Like Tree4Likes
Old 03-25-2003, 06:48 AM   #4576
OleC's Avatar
Thanks Dingus!
OleC is offline   Reply With Quote
Old 03-25-2003, 08:36 AM   #4577
Default Freeup the Drivetrain
Thanks Dingus for the file... I did the what you call "blueprinting" to free up the drivetrain but didn't notice any difference. How free should it be free? Do you just spin the tires and count how many seconds before it stops spinning?
DRIVEN is offline   Reply With Quote
Old 03-25-2003, 08:40 AM   #4578
Lonestar's Avatar
OleC: just normal metric screws... no fancy conic threads or anything. I guess I should have bought the Yok shock caps first.
For stock racing, instead of rev exp, you can also setup your radio so that at neutral there's already some throttle action... it helps with corner speed. You have to use a chassis setup with lots of turn-in with this trick, because it also make the car feel a little pushy sometimes.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-25-2003, 08:56 AM   #4579
Dingus's Avatar
Like I said, I didn't create the file. Just passin it around.
It shows the places that need a little massaging, how much exactly you'll have to figure out. Just be sure the bearings don't "stick" in any of the plastic areas.
How long your car will spin will depend on a vriety of factors such as how clean your bearings are, how tight some of the various screws are, how heavy the spinning parts of your drivetrain are, wheels etc.
It's tedious, but it is best to do one part at a time and see if there is a difference, then keep going or move on.
NTC3NUTS very detailed pics and descriptions of the ntc3 rack conversion is around pg 100-105 of this thread.
Dingus is offline   Reply With Quote
Old 03-25-2003, 09:15 AM   #4580
DaveW's Avatar
Lonestar... the screw you use has to be a coarse thread... not a fine machine thread. The finer the thread the greater chances for leakage. My first set of caps i drilled i used the screws that used to hold Novak speedos (Cyclone) together... but the fine thread caused them to leak. For the frustration, it is simpler to just order the Yok caps. I went through this years ago when the MX4 came out... and had the little screws in the caps... but the caps wouldnt adapt to my then new TC3. they wouldnt screw all the way down on the shock body, and leaked at the threads. So i used a #55 drill bit (second attempt,same hole size as an Associated #1 piston) and drilled my TC3 caps. I used the Yok screws... and worked like a charm. Now the caps that Yok makes work with no issue on TC3 shocks. Matter of fact... if you look hard, you can still see that i have the ASC caps with the Yok screws (Yok caps are knurled at the bottom if i am not mistaken)... they last a long time!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 03-25-2003, 09:27 AM   #4581
rc-racer's Avatar
What is the part # for the Yok shock caps? Is it YS-8D?
rc-racer is offline   Reply With Quote
Old 03-25-2003, 09:35 AM   #4582
mistercrash's Avatar
R/C Tech Charter Subscriber
Default NTC3 steering rack and blueprinting
coolrcdad
I did the NTC3 rack conversion and documented it. You can go here to see it. Just click on "NTC3 steering rack modification".
DRIVEN
I blueprinted my TC3 and posted a clip of the spinning test on my website. Click here to see it. Does all this work make the car faster? I don't know. This is still being debated. I guess it would affect runtime since it takes less power to keep the drivetrain rolling.
mistercrash is offline   Reply With Quote
Old 03-25-2003, 11:04 AM   #4583
mistercrash -- awesome pages with the mods! Thanks for posting.
coolrcdad is offline   Reply With Quote
Old 03-25-2003, 11:42 AM   #4584
Mistercrash...what did you do to get your drivetrain that free? I've worked on mine for hours and can still only get it to spin for only four seconds
DOTMAN is offline   Reply With Quote
Old 03-25-2003, 11:57 AM   #4585
The heavier the drivetrain, the longer it is going to spin. I have the composite shaft and composite CVDs but the rubber tires are heavy so it spins longer than if I put foam tires on the car. Basically, I did what everybody must have done, releaved some material so the bearings won't be pinched, I didn't torque the screws for the diff halves too much, I took out the interior seal of every bearing, cleaned them thoroughly and put a drop of good bearing oil. When I do this test with foams, it spins somewhere between 12 and 13 seconds.
It's fun to see the wheels spin this long but I haven't noticed any speed difference on the track. Like I said, maybe this helps to get slightly longer run times but I haven't made any tests on that.
P.S.: Please don't tell me I should make another "How to" page on my site
Old 03-25-2003, 12:23 PM   #4586
DaveW's Avatar
Holy rusted metal Batman! Spinnerooooonie! I think a free drivetrain yields a higher average voltage from your battery pack for your motor in the latter half of the run. Efficient driveline and driving style can only mean lower amp draw. Just depends on if it is mod class giving you more run time... or stock class giving you a cooler and faster motor all the way to the end of the heat. Of course... this usually means we gear up to go faster! Its all about percentages and small gains... now if only i could drive!
- Dave
Old 03-25-2003, 12:33 PM   #4587
Default Thanks for the clarification
I've been racking my brain to explain to myself why did I put so many hours on my drivetrain to free it up... If the answer is that I can gear up a tooth or two than it was worth it. Now why didn't I come up with this answer myself? Well I know the answer to that! I'm good with my hands but my head don't work.
Thanks again.
Old 03-25-2003, 09:30 PM   #4588
I am white trash
fatovalguy is offline   Reply With Quote
Old 03-26-2003, 11:16 AM   #4589
omalley's Avatar
Send a message via AIM to omalley
Default Tires
whats good tire for parking lot racing? The lot we race on is concrete, I was running the V-rage tires, but they got ate by the concrete fairly fast.
any suggestions?
omalley is offline   Reply With Quote
Old 03-26-2003, 11:20 AM   #4590
theisgroup's Avatar
take offs are relatively inexpensive and work well.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
