Old 03-01-2003, 08:32 PM   #4201
DaveW's Avatar
Default I WISH i had a mill!
No, this was done with many hours (4) of dremel and hand sanding. The bottom of the chassis is sanded away a full mm to allow for a lower car. The center is removed for more torsional flex. There is also a removable radio tray... which i did not have time to flush mount for the Birds. The cars transfers are VERY smooth. With the weight being as balanced as it is, and moved more forward, the car is consistent and has more initial turn-in than a standard TC3. As far as breakage goes... it was hacked relentlessly at the Birds...and survived dent or crack free. I just needed more time with the car to tune it in. i have more pics too in differing stages of completion...
DaveW is offline   Reply With Quote
Old 03-01-2003, 08:35 PM   #4202
DaveW's Avatar
Thanx Mike F. Just wish i had more time to enjoy it! LOL
- Dave
Old 03-01-2003, 09:17 PM   #4203
DaveW's Avatar
I seen on one of the other posts, a graphite upper deck made for the TC3 and had a sticker on it that said "K Speed". I dig the plate, and seen one similar on Cyruls car at the Birds. Someone please let me know where i can get plate graphite so i can make one... or how i can buy one of the ones i have seen! Thanx!
- Dave
Old 03-02-2003, 12:05 AM   #4204
NTC3NUT's Avatar
You're probably looking at the K.Models center brace, very nice, but unavailable in the U.S.. Josh made his himself. You can get one similar to Josh's from Warpspeed, or you can get one similar to the K.Models brace from Wstcoastrc@aol.com , it's also made out of the new SSG silver graphite. There may be other sources here in the states that I am not aware of. Not sure on the price for the Warp speed, but the one from Wstcoastrc@aol.com is $29.95 + shipping.
NTC3NUT is offline   Reply With Quote
Old 03-02-2003, 01:34 AM   #4205
Craig's Avatar
Send a message via AIM to Craig
Dave-What servo do you have in there? I know Futaba makes on that is shorter then most.I believe its a 9450?< I wonder if that would allow you to put three cells on each side.
Craig is offline   Reply With Quote
Old 03-02-2003, 08:10 AM   #4206
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Default Silver Graphite
Here is the West Coast top deck.
Speedo is offline   Reply With Quote
Old 03-02-2003, 08:57 AM   #4207
Whats under the chassis, is that a shadow or something else?
patcollins is offline   Reply With Quote
Old 03-02-2003, 09:13 AM   #4208
Send a message via AIM to lilshortyc3
Dingus: Yes I did install them and see that the turnbuckle leans toward the back. It also seems that the ball end does not go all the way down.
Pat: I don't think that is a shadow, I think it's a black foam car stand.
lilshortyc3 is offline   Reply With Quote
Old 03-02-2003, 09:30 AM   #4209
Dingus's Avatar
I got mine all the way down, but it took some doing. Losi plastic is much stiffer than Associated's. You could also try some shorter ball ends.
Which hub carriers did you get? I'm running the 1 deg rev installed to take away rear toe.
Dingus is offline   Reply With Quote
Old 03-02-2003, 09:38 AM   #4210
I am running the same hubs and wut toe in do you have in the front with the hubs? Also wut other Losi's part do you run in the front?
Old 03-02-2003, 09:52 AM   #4211
Dingus's Avatar
My track is a smooth, med traction, nitro layout asphault. My goal was to get the car to rotate easier and have a high top end so all these mods are done to achieve that.
Front: Losi Steering blocks
Rear: Std front hinge pin carrier
R+2+2 rear block
Losi 1 deg rear hub carriers installed reverse to achieve 1 deg rear toe per side.
Others have used the fron hub carriers as well, but that requires a little massaging of the part and it's easy to go too far and then have to shim. I think you can get more caster with the Losi carriers.
Old 03-02-2003, 10:03 AM   #4212
Oh I run carpet wit foams, you think I should try out the R+2+2 block. Right now I have the R+3+0 block wit the F block on the opposite side of the R+3+0 block and F and F-0 block in front. I just installed the Losi hubs so I have never tested them out before.
Old 03-02-2003, 10:09 AM   #4213
rc-zombies's Avatar
Originally posted by lilshortyc3
When u put the Losi XXX-S hubs on the rear of the TC3 are the ball ends suppose to be facing up when on the Losi hubs? b/c that's wut it looks like can only happen...
See the mods I did with the Losi rear hubs to fit correctly:
http://groups.msn.com/RCZOMBIES/shoebox.msnw
Old 03-02-2003, 11:32 AM   #4214
Moderator
Speedo's Avatar
Yeah thats a car stand
Old 03-02-2003, 01:19 PM   #4215
Scrad's Avatar
Trader Rating: 15 (100%+)
BigAl,
After changing my oil and tires to the set up you recomended I finally won the A main last Friday. It also helped I finally got a really good servo too! Just thought I'd let you know. I was about to sell the car, but now I can't.
Scrad is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
