Old 04-12-2003, 04:35 PM   #4726
pimpedaccord:
how can you be so opinionated? have you driven the car?
the warpspeed demon outhandles the Associated car. I have the demon and it is kicking ...... out here in europe. and the way that i read on the post, it is kicking......out there in the states too. the way i see it is that you seem to be alittle jealous. and another thing, this car is not slapped together, it is well engineered.
DO YOUR HOMEWORK.
HARLEY is offline   Reply With Quote
Old 04-12-2003, 05:41 PM   #4727
Default Warpspeed Chassis
Here is my point, Pimpedaccord; I have run both cars for a long time. I am an average driver at best and I am quite a bit faster and more consistant with this chassis. This car is more stable and alot easier to drive than the stock car. This is the testimony we have gotten from everyone who has bought one. Some how, it generates more traction with the exact same setup. Yet, its stiffer. I have not heard a single person who has had both cars say that the stock car handles better and go back to it. Not too bad for a car thats just "slapped together" as you love to say. So if you are so hung up on .4mm, so be it. but please don't go around bashing my product without having even run it. If you bought one and ran it and hate it, thats one thing, but you you are posting damaging comments without any grounds or basis to do so. Have a wonderful day!!!
Art Jensen is offline   Reply With Quote
Old 04-12-2003, 06:51 PM   #4728
Trader Rating: 71 (100%+)
Wohhhhhhhhhh...
Hang on everybody. No need to get all worked up. I think the point that "PIMPEDACCORD" is trying to make is the Warpspeed roll center is slightly different than the stock TC3 chassis and if the area around the diff housings were cut down a little the car "MIGHT" be even better than it already is.
I am sure it is great car. The machine work is "EXCELLENT" and all of the ideas behind the car seem right on in my eyes......
RBLove is offline   Reply With Quote
Old 04-12-2003, 08:06 PM   #4729
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default rear toe in
hiyas fellas if a guy had the r+2 -0 block in rear with losi 1degree reah hubs on opposite sides what would the rear toe be seems like it is .5 each side but no sure way to measure it ???? anyone know for sure ???
dynoman007 is offline   Reply With Quote
Old 04-12-2003, 08:08 PM   #4730
You will have 1 degree per side...
Old 04-12-2003, 08:43 PM   #4731
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Hmmm... well the Warpspeed car might just be faster on carpet, but if you're talking about rubber tire/asphalt, then you're more than welcome to come get some of this Mission in Memphis.
BigDogRacing is offline   Reply With Quote
Old 04-12-2003, 09:28 PM   #4732
dynoman007's Avatar
Default cool
thx rob ,,, when you fellas gonna ride down to the fort and race ?
Old 04-12-2003, 11:41 PM   #4733
Registered User
OB42TC3's Avatar
Originally posted by pimpedaccord
Muffin- The point is that when it was slapped together, the whole car was raised. Why would you want to run half an mm higher ride height? Milling .4mm off a 3mm chassis is going to have negligible increases of stress concentrations.
How could it have been 'slapped together'? it took them forever to produce a picture of it.
OB42TC3 is offline   Reply With Quote
Old 04-12-2003, 11:57 PM   #4734
Registered User
OB42TC3's Avatar
Default Re: Warpspeed chassis thickness
Originally posted by MUFFIN
It doesn't change the roll center if everything mounts on the same plane.
Do you understand how these work? The angle of the lower arm(which changes due to ride height) also determines roll center; not just the top arm angle. So to maintain the same Roll Center the ride height has to decrease which makes the chassis drag the carpet more or DQs you OR to maintain ride height the RC goes up and the CG too. Sounds like a winner!
Old 04-13-2003, 08:16 AM   #4735
No you would have .5 per side.
The R2+0 blocks give you 1 deg. per side and the losi 1 deg blocks take off .5 per side so that would equal .5 per side.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-13-2003, 12:00 PM   #4736
Sigearhead's Avatar
Trader Rating: 68 (100%+)
NO RBLove was right. You will have 1 per side, The Losi blocks will add or take away 1 degree of toe on the side placed.
If you have the 3 + 2 block then you have 3 degree of toe per side and the 2 + 0 is two degrees per side and so on and so forth.
Put the car on a Hudy setup system and you'll find out for yourself.
Sigearhead is offline   Reply With Quote
Old 04-13-2003, 12:13 PM   #4737
Dingus's Avatar
Yup, it's per side.
Dingus is offline   Reply With Quote
Old 04-13-2003, 12:40 PM   #4738
Registered User
OB42TC3's Avatar
I would also like to know the answer; is it 1 per side or .5 per side.
Old 04-13-2003, 12:49 PM   #4739
UHHH NOOOOO!!!! I WAS RIGHT!! HE SAID-----
Soo you see if you start with the R3-2 blocks he would be right, but as as asked he said the R2-0 blocks...... I can read! HEHEHE
Old 04-13-2003, 12:54 PM   #4740
YES , the Losi 1 deg blocks take .5 or 1/2 deg. per side.
The Losi 1/2 deg. blocks take away .25 or 1/4 deg. per side.
the end result is the Losi 1 deg blocks take 1 total deg. from the entire rear toe, and the 12 deg. blocks take 1/2 total deg. or rear toe away....or add it depending on how they are installed....
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
