Old 03-19-2003, 12:31 AM   #4501
Manfredo's Avatar
heatsink - cyrul-style...
Manfredo is offline   Reply With Quote
Old 03-19-2003, 04:08 AM   #4502
NTC3NUT's Avatar
I see very few guys running heat sinks on their motors at our carpet track. I sold my FT stuff & made this one from the AE black cam & clamp.
NTC3NUT is offline   Reply With Quote
Old 03-19-2003, 06:22 AM   #4503
Scrad's Avatar
Trader Rating: 15 (100%+)
I also got rid of mine last week. A friend offered to buy it for 5 dollars and I said ok, since I think it makes the motor hotter. Plus I'll be running my xray more now.
Scrad is offline   Reply With Quote
Old 03-19-2003, 06:35 AM   #4504
NTC3NUT's Avatar
Yup, me too, $5 ea. for the blue clip-on heat sink, the big blue motor clamp heat sink, the blue battery strap, and the blue motor cam. Also sold a couple of the bigger blue clip on heat sinks. Most of them where bought by a young kid with a RTR TC3, you should have seen him, he was on cloud 9. I think he was happier than the day I let him go thru my sticker collection. Man, I didn't think you could get that many stickers on a sedan body!
Old 03-19-2003, 06:55 AM   #4505
DaveW's Avatar
Since the large ASC heatsink blocks one side of the holes on any motor can... i hollowed the center area of the sink. Now air is drawn through the sink...and across the fins to dissipate heat better. I only use it on extremely hot asphalt though... where the heat of the sun radiates off of the track and into the motor through the chassis. With the holes being covered up on one side... the hot air has nowhere to escape. But usually i just run the ASC large motor clamp... and gear reasonably.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 03-19-2003, 07:48 AM   #4506
Scrad's Avatar
I drilled holes in my heatsink, but the motor still got hot.
Old 03-19-2003, 07:58 AM   #4507
Lonestar's Avatar
Howdy folks,
I'm in search of a FT TC3 mod (12x2) carpet setup based on the following:
- Orion B tires (spec rubber tires)
- front one way (the really fast guys run and swear by them, and I have no spool available)
- rear tower at the front, updated front and rear A arms
- Tight and technical track, fast laps are under 10s, fast sweeper, tons of 180's in the infield
- Preferably with 0 deg castor blocks (it's a PITA to get AE parts here in switzerland and 0deg is all I have)
Can anybody help? I asked a similar question a few weeks ago, but to no avail... TonyP's site doesn't have what I need... neither does AE's site...
Plus I have a couple more questions...
1- Do the bump steer washers really have much influence on changin the handling?
2- Yesterday night I was trying a new setup and the (rear it seems) tires started shattering on hard acceleratin exiting corners... It seems the problem got cured by adding negative camber... Can anybody explain?
3- Why is there a rumour that people are switching back to the "old" front shock tower.... especially when I just switched to the rear shock tower up front
Thanks for the info folks.
Later
Paul
Lonestar is offline   Reply With Quote
Old 03-19-2003, 08:01 AM   #4508
PizzaDude's Avatar
Lonestar,
Try to find one of the settings which were used on the DHI race.
Orion B-compound tires tires were specs there also.
There maybe some on www.rczone.net.
Or go to http://home.swipnet.se/airwide/
tc3 corner > setups. look for DHI.
good luck
PizzaDude is offline   Reply With Quote
Old 03-19-2003, 08:06 AM   #4509
Lonestar's Avatar
Default thanks...
PizzaDude... Thanks for the help...
Thanks!
Paul
PS: Samurais rule! I have an unassembled kit in my basement that I'm keeping for the day we move out of that flat and I can have my RC museum
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Old 03-19-2003, 08:10 AM   #4510
PizzaDude's Avatar
I don't know what it stands for.
But DHI is the importer/distributor in Danmark for Asso, Orion and more.
And even JB is made by them.
For the last 2 or 3 years they organise a big event very early in the year with all big names from Europe competing.
CU
Pizza
Old 03-19-2003, 08:13 AM   #4511
PizzaDude's Avatar
About the Samurai.
It was my first kit.
But having no money, and wanting to advance with newer kits I sold mine many, many years ago.
I'm jalous off you man.... (unassembled and all...)
Let me know how you fare...
Old 03-19-2003, 09:48 AM   #4512
Send a message via AIM to ZER01
So has anyone tried the new Yokomo diaphragm shock caps for the TC3 yet? If so, does the car handle any differant?
ZER01 is offline   Reply With Quote
Old 03-19-2003, 09:52 AM   #4513
rc-zombies's Avatar
Haven't tried it yet though... but from my experience with HPI diaphragm it gives quicker rebounds.
Old 03-19-2003, 10:24 AM   #4514
Well if I can ever get to speedtechrc, I'll order some to try out. One things for sure, no more 30 refills to get the same rebound.
Old 03-19-2003, 12:48 PM   #4515
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Steup for Carpet Stock Racing
I am looking for different setups to try for stock sedan, rubber tires carpet. Medium size track, fairly good traction.
Thanks,
Tony
CRASH is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
