Old 03-15-2003, 08:37 PM   #4426
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
How about posting your Caster, Camber and Toe-In....also what camber link positions are you using???
TigeRyan is offline   Reply With Quote
Old 03-15-2003, 08:49 PM   #4427
teamsherman's Avatar
Default check my setup, its been edited
my setup has been edited
teamsherman is offline   Reply With Quote
Old 03-15-2003, 08:52 PM   #4428
team--- start by matching your springs.... very rarely will you ever use softer springs in the front. Try silver/silver
here are a few other general suggestions.
reduce front droop
reduce front toe ( toe-in steers more coming out of turns and less going in) no more than 1deg. toe-in
stand your front shocks up
lay your rear shocks down
tighten your servo saver
reduce rear-toe
shorter chamber links in the front
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-15-2003, 08:56 PM   #4429
Default rear toe
Can i reduce the rear toe without having to purchase any new parts????
Old 03-15-2003, 09:06 PM   #4430
DaveW's Avatar
Spaz... nice work man! Driftmaster... im way impressed with the spool... how do i get one?!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 03-15-2003, 09:39 PM   #4431
Registered User
OB42TC3's Avatar
Default Re: Push
Originally posted by teamsherman
G'day, i have just recently bought a TC3, and was just wondering how i can stop the car from pushing wide out of corners??
Any advice would be great.
Cheers.
You might want to try a One-way or spool they really help coming out of corners.
OB42TC3 is offline   Reply With Quote
Old 03-15-2003, 09:41 PM   #4432
Default Diff
Just the normal diff that comes in the team kit.
Old 03-15-2003, 11:28 PM   #4433
driftmaster's Avatar
- Dave
Thanx dude, the props really go to Spooler he's a friend of
mine and also a member here on R/C tech. Just PM him for the details. If you cant find him, PM me.
driftmaster is offline   Reply With Quote
Old 03-16-2003, 02:15 AM   #4434
- Dave
Dave- thanks. this has kind of been my test chassis for me to figure out what i like and dont like. so i know what i want when i get a nice machined chassis done for next year.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 03-16-2003, 07:48 AM   #4435
Send a message via Yahoo to LaxRacer
Default Considering a New TC3
Hi all
I am considering buying a TC3 as my next chassis. I know that people say go with the FT version, but honestly I can't afford it. So what I am wondering is what are the nessecary performance options that come in FT kit, things like the Heat sinks for the motor, and threaded shocks I think of as most haves. are there any others ?
So if the most haes are great I will save up to get the FT version. But I really must know what those are.
And this will be a new in the box factory sealed purchase, I don't believe in used cars so I won't be looking on EBay for a tricked out one, so please don't suggest that.
Last I am also wondering which options aren't included in FT kit. Specifically, I am wondering about drive train parts, diff upgrades, one ways, drive shafts, bearings. Or must have aftermarket parts made by others. Though I would prefer to stay with AE for parts on the kit.
Thanks for your help
C
LaxRacer is offline   Reply With Quote
Old 03-16-2003, 08:07 AM   #4436
Dingus's Avatar
If it's either/or, go for the FT or the Racer depending on your use of the car.
For racing, FT is better suited. Bashing or street play with racing in the future sometime, Racer all the way.
The team kit does not come with enough to justify the price.
FT has all the blue stuff plus all graphite parts. I don't think the heatsink is really worth much, but the al cvd's, threaded shock bodies, ti rods, are nice.
If the FT will tap your budget, then it might not be the best choice b/c you'll still need tires (for any kit, really) and a body and spares and other tuning options (spool, oneway, motors, brushes etc.)
FT is worth the $$, but not if it means you have to skimp in other areas.
Dingus is offline   Reply With Quote
Old 03-16-2003, 08:19 AM   #4437
Scrad's Avatar
Trader Rating: 15 (100%+)
You will be plenty fast with just a racer kit. I bought a racer about a year and a half ago. I didn't know if I would like touring so I didn't spend as much. I've won a few races and always finish in the A main with my racer. If you don't have the money get a racer and then get a spool and tuning options. The stuff that comes with the FT is nice, but not needed. I'd suggest going cheaper on the kit and then getting better electronics and practice driving.
Scrad is offline   Reply With Quote
Old 03-16-2003, 09:00 AM   #4438
OSherman's Avatar
Thumbs up
Originally posted by Scrad
You will be plenty fast with just a racer kit....
you said it bro'
only thing from FT kit i would consider 'needing' is the threaded shocks....but then again, i prefer the shims...
been doing good with my racer too..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-16-2003, 09:09 AM   #4439
D_Ames's Avatar
Send a message via AIM to D_Ames
Default Re: Spool
Originally posted by driftmaster
New spool is on top and the old spool is on bottom. Cut it
down more in the center and cut away some on the gear
mount. Trick huh? Not sure on the weight, but its lite.
Rotating mass, what mass!
Drift,
The problem with that is the gear will flex and strip under power. We already tried that design and had to go back to a full faced gear mount. I lightened it by drilling holes.
D_Ames is offline   Reply With Quote
Old 03-16-2003, 11:25 AM   #4440
Let me put it this way ... I am a racer so things like tires, bodies, and electronics are non issues since I already have them.
I have been running my Pro2 forever, I have run an Xray before, and I just want to try something different.
So if you guys could be a little more specific with your parts you are describing that would be great. Since I know nothing about the TC3. Like this spool thing thats being described and shown recently in this thread, where is that located. What does that replace ?
how long are the TC3 shocks ??? I could always put off getting the threaded shocks.
I am really wondering about the bearings, whats the major difference between the teams bearings and the FT bearings ?
The racer isn't for me needs the Team would be better. Though I am not a fan of eye candy that little price difference is worth it.
last question. Which parts are graphite, and which do the replace ? I know the FT has the new Arms, but what else.
thanks again
C
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
