Old 02-23-2003, 04:08 PM   #4126
Dingus's Avatar
You can rid your body of a "permanent" crease by heating it with a heat gun or hair dryer and pressig out the crease. Might want to add a layer of shoo goo to the back of te crease after to prevent it from becoming a tear.
Originally posted by AssociatedRacer
Hey, does a crease in the hood of a body cause a lot of problems?
Dingus is offline   Reply With Quote
Old 02-23-2003, 05:29 PM   #4127
Scrad's Avatar
Trader Rating: 15 (100%+)
I know different body styles have different effects on handling. They are aerodynamically different. I'm just saying a crease in the hood isn't going to effect the over all handling of the car. Unless it is a huge crease. Like in nascar if the body gets messed up your race is pretty much over. In r/c that effect is pretty minimal.
Scrad is offline   Reply With Quote
Old 02-23-2003, 06:05 PM   #4128
andrew5's Avatar
Send a message via AIM to andrew5
can somebody give me a good carpet setup
andrew5 is offline   Reply With Quote
Old 02-23-2003, 06:09 PM   #4129
howard hudson's Avatar
R/C Tech Charter Subscriber
Lightbulb I HAVE SEEN THE LIGHT
YO I have seen the light. just ran my TC3 for the first time. I have had the car three years but never ran it . bought it for 100 green backs. and put it on the shelf. only reason I bought it was because it was such a good deal. full graphite kit lots of blue stuff and extra parts ( cant pass that up)
I ran it at a local parking lot race and wow it works a lot better than my losi with less work to get it there. so now the losi is on the shelf.
so tell me how far back do I need to go to find out about the losi front and rear hub conversion's ? and is it worth the conversion for parking lot or is it only good for carpet
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-23-2003, 08:27 PM   #4130
Coxy's Avatar
Default Re: I HAVE SEEN THE LIGHT
Hey guys. Can anyone help me out with Losi front ends on a TC3. I know this question has maybe been asked before but if you can help thanks a lot. My car is fine and hooked up but racing at this new track I need heaps of steering throw. Itís so tight and I just donít have enough low speed steering.
So my question is does Losi 0,2 and 4 front block have the same castor angle as the AE ones and is it a easy replacement and no other parts needed for the swap.
Thanks in Advance
Coxy.
How funny just saw the post below about the same thing as what I am asking.
Coxy.
Coxy is offline   Reply With Quote
Old 02-24-2003, 04:02 AM   #4131
stormperson's Avatar
Send a message via AIM to stormperson
try running the losi 6 degree castor blocks, i found they give a good amount of steering, also run the front F+2 block which in effect gives 8 degrees of castor,and alot of steering. Also try a rear sway bar, shorter wheelbase, more front sauce, maybe even a front spool if you need alot of onpower steering.
stormperson is offline   Reply With Quote
Old 02-24-2003, 01:06 PM   #4132
Send a message via AIM to lilshortyc3
don't u use the Losi 1 degree hubs in the back???
lilshortyc3 is offline   Reply With Quote
Old 02-24-2003, 01:14 PM   #4133
Mike D's Avatar
Send a message via Yahoo to Mike D
Default New Transmission Gears
Has anybody tried the new white colored TC3 transmission gears? Do they run any smoother then the old material gears when new?
Mike D is offline   Reply With Quote
Old 02-24-2003, 01:18 PM   #4134
rc-zombies's Avatar
Default Re: New Transmission Gears
Where have you seen those..? got some pics or a link to them?
If they are white..I'm guessing they are made of delrin and probably will run smoother than the original gears.
Old 02-24-2003, 01:35 PM   #4135
robk's Avatar
Trader Rating: 22 (100%+)
Somebody posted pics of white TC3 gears from the nitro worlds. I never knew if they were mass produced or not. i assumed the factory had produced them to test.
Old 02-24-2003, 01:37 PM   #4136
i saw an associated driver at my "local" (3 hr drive, lol) track using them, didnt get a chance to ask him what he thinks of them, they look like they are made of delrin.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 02-24-2003, 01:37 PM   #4137
rc-zombies's Avatar
Might be a Prototype for testing..no official release from AE yet.
Old 02-24-2003, 01:43 PM   #4138
Mike D's Avatar
I believe they are replacing the old gear and are shipping out now.
Old 02-24-2003, 02:35 PM   #4139
Registered User
OB42TC3's Avatar
They are in production now, same part numbers, so however long it takes to get to the hobby store shelves...
OB42TC3 is offline   Reply With Quote
Old 02-24-2003, 03:15 PM   #4140
Trader Rating: 37 (100%+)
Default top electric car voting....
http://www.rccaraction.com/readerschoice/ChoiceForm.asp
vote for the TC3 as top electric
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
