Like Tree4Likes
Old 03-27-2003, 02:06 PM   #4606
Thanks. Could you use the 115 cutting bit to enlarge the motor hole and to remove the material on the sides for the turnbuckles?
coolrcdad is offline   Reply With Quote
Old 03-27-2003, 02:10 PM   #4607
mistercrash's Avatar
R/C Tech Charter Subscriber
Yes you could. I used both because I had them but if you have to buy new bits, then just use the #115 and save some money
mistercrash is offline   Reply With Quote
Old 03-27-2003, 04:03 PM   #4608
Number 11's Avatar
Default Electric motors
Guys,
I am new to electric just started racing them this winter. I have a FTC3 and a T3 we race indoors on carpet. I run the FT in a stock class and my T3 in a 17 turn foam class, this is probably the best class because the guys are so willing to share tips.
What I would like to know is, if there are any good websites out there that I could read up on motors? Basically I want to know how to tune, clean what type of brushes and springs to use. Things like that. Everything that I have read so far is so vague I need some meat. Thanks
Number 11 is offline   Reply With Quote
Old 03-27-2003, 04:48 PM   #4609
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Talking got a perfect thing for u
im pretty sure i got this off of tony phalens site but im not positive. its by wild hobbies. if u send me an email i can send u one back with it as an attachment or if u want me to paste it in.
[email protected]
rdub202 is offline   Reply With Quote
Old 03-27-2003, 07:35 PM   #4610
JSJ Racing's Avatar
Send a message via AIM to JSJ Racing
Default Re: NTC3 steering rack and blueprinting
Originally posted by mistercrash
coolrcdad
I did the NTC3 rack conversion and documented it. You can go here to see it. Just click on "NTC3 steering rack modification".
DRIVEN
I blueprinted my TC3 and posted a clip of the spinning test on my website. Click here to see it. Does all this work make the car faster? I don't know. This is still being debated. I guess it would affect runtime since it takes less power to keep the drivetrain rolling.
Mistercrash what bearing are in the tc3?
JSJ Racing is offline   Reply With Quote
Old 03-27-2003, 08:05 PM   #4611
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Factory Team has the Teflon Bearings.
I think all other TC3's have the Rubber Sealed.
Guys...I have the IRS Aluminum Front Diff. I had to buy it down at snowbirds because I was poping the CVD's out of the Diff down there and that was the only solution I could come up with to fix it. My problem is that now I have 2 hugh gashes in it where the CVD Pins press agaisnt it. What can I do to stop this from happening? I heard of Diff Savers that go over the Pins but I tired that with heat shrink and it was very very hard to get into the Diff and now my drivetrain is not as free as it was without the heatshrink. I use the composite bones.
thanks
Mike Webb
mike_Webb is offline   Reply With Quote
Old 03-27-2003, 08:12 PM   #4612
Send a message via AIM to ZER01
Mike Webb, I wouldn't bet on this but the niftech swivel pins might help you.
ZER01 is offline   Reply With Quote
Old 03-27-2003, 09:04 PM   #4613
Dingus's Avatar
Even cheaper, just use the IRS pin cushions for the plastic or al outdrives.
Well. I did the NTC3 swing mount steering. Not too difficult, but I would definitely recommend using digital calipers. Made it much easier.
Dingus is offline   Reply With Quote
Old 03-27-2003, 09:10 PM   #4614
superk's Avatar
wrong post.
superk is offline   Reply With Quote
Old 03-28-2003, 04:00 AM   #4615
ya i have been using irs pin cusions in the plastic and irs outdrives with excellent results. i think you can but a pack of 4 for 5 bucks or you can get the a set of 4 irs composite bones with the cusions installed for 15.00 i think.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 03-28-2003, 04:18 AM   #4616
Default Re: Re: NTC3 steering rack and blueprinting
I started out with a TEAM kit so my bearings are rubber sealed.
Old 03-28-2003, 06:23 AM   #4617
Mike D's Avatar
Send a message via Yahoo to Mike D
If you run aluminum outdrives, you need to run the IRS pin cushions.
Steel dogbone pins + aluminum outdrives = not good
Mike D is offline   Reply With Quote
Old 03-28-2003, 06:24 AM   #4618
mike_Webb's Avatar
I hear you Mike
Old 03-28-2003, 06:30 AM   #4619
Mike D's Avatar
I'm still using a pair of the non-blue IRS aluminum diff halves. They are 2-3 years old and have no wear because of the pin cushions. Too bad my suspension arms don't last that long.
Old 03-28-2003, 08:22 AM   #4620
omalley's Avatar
Send a message via AIM to omalley
Default Gearing
whats some of the gearing people are using in their TC3's? Example 48 or 64 pitch.. 96 Tooth with 23T pinion
omalley is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
