Old 03-20-2003, 07:31 AM   #4531
OleC's Avatar
This is probably not the right thread/ forum, but if someone could put me in the right direction I'd appreciate it.
Im looking for a really cheap/ good online webstore (based in the US). I have been shopping at Tower Hobbies and the Integy webshop. The service is good but the prices isn't that great
I'm looking to buy TC3 parts/hop ups and electronics (motors) mostly.
Also, does anyone know if the Fastrax parts for the TC3 sold by CML distribution in England is the same parts as Megatech sells/ produces?
OleC is offline   Reply With Quote
Old 03-20-2003, 07:34 AM   #4532
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by OleC
Has anyone tried to put spacers between the motor and the motor cam to let air pass easier trough the end of the motor?
Or how about milling larger holes in the can, would that ruin the motor or making it illegal?
-BTW: DHI stands for Dansk(Danish) Hobby Import
Those holes are the shape they are for a reason. That would alter the magnetic field and could really screw up your motor.
Jon Kerr is offline   Reply With Quote
Old 03-20-2003, 09:29 AM   #4533
OleC's Avatar
I know that is the theory, but has anyone tried it?
Old 03-20-2003, 09:38 AM   #4534
Dingus's Avatar
You could post the question to Jim Dieter on Tech Talk. He has a thread he responds to at Trinity.
I can't imagine he hasn't tried just about everything with a motor.
Online shops in the US:
www.stormerhobbies.com
www.speedtechrc.com
www.kthobbies.com
There are others
edit: Woops! How embarrasing
Dingus is offline   Reply With Quote
Old 03-20-2003, 09:48 AM   #4535
Send a message via Yahoo to LaxRacer
wrong speed tech
http://www.speedtechrc.com/
LaxRacer is offline   Reply With Quote
Old 03-20-2003, 05:10 PM   #4536
Default Caster and Kick Up
I've seen setups with a 4deg caster block with 0 deg kick up and 2 deg caster block and 2 deg kick up? What is the difference and advantage because both end up with 4deg total caster..
DRIVEN is offline   Reply With Quote
Old 03-20-2003, 05:15 PM   #4537
4 deg with 2 deg of kickup is supposed to handle a bumpier surface better. On a smooth track, there shouldn't be much difference.
DOTMAN is offline   Reply With Quote
Old 03-20-2003, 05:40 PM   #4538
Registered User
OB42TC3's Avatar
Originally posted by theisgroup
I was also thinking about using some of that computer fan heat sink dope between the heat sink and motor.
That is a good idea, ever try building a computer w/o the transfer compound?
OB42TC3 is offline   Reply With Quote
Old 03-20-2003, 05:41 PM   #4539
theisgroup's Avatar
yeah, the old proc were ok without it, but once they hit 1gig, they need all the help they can get.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-21-2003, 06:02 AM   #4540
Mike D's Avatar
Send a message via Yahoo to Mike D
Default DOTMAN
Not totally true...
0 degree kickup will smooth the car out on turn-in and through the corner. Weight also transfers to the front faster. It is better to use 0 degree kick up to smooth the car out on high traction surfaces.
2 degree kickup is the kit setting because it works best in most conditions. It will cause the car to turn into the corner more and will reduce steering on turn exit.
When calculating total caster take into account kick-up angle and caster block angle. More total caster will cause the sedan to steer into the corner more and reduce steering on turn exit.
For example, using kit and optional settings:
Most steering into the turn and least off: 2 kickup + 4 caster block
Least steering into the turn and most off: 0 kickup + 0 caster block
Mix different kickup and caster block angles to get desired handling characteristics in between extremes.
Mike D is offline   Reply With Quote
Old 03-21-2003, 07:03 AM   #4541
OleC's Avatar
Will the NTC3 bumper fit the TC3 without any major modifications?
I am thinking about the lower part, foam bumper and the top brace.
If so, will the body posts from the NTC3 have the same position as the original TC3? It looks to me like the NTC3 has the body posts further apart.
Old 03-21-2003, 07:57 AM   #4542
rc-zombies's Avatar
No they will not fit.
and no..body post are further aparts
Old 03-21-2003, 09:38 AM   #4543
Thanks, Mike. I actually use a little negative kickup. It seems to really make the front tires dig in more in tight turns
Old 03-21-2003, 09:48 AM   #4544
Default Ride Height and Tweak
Thanks Mike for the explanation on Caster and Kickup.
Another thing on ride height and tweak. My car seems to be heavy on the LEFT (battery side) due to the weight of the batteries. Is that what you call tweaked? Anyway, I've been reading about how to adjust tweak and it calls for adjusting the shock collars. Now, if I do that, the ride height changes at the same time and will not be even acroos 4 corners. How do I tackle this problem?
Old 03-21-2003, 10:23 AM   #4545
Mike D's Avatar
Default Setting Tweak
Having more weight on the battery side of the car is weight bias and not tweak. Weight bias isn't great to have but tweak is worse. Tweak will make your car noticably turn better either left or right.
Tweak is a diagonal problem in the chassis. For example, if your left rear wheel is lighter then your right rear wheel, then right front wheel will also be lighter then your left front wheel. You correct tweak by adjusting the shock collars diagonally. In this example, you would tighten the left rear and right front shock collars equally. This will fix tweak without jacking the ride height from left to right.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
