Like Tree4Likes
Old 11-20-2001, 09:08 AM   #436
JOHNNY RACER's Avatar
Default cosmo
where is your bat location? F, R or a split
JOHNNY RACER is offline   Reply With Quote
Old 11-20-2001, 09:55 AM   #437
Cosmo's Avatar
Sorry. It is back. We have to run stick packs according to the rules here, so split packs are not an option.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 11-20-2001, 10:03 AM   #438
David Joor's Avatar
R/C Tech Charter Subscriber
Cozmo - Is the stock toe in block the 3-0 block? You running a oneway?
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 11-20-2001, 12:23 PM   #439
TPhalen's Avatar
My suggestion is trying the Standard World's Setup. Whenever we go to a big race, this is the setup the car has on it when we arrive. We make adjustments from it. It usually works just about everywere we go (with some small changes). If you just want to modify this setup, I would suggest laying the rear shocks down. you might try a red spring in the front or a green in the back. Personally, shock oil is gonna make the biggest difference.
If you choose to try the Standard World's Setup, my site has that and many more TC3 setups to check out.
Airwide: We did notice the stiff wheels make the car a little more responsive with a bit more steering, but not too much. Of course, your track surface might differ quite a bit from the massive traction SoCal has...
Oh ya, and, by the way, saw your site....nice!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 11-20-2001, 12:43 PM   #440
Cosmo's Avatar
Thanks. I'll give that a shot.
Old 11-20-2001, 06:19 PM   #441
badboy's Avatar
Trader Rating: 14 (100%+)
TP : Thanks!!! I'll try it our and lets see what happens during our weekend race. I'll keep you posted if I encounter more problemo
badboy is offline   Reply With Quote
Old 11-20-2001, 10:45 PM   #442
robk's Avatar
Trader Rating: 22 (100%+)
"If you are feeling really sassy" - LOL Tony that was awesome.
Cosmo- How much caster ase you using? That can also have a big effect...
Old 11-21-2001, 09:29 AM   #443
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I'm glad you liked it. My equipment haven't been updated in a while. I'm now using Advanced speedos and batteries and Reedy motors instead of the LRP stuff I used before.
I'm gonna take a lot of pictures at Procar Open this weekend and write a race report next week. A lot of good nordic drivers are attending the event. To name a few: Andres Myrberg(HPI/LRP), Mikael Fransson(X-Ray) and Steen Graversen(Schumacher/Orion).
Airwide is offline   Reply With Quote
Old 11-21-2001, 12:07 PM   #444
Send a message via AIM to Type S
tony, i tried to download the worlds setup for the tc3 from your site but it didnt seem to work. do i have to download it or up load it from the site?
thanks
Type S is offline   Reply With Quote
Old 11-21-2001, 02:20 PM   #445
TPhalen's Avatar
Sorry...ya, you will need Adobe Acrobat Reader. I have a link (that somehow disappeared) on the home page now to the exact place on Adobe's site to download the Reader. It's FREE!!!! Get it and you should be able to download all the files you want...
Thanks for the info....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 11-21-2001, 08:42 PM   #446
spawn's Avatar
Default glitch
Helppp... I just put in an 11T into my TC3.. whenever I pull the throttle... my car glitches badly but if I pull the throttle slowly nothing happens...now is it because my receiver is too close to the motor or my motor has not been run in enuf or could it be the comm drop... I am using kinwald-trinity comm drop.... cant control it to go straight....
spawn is offline   Reply With Quote
Old 11-21-2001, 09:43 PM   #447
Setup
We race on an old skating rink and I'm looking for an edge. The track is about 50 feet corner to corner and about 15 feet from the middle of the straight to the same spot on the other straight. The track is about 8 feet wide everywhere. It's painted wood and very slick. You have to drift through the turns. The hot setup seems to be the tamiya rally block tread tires and no inserts. I have a p2k, 30t pinion and 72t spur. Any ideas are welcome. Thanks
Keyz28 is offline   Reply With Quote
Old 11-21-2001, 10:56 PM   #448
Keyz28,
Are the Tamia tyres a controlled tyre? If not then try Schumacher mini pins in yellow compound with Sch blue inserts.
After that I would run with 2 liniters in the front shocks and I in the rear to give plenty of droop. Other than that start with the stock kit set up and make small changes from there.
Have fun on the slippy stuff. It's quite popular here in the UK in the winter. Too wet to run outside.
Yorkie
Yorkie is offline   Reply With Quote
Old 11-21-2001, 11:03 PM   #449
Default Setup
There are really no rules as the traction dictates speed. I'll try the schu pins. Most cars are tc3 racer kits with most setups running preloads or stiffer front springs and diffs adjusted tight.
Old 11-22-2001, 09:03 PM   #450
TPhalen's Avatar
Keyz28: GOOD NEWS!!! I have a setup on my site from Craig Drescher....it's a setup for a polished wood surface!!! Go figure!!!
You can get it from www dot competitionx dot com. Go to the R/C Tuning section and to the Racing Setups. Sorry if it's a bit slow...I just went and checked it (to see if I actually had that setup) and it appears to be slow tonite.
Too much info, I guess???!!!
BTW, there are tons of new setups for a whole bunch of different cars on my site now....Go give it a looksy and see if there is something anyone can use....
Spawn: DUMP THE COMM DROPS!!!! That's the first thing. While they may provide a tad more power, they can really gunk up a motor, and you are required to spray out the motor after EVERY SINGLE RUN!!! It could be the cause of your glitching. I would also try a different motor...this will eliminate the motor as the glitching problem. If it continues to glitch, try moving the electronics around. In the TC3, the order should be motor - ESC - reciever - servo. This is the best setup to keep wires short and keep crucial wires from crossing over each other, possibly causing glitches...
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
