Old 02-24-2003, 03:53 PM   #4141
Send a message via AIM to AssociatedRacer
Hey is the blue aluminum AE shaft worth it?
AssociatedRacer is offline   Reply With Quote
Old 02-24-2003, 04:26 PM   #4142
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Weighs nearly twice as much as the composite shaft. So, just run your composite shaft til it breaks, then get the blue one...
pimpedaccord is offline   Reply With Quote
Old 02-24-2003, 04:33 PM   #4143
any idea if the input shaft pinion will be in the updated material as well?
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 02-24-2003, 07:12 PM   #4144
rayhuang's Avatar
pimpedaccord-where were you this weekend??? huh??? Marysville isnt that far from Cincinnati for the USTC race!!!
Old 02-24-2003, 07:13 PM   #4145
howard hudson's Avatar
R/C Tech Charter Subscriber
Default so sad
man getting help from any of you guys is as bad as asking a team driver SILENCE I'M outta this thread
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-24-2003, 07:25 PM   #4146
Hudson I didn't even see it. What was it?
Old 02-24-2003, 07:52 PM   #4147
mab_man20's Avatar
Send a message via AIM to mab_man20
Any word on the new associated shaft?? I heard they were switching over to an aluminum shaft.
mab_man20 is offline   Reply With Quote
Old 02-24-2003, 07:58 PM   #4148
Hey the aluminum shafts been out for a while. Its more for mod and if you break your shaft do to oneway, spool, locked diff and that stiff(i believe)
Old 02-24-2003, 09:30 PM   #4149
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Default Re: I HAVE SEEN THE LIGHT
Originally posted by howard hudson
YO I have seen the light. just ran my TC3 for the first time. I have had the car three years but never ran it . bought it for 100 green backs. and put it on the shelf. only reason I bought it was because it was such a good deal. full graphite kit lots of blue stuff and extra parts ( cant pass that up)
I ran it at a local parking lot race and wow it works a lot better than my losi with less work to get it there. so now the losi is on the shelf.
so tell me how far back do I need to go to find out about the losi front and rear hub conversion's ? and is it worth the conversion for parking lot or is it only good for carpet
I don't know about parking lot setups but the Losi pieces both front and rear will fit right on with little to no modifications. The Losi steering knuckles (I think that is what it is called) will give you more steering throw than the stock associated pieces. Also, the Losi rear hubs will allow more rear toe in options. I hope this helps some.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-25-2003, 02:07 AM   #4150
NTC3NUT's Avatar
Here's a photo of the gears, yes they are available to the public under the same part numbers, it's a running change.
NTC3NUT is offline   Reply With Quote
Old 02-25-2003, 05:20 AM   #4151
johnbull's Avatar
Hi guys. Greetings from Malta.
Has anybody tried these new white diff gears yet.
Can you tell what improvements one should expect?
To be honest we have never had any problems with TC3 diffs, but if there's any improvement in performance we will gladly switch to them.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-25-2003, 07:18 AM   #4152
rayhuang's Avatar
Default Narrowed chassis rocks!!!
Guys,
I finally ran my Tc3 at a big race with narrowed chassis, etc. and it was so good as the traction came-up. Way better tham when the car was wide. If you havent done that mod yet-you should!!!
Ray
Heres a shot of the last prototype. The production ones look the same-only cleaner as I had done some hand drmel work on this plate before giving it to a machine shop to do.
Batteries moved in 0.5", slots for taping and added cooling, battery box lowered 0.0250", extra wide motor hole and extra cutouts to further lighten.
My car crossed the scales in Cincinnati at 50.00oz with GP batteries taped in. I put my battery bar back ON to make sure I made weight!!!!
Old 02-25-2003, 09:26 AM   #4153
looks sweet ray, wish i could get my hands on a milling machine. i got to use a mill to do the brace but the rest had to be done with my trusty dremel.
i got to try the servo lowered to sit flush with the bottom of the chassis this weekend and i definately like it, the steering feels more linear and responsive along with batts moved in. the car transitions nice. flex does not seem to be a huge problem in mod either although i may try the warpspeed top deck next time.
ray- i was talking to dumas this weekend and he said you were going to be doing chassis for him, sounds good.
Old 02-25-2003, 01:02 PM   #4154
NTC3NUT's Avatar
johnbull,
I believe the gears where designed with the NTC3 in mind more so than the electric TC3. That's where they where having gear issues. The should be stronger & truer than the old plastic. You will eventually get a chance to try them no matter as they replace the originals, another running change, same part numbers.
Old 02-25-2003, 01:34 PM   #4155
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Narrowed chassis rocks!!!
Originally posted by rayhuang
Guys,
Ray
Wow
that milled chassis looks outstanding!!
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
