Old 03-08-2003, 05:56 AM   #4306
No bad driving here, I maybe tap the board once or twice a night.
rcpilot is offline   Reply With Quote
Old 03-08-2003, 08:13 AM   #4307
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I must be a star driver then because like I said, I have yet to bend one.
Jon Kerr is offline   Reply With Quote
Old 03-08-2003, 08:19 AM   #4308
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I use the BRP and down at Snowbirds I got rear ended going into a turn and the car hit the Left Rear Tire and bent my pin. It all depends on the type of Walls you have and how a car hits you. The Pin was bent big time but the arm did not break. I had about 20 degrees of rear Toe out on the car after that hit...but finished the race . Luckily I put a lap on the field and the car that hit me was the second place car.
mike_Webb is offline   Reply With Quote
Old 03-08-2003, 08:44 AM   #4309
DaveW's Avatar
I got "tapped" quite a bit at the birds too. I just tore my car down last night to goto a local points race, and to my amazement... i had NO bent pins! Since i have switched to the BRP pins, i think i have bent two. But they were in Armageddon-style wrecks with lap traffic. The standard pins are good for.... well.... taking up space in my parts box! The Ti pins i have never bought... the general consensus on them was bad, so i stuck with what worked!
- Dave
DaveW is offline   Reply With Quote
Old 03-08-2003, 08:50 AM   #4310
diesel's Avatar
Default TC3 Racer Upgrades
Hey guys, what are the most essential parts to upgrade from a TC3 racer kit? Thanks for any advice.
diesel is offline   Reply With Quote
Old 03-08-2003, 08:54 AM   #4311
Jon Kerr's Avatar
Threaded shocks, Ti turnbuckles, and a full set of springs.
Old 03-08-2003, 09:14 AM   #4312
DaveW's Avatar
Swaybars if you run carpet...
Old 03-08-2003, 12:20 PM   #4313
Diesel
Also get the optional caster blocks and suspension mounts.
I like the Trinity blue foam front bumper, and BRP rear nerfwings to keep things nice and protected.
patcollins is offline   Reply With Quote
Old 03-08-2003, 12:25 PM   #4314
Send a message via AIM to AssociatedRacer
How do I blue print the diff housing? I am trying to make my Tc3 as smooth as possible, and the only thing I know how to do is take off one seal of the bearings. Any other suggestions?
Thanx
Also what are those nerf wings?
AssociatedRacer is offline   Reply With Quote
Old 03-08-2003, 12:37 PM   #4315
just remove some material from where the diff bearings sit. put the case together and see if it spins freely. also check to see if the diff falls out of each half when flipped over.
James Nguyen is offline   Reply With Quote
Old 03-08-2003, 01:37 PM   #4316
make sure you remove some material from side wall where the bearing site and not the actual seat where the outer race sits. you are just trying to increase side to side play.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 03-08-2003, 04:49 PM   #4317
The Nerf Wings
http://www.brpracing.com/6230.html
Old 03-08-2003, 04:52 PM   #4318
DaveW's Avatar
Ok..are you trying to increase play from side to side... or up and down for the bearing?? I guess you are trying to make sure the bearing isnt pinched when the tranny cases are screwed together? Or make sure the diff is free between the bearings? I have noticed some cases are tight on the bearings when the two halves are put together. On one side of the tranny case where the shock tower is lowest and closest to the bearing, when you tighten the screw that holds the tower in place, it will dimple the plastic, and press on the outer race of the diff bearing. But as far as side to side play for the diff between the bearings goes... i still have to use some of the standard shims to get rid of the excess play. (spaced to allow a looser mesh with the gear case pinion) Is this because i am still using the older gear cases that were updated for the NTC3? Were the tolerances changed from the old cases to the newer? Maybe i just misunderstood the previous question.
- Dave
Old 03-08-2003, 05:41 PM   #4319
diesel's Avatar
Default Thanks Guys!!!
Got it...Thanks for the advice guys. Cheers.
Old 03-08-2003, 06:26 PM   #4320
Hey, I know this is a little off topic. But does anyone know of a race in La Mirada tommorow?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
