Old 02-21-2003, 09:11 PM   #4111
Glue-Stick's Avatar
Anyone got a URL or pic or the GPM centre oneway?
Glue-Stick is offline   Reply With Quote
Old 02-22-2003, 09:09 AM   #4112
Trader Rating: 36 (100%+)
Default 1 way
http://www.hobbyetc.com/cgi-bin/item...=984&car_id=27
check that link out...i believe that is what you are looking for.
Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-22-2003, 02:22 PM   #4113
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Yep, that's it.
I used it for a while but got faster laptimes with just the front one-way and got very very close to the same laptimes (front only) with the locked front but had more control
Anyway, yep, that's it.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-22-2003, 02:47 PM   #4114
Default locked...
i've also read/scene a lot of breakage when people are running the locked diffs.
it causes more stress on the whole assembly....cvd's.
Old 02-22-2003, 06:16 PM   #4115
Send a message via AIM to AssociatedRacer
In AE's manual they said to tighten the diff all the way, then back it out half a turn. No more no less ever. Im going to go with what they say.
AssociatedRacer is offline   Reply With Quote
Old 02-23-2003, 01:12 AM   #4116
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default Associatedracer
You can adjust the handling of the car with the diffs. You don't really want to run them too loose but you and adjust the steering by running them a little on the tight side. And if you're running a locked front diff, you should run the rear a little looser to help witht the low speed steering. Running a tighter front diff will give you more pull off the corner. They tell you that in the manual so you don't run it so loose that you're going to let it slip. In a TC, a slipping diff is a bad thing.
Jon Kerr is offline   Reply With Quote
Old 02-23-2003, 07:04 AM   #4117
Exclamation New better one-way?
Hey there! Question to you AE owners:
Has anyone got to his AE TC3 Yokomo`s made (sp3938-6) HD one-way? Price 58,50$
I ask first our AE dealer when we`ll get a new AE one-way and they answer at it is not available???
Then i also ask that from our Yokomo dealer, but they don`t get any info about that... yet.
I`m a little confuse because that Yokomo`s one-way for TC3 with bigger bearings is not a new thing??!!
I hard remember... it was almoust year ago when Yokomo published that product first time??
Proto pilot is offline   Reply With Quote
Old 02-23-2003, 12:10 PM   #4118
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
Thumbs up TC3 Top Deck
This is a direct bolt on and includes spacers and hardware. Made of the new SSG silver graphite material. Price: $29.95 plus shipping. Contact West Coast Hobbies at wstcoastrc@aol.com, or you may reach us by phone at (509) 375-4995.
Comming soon-a new bumper support for the TC3
KeNelson03 is offline   Reply With Quote
Old 02-23-2003, 12:11 PM   #4119
Registered User
KeNelson03's Avatar
Here is another view
Old 02-23-2003, 12:51 PM   #4120
Boomer's Avatar
Boy is that every pretty!
Old 02-23-2003, 02:31 PM   #4121
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
That is sweet! But, I don't like that it mounts on the bearing support...
pimpedaccord is offline   Reply With Quote
Old 02-23-2003, 03:22 PM   #4122
Hey, does a crease in the hood of a body cause a lot of problems?
Old 02-23-2003, 03:32 PM   #4123
Scrad's Avatar
Trader Rating: 15 (100%+)
probably not. It's not like aerodynamics are a huge part in r/c racing.
Scrad is offline   Reply With Quote
Old 02-23-2003, 05:04 PM   #4124
Jon Kerr's Avatar
aerodynamics play a huge roll in rc racing. Why do you think there are so many Stratus bodies out there. Not because they're pretty. They give the most balanced performance between handling and drag. You need to remember, only one pound of down force on a car that only weighs four and a half pounds or so is alot. It's like adding seven or eight hundred pounds of downforce on a full size race car. I don't know of any full size race car that can claim that.
Old 02-23-2003, 05:08 PM   #4125
Hooked's Avatar
I agree ... it only takes a small amount of downforce on such a small car to make a huge difference.
As far as the crease in the hood goes ... it would depend on how much drag it creates.
Dean
Hooked is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
