Old 03-31-2003, 07:04 AM   #4651
Mike D's Avatar
Send a message via Yahoo to Mike D
I've used a kimbrough servo saver ever I shredded a set of metal gears in the airtronics high speed servo three years ago.
Mike D is offline   Reply With Quote
Old 03-31-2003, 07:06 AM   #4652
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Mike...
You must have had a run-in with Nelly
He did the same to my KO during Nitro Season....Full speed into my car agaisnt the wall
mike_Webb is offline   Reply With Quote
Old 03-31-2003, 09:16 AM   #4653
rayhuang's Avatar
Heres a very intersteting Tc3 vs. Losi comparison. At our last race-our fastest guy with a Losi was getting beat (by me) and he wanted to go faster. he ran our A-main NAts and Snowbirds driver's car, motor and battery. The car was a dialed Tc3, the batteries 1.17 SMC and the motor was his A-main Nats motor!!!
He TQ'd the race!!! So for the A-main-he put the battery and motor in his Losi G+ (which is very good) and we rolled it out the same as the Tc3 and he went 3 tenths slower per lap!!!
So on this latest layout of our track-the TC3 had a decided advantage over the Losi in a big way!!!
Old 03-31-2003, 09:19 AM   #4654
rc-zombies's Avatar
Next I want to see TC3 vs YOK SD1
Old 03-31-2003, 10:17 AM   #4655
Send a message via AIM to ZER01
Originally posted by IMPACTPLAYR
PROUD- maybe next time you might wanna sleep it off beforeyou try to make any since......LOL
You're absolutely right, I should have. Your since is suppose to be sense.
ZER01 is offline   Reply With Quote
Old 03-31-2003, 12:12 PM   #4656
PROUDWINNER- good to here yur dayz gettin' a litle betar....LOL
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-31-2003, 12:12 PM   #4657
I am currently in a personal battle between a Losi G+ and my old trusty TC3.
I had previously run a Losi and found that I couldn't even get it close on speed to my TC3, so it soon became my son's car. It works for him since he is only 7 and just learning to drive.
Recently I purchased a Losi G+ from a local racers who had won many events. I knew this car was good and fast. This last Sunday I alternated running this car and my TC3.
My first two runs were with the Losi. The car felt good, but just looked slow. The lap times where nowhere near where I wanted them, about 4 tenths slower than I expected.
My third run I put the TC3 out there and got much closer to the lap times than I had with the Losi. I was pretty convinced that the TC3 was faster, but decided to put the Losi out for the main.
In the main, I ran a lap only 2 hundredths slower than my best lap in the TC3.
This just tells me that the two cars require different driving styles to get the best out of them. The TC3 loves being thrown into the corners and accelerating out of them. The Losi requires a more gentle touch to keep the speed up through the corners.
My opinion right now is that the TC3 is a better car for me. My driving style matches this car. The Losi is a great car too, and if I spent the amount of time with that car that I did with my TC3 I would probably go just as fast with it.
I've seen enough of the big races where the car manufacturers are fairly represented and it all comes down to a driver knowing how to drive his (or her) car.
Jeff Gilligan
gotpez is offline   Reply With Quote
Old 03-31-2003, 03:18 PM   #4658
GOTPEZ-- exactly!! The Losi likes to be driven and the TC3 likes to be "whipped" 2 different styles.....
Old 03-31-2003, 04:03 PM   #4659
Number 11's Avatar
Default Yokomo one way
I just got the Yokomo one way today. I wanted to know what type of grease should I use with this since the instructions are not in English. Does the Steatlh lube work for this or should I use something else?
Number 11 is offline   Reply With Quote
Old 03-31-2003, 04:50 PM   #4660
You should probably use serpent one-way lube or some other "one-way" specific lube.....
Old 03-31-2003, 04:51 PM   #4661
Number 11's Avatar
Do you know where I can get that at?
Old 03-31-2003, 04:54 PM   #4662
Scrad's Avatar
Trader Rating: 15 (100%+)
Check ebay and do a search for xray. I think www.teamxray.com has some in there e shop.
Scrad is offline   Reply With Quote
Old 03-31-2003, 04:58 PM   #4663
http://www2.towerhobbies.com/cgi-bin...?&I=LXEB13&P=7
here's some racers choice stuff....
Old 03-31-2003, 06:08 PM   #4664
Number 11's Avatar
Thanks guys for the info.
Old 03-31-2003, 07:23 PM   #4665
omalley's Avatar
Send a message via AIM to omalley
Diff Issue
okay so heres my problem.. probably totally simple but i am at a loss at the moment.
I rebuilt my diffs and now once i have everything back together.. everything seem to turn correctly and when i hit the throttle all for wheels turn. but and soon as i put it down on the ground it wont move. only the shaft moves and not the diff gear.
any ideahs?
omalley is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
