set the two cars the same and compare. Keep you posted
DOTMAN is offline   Reply With Quote
Old 04-14-2003, 01:21 PM   #4764
DaveW's Avatar
Default Warpspeed
Anyone can cut flat graphite/fiberglass, and use a standard chassis as a template for the battery locations. I have as yet, seen a definitive answer for the "improved" handling of this "car". Seems to me, one does things to improve a car with a goal in mind... a reason to do "this and that". And "this and that" is based on knowledge of how the overall suspension works, not to mention, particular use. Face it. You could realistically build a car for carpet... and asphalt... and the two use similar drivetrain components... but must utilize different theory to build each setup. The answers given for the "improved handling" are sparse and general. Heck... you might have just got the right tire/insert combination for the day! I guess im asking... what was your reasoning for doing the chassis the way it is? If the cars were mostly tested on medium bite asphalt tracks... then the "raised" chassis WOULD increase "stability" and "traction". Anyone knows, you raise overall ride-height, the chassis has a slower response to directional input... not to mention the change to roll center and roll moment. Its simple geometry... not rocket science. But one cannot simply swap battery location from one side to the other.. and add a "fancy" brace and claim it as a new "car". I dont know... maybe i am too much of a tweak to think it can be that simple....
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 04-14-2003, 01:38 PM   #4765
They also moved the battery position further inwards towards the shaft.... which has been well documanted thru tons of cutting on the tub chassis to make a huge difference.........
Old 04-14-2003, 09:47 PM   #4766
Registered User
OB42TC3's Avatar
Default Re: Re: Re: Warpspeed chassis thickness
For what it's worth I think the ultimate proof of the warpspeed RC increase is the track. The benefits of the warpspeed setup may outweigh the RC/ride height deal. For asphalt rubber tire this wouldn't be such a big issue as carpet I think because on foam/carpet you have so much more grip. I mean just look at all the rear toe conversation. That's important because the tires aren't slipping on the carpet so removing toe really frees the car up. The ackerman angle seems to have a big effect too; same reason-low tire slip. What else comes with this? traction rolling and dragging the chassis edges and ride height becomes very important; most carpet tracks will check minimum ride height too. So you can see how the .4 mm impacts the setup pretty directly, and small changes are more noticeable because of the grip levels....and those old RS4 roll center plates were designed for rubber tires on asphalt.
OB42TC3 is offline   Reply With Quote
Old 04-14-2003, 10:59 PM   #4767
RBLove's Avatar
OB4TC3,
Well said! We are all foam tire carpet guys (Sigearhead and Pimpedaccord)
Old 04-14-2003, 10:59 PM   #4768
RBLove's Avatar
OB4TC3,
Old 04-14-2003, 11:24 PM   #4769
Can you make the battaries in the Warpspeed chassis sit at the same level as the Associated chassis by filing (spelling? ) the chassis if they don't already sit at that level? That would help keep the CG lower probably. I would get the Warpspeed chassis but it probably costs a lot more than the graphite Associated chassis. How much does the Warpspeed chassis cost?
Old 04-14-2003, 11:49 PM   #4770
RBLove's Avatar
Warspeed conversion kit is $190.00 street price.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
