Old 04-13-2003, 01:55 PM   #4741
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Dynoman, just take the rear bumper off, stand the car straight up (with the nose pointing towards the ceiling) and use your rpm camber gauge to measure it.
I've got a setup station and RBlove is right... Using 1* blocks takes 1* out per side.
You can also use the 'F' block in place of the R block to take out roughly 2* toe (per side).
pimpedaccord is offline   Reply With Quote
Old 04-13-2003, 02:13 PM   #4742
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Okay, for all of those who don't know what they are talking about here is the answer and pictures to prove it!
This first pictures shows the standard tc3 blocks with 3+2 block in the rear in this case when you look the notch is at 3 degrees.
Sigearhead is offline   Reply With Quote
Old 04-13-2003, 02:15 PM   #4743
Sigearhead's Avatar
Now I placed a 1 degree R Losi hub on the left which will take 1 degree off that side, remember the right side reads 3 degrees so now this side reads what, oh, no, oh my god! 2 !!!!
Old 04-13-2003, 02:18 PM   #4744
I think favian cheated!!! haha
Old 04-13-2003, 02:19 PM   #4745
Sigearhead's Avatar
Now the last picture will show you that I placed a R1 degree losi block on the left side to take away 1 degree of toe to that side so that there are no doubters. So, depending on the desired amount of toe you can play around with the different blocks and hubs, there are several ways to achieve the same amount of overall toe this way.
Old 04-13-2003, 02:29 PM   #4746
RBLove's Avatar
Trader Rating: 72 (100%+)
What up fellas? Thanks Fave! Some people know everything on these boards....... Oh well. Try to lend a hand or give some advice and there is always someone that does it better.......
PIMPEDACCORD, I'm mad at you No show! We ran, but it was rather boring. I only got a 31 5:08, but was on a 31 flat in the main until the last two laps. Carpet is terrible. I was told you ran a 31 5:04 or something........... Nice.
L8R boyz,
RB
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 04-13-2003, 02:35 PM   #4747
I ran a mid 32, but I'm not sure if it was the same layout? I remember my laps were like 7.5's.
Old 04-13-2003, 02:37 PM   #4748
RBLove's Avatar
7.5's???? Had to be different. Fastest lap today was 9.6. I thought Gilligan had said that you ran a 31 5:4 on the current layout. Oh well. We gotta hook up soon!
Old 04-13-2003, 02:43 PM   #4749
Sigearhead's Avatar
Wow, Jeff you got 32 laps with 7.5 second laps, you da man brother and you only did it in 4 Minutes time!
Running 7.5 second laps would put you closer to 40 laps in 5 minutes time!
Old 04-13-2003, 05:55 PM   #4750
oops, that's supposed to be 9.5's, haha
I think I had a couple high 9.4's too
Old 04-13-2003, 06:08 PM   #4751
Default Re: rear toe in
OK I was mistaken on how much toe was changed per block...however if you read very carefully I was much closer than RBLOVE.....
Originally posted by dynoman007
hiyas fellas if a guy had the r+2 -0 block in rear with losi 1degree reah hubs on opposite sides what would the rear toe be seems like it is .5 each side but no sure way to measure it ???? anyone know for sure ???
RBLOVE replied:
You will have 1 degree per side...
NOW the
R+2-0 block gives you 1 degree per side this is how it achieves 2 deg. of total rear toe. IF you take 1 deg. and subtract 1 deg. you will not get 1 deg. I may not know everything.... buy I do know how to read.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-13-2003, 06:11 PM   #4752
Default Re: Re: Warpspeed chassis thickness
Originally posted by OB42TC3
Do you understand how these work? The angle of the lower arm(which changes due to ride height) also determines roll center; not just the top arm angle. So to maintain the same Roll Center the ride height has to decrease which makes the chassis drag the carpet more or DQs you OR to maintain ride height the RC goes up and the CG too.
Your the expert.
Art Jensen is offline   Reply With Quote
Old 04-13-2003, 06:31 PM   #4753
Om the Warpspeed chassis, who is to say that the slight (very slight) increase in roll center is a bad thing?? maybe it helps inhance the other changes the new chassis makes over the standard tub? If you remember the roll center kit that was sold fr the HPI RS4 raised the geaboxes and motor 3mm , but left the batteries setting at the same height..... and worked extremely well..... now your only talking about raising the gearboxes and motor 0.4mm, and the batteries will still set as low in the chassis!
I am with MR. Warpspeed, until you try it don't try and determine how it effects the car unless you are a mechanical engineer specializing in race car dynamics.....
Old 04-13-2003, 06:39 PM   #4754
Dingus's Avatar
Impact,
You're still off. Maybe you can read, but comprehend...
R+2 block give 2 deg PER SIDE, with the Losi hubs backwards, minus 1 deg per side, gives you 1 deg per side.
2 - 1 = 1
Dingus is offline   Reply With Quote
Old 04-13-2003, 07:09 PM   #4755
Default how old is this kit?
A friend just bought a Team kit from an LHS and I was surprised to see it had the (original?) arms and composite chassis that do not have droop holes and droop screws and no place on the chassis for the droop screws to rest. Is this an original spec kit?
One nice thing, the gear boxes were some of the best molds I've seen.
coolrcdad is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
