Like Tree4Likes
Old 03-31-2003, 07:38 PM   #4666
Lab-driver's Avatar
You might have put too much diff grease on them or didn't tighten them enough, give that a try.
Lab-driver is offline   Reply With Quote
Old 03-31-2003, 07:41 PM   #4667
omalley's Avatar
Send a message via AIM to omalley
ill give that a shot.. thanks
omalley is offline   Reply With Quote
Old 03-31-2003, 07:45 PM   #4668
Scrad's Avatar
Trader Rating: 15 (100%+)
The diff nut or bolt could be stripped. There would be not pressure when the car is off the ground, but once you set it down there is more pressure. I'd make sure that it is tight and not stripped. One other thing. I know it sounds dumb, but are the tires glued to the rims. I had a JrT that didn't have the tires glued to the rims and I racked my 10 year old brain for days. Ahh the good ol days.
Scrad is offline   Reply With Quote
Old 03-31-2003, 07:52 PM   #4669
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Diff Issue
Originally posted by omalley
okay so heres my problem.. probably totally simple but i am at a loss at the moment.
I rebuilt my diffs and now once i have everything back together.. everything seem to turn correctly and when i hit the throttle all for wheels turn. but and soon as i put it down on the ground it wont move. only the shaft moves and not the diff gear.
any ideahs?
did you stay with the metal outdrives or change to the plastic ones. if you switched to plastic you can not run bearings in them only bushings will work
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 03-31-2003, 07:56 PM   #4670
Deves's Avatar
Howard I missed your race how is the Warpspeed??
Deves is offline   Reply With Quote
Old 03-31-2003, 08:33 PM   #4671
SixVi6-Camaro's Avatar
Send a message via AIM to SixVi6-Camaro
I had that problem last week during a race after a fresh front diff rebuild. I just lost drive to the front wheels. I didn't crash or do anything about a 1/2 lap in. it turned out to be the diff screw was sheared off right at the head. strangest thing I've ever seen.
SixVi6-Camaro is offline   Reply With Quote
Old 03-31-2003, 08:39 PM   #4672
i have had that problem with the yokomo diff screws but never on the tc3. its is prob. all that horse power you run jk
Old 04-01-2003, 01:35 AM   #4673
theisgroup's Avatar
Default Re: Re: Diff Issue
AE does make a bearing set for the plastic outdrives, just not the same part as the steel oudrives
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-01-2003, 04:24 AM   #4674
omalley's Avatar
i did just put the AE bearings in the outdrives in the rebuild. Ill try cleaning any excess lube off the gears and replace the bushings and see what happens..
any more ideahs would be appreciated..
and yes the tires are clued
Old 04-01-2003, 06:58 AM   #4675
Dingus's Avatar
Don't use the bearings in the plastic outdrives. Even if you get it to work, it will still slip easier than the bushings.
There really isn't enough movement to warrant bearings in the diff anyway.
Dingus is offline   Reply With Quote
Old 04-01-2003, 09:22 AM   #4676
make sure when you do use bushings you put the correct ones in. there is a set for the steel outdrives and a set for the plastic ones(which are thinner because of the thinner flange). im pretty sure the part # for the plastic bushings is asc3907.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-01-2003, 03:45 PM   #4677
omalley's Avatar
swapped out the bearings in the plastic outdrives with bushings all is well again. hmm interesting delima i had. oh well, lessons learned.
thanks for the help
Old 04-02-2003, 06:05 AM   #4678
OleC's Avatar
Megatech alu parts?
Does anyone have any experience with the Megatech hop ups for the TC3?
They do have a lot of alu at reasonable prices, but how is the quality? When looking at the pictures on Americas Hobbysenter’s webshop the holes in the arm mounts doesn’t look good.
I was looking to buy the front alu knuckles and front and rear arm mounts, but now I am not so sure.
What do you think??
OleC is offline   Reply With Quote
Old 04-02-2003, 09:03 AM   #4679
CRASH's Avatar
Trader Rating: 26 (100%+)
Default IRS Chassis Conversion?
Anyone have any expereince with this chassis?
Thanks,
CRASH is offline   Reply With Quote
Old 04-02-2003, 09:07 AM   #4680
rc-zombies's Avatar
Default Re: Megatech alu parts?
What do you think??
I have the arm mounts...they are better than stock..will not break.
The holes look big coz there is also a delrin insert that the arm pins go into..makes for a very smooth suspension. front and rear knuckles are just a good.
Thanks,
Great for outdoor racing...not too stiff like the graphite tub.
Along with the graphite side stiffeners it will do just as well on carpet.
Check out my MSN photo album..I've got some pics of my TC3 w/ IRS and Megatech parts... unfortunately I sold the car..
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
