Old 03-15-2003, 04:07 PM   #4411
Default Chassis pics
Here'w with the body off. Front view
XtremeMDX is offline   Reply With Quote
Old 03-15-2003, 04:19 PM   #4412
Default Hood design
Highlights are painted in Glow in the Dark paint. You should see this in the dark, quite eerie.
Old 03-15-2003, 04:21 PM   #4413
Default chassis mods
Pics of underbelly lighthened as well with the baterry mods.
Old 03-15-2003, 04:24 PM   #4414
Send a message via AIM to AssociatedRacer
Hey do the 2 hole a-arms only come in graphite?
AssociatedRacer is offline   Reply With Quote
Old 03-15-2003, 04:50 PM   #4415
Associated------ yes
MDX--- wow.... you did.....what?? can't see a think in the pics, can you add a little light please?
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-15-2003, 05:34 PM   #4416
hey guys here are some of the pics of my tc3 with the mods. i race on carpet with foams. mod and stock. my most recent mods are filling in the cut brace with jb weld and i will get my first chance to try it out tomarrow in stock. i have also started taping my batts in for better side to side balance.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 03-15-2003, 05:35 PM   #4417
the pics are not the best quality, but heres more.
Old 03-15-2003, 05:36 PM   #4418
more...
Old 03-15-2003, 05:37 PM   #4419
last one. ill work on getting some better quality ones.
Old 03-15-2003, 07:10 PM   #4420
teamsherman's Avatar
Default Push
G'day, i have just recently bought a TC3, and was just wondering how i can stop the car from pushing wide out of corners??
Any advice would be great.
Cheers.
teamsherman is offline   Reply With Quote
Old 03-15-2003, 08:55 PM   #4421
driftmaster's Avatar
Post Spool
New spool is on top and the old spool is on bottom. Cut it
down more in the center and cut away some on the gear
mount. Trick huh? Not sure on the weight, but its lite.
Rotating mass, what mass!
driftmaster is offline   Reply With Quote
Old 03-15-2003, 09:14 PM   #4422
Default Re: Push
Cheers.
Check your manual. Or also check www.competitionx.com
Old 03-15-2003, 09:26 PM   #4423
Default comp x
Can someone just give me a written answer here please as the site competition x gave me now info whatsoever. my question was:
How do i stop my car pushing wide out of the corners???
Thanx.
Old 03-15-2003, 09:28 PM   #4424
teamsherman-- please post your set-up and track info....
Old 03-15-2003, 09:35 PM   #4425
Default setup
The track is cement (like sidewalk stuff) straight is about 70feet,
tight technical mid section, low traction.
The car has 40wt oil all round, silver stock springs front, gold springs rear.
CS TAKEOFF 27's all round (although i tried 22's on the front and made not much difference)
Shock mounting positions are stock from the manual. Other than that, the car handles well.
One more question, Can i change the toe-in degree on the back without purchasing new parts? is it possible to use the rear mount in the front and vice versa?
Thanx again
Sorry, camber front is about 1degree /_\ and toe in is the same
same on the rear for camber, but toe is 3degrees stock
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
