Old 02-15-2003, 08:15 AM   #4066
Scrad's Avatar
Trader Rating: 15 (100%+)
Big Al,
I ran the sorex 28s up front with the 24s in the rear with some hpi red inserts and finally the car was hooked up. I also went thicker on the oil 70 front 60 rear and the car was the best it's ever been. So thanks for the info. I finshed 3rd every race last night with it. Now I just need to get my motor refreshed.
Scrad is offline   Reply With Quote
Old 02-15-2003, 08:35 AM   #4067
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally posted by TC racer
I can't find a way to mount my M8 reciver and my GT7 in my TC3 FT. Do you guys have any ideas?
Here's how I've got mine mounted. I thought I'd have trouble with glitching with the power cap there but it's fine.
Jon Kerr is offline   Reply With Quote
Old 02-15-2003, 09:03 AM   #4068
Default diff gear design change?
I bought some replacement diff gears and noticed that the drive pinion is a bit larger than my original kit one, which is 2 years old. The new gear doesn't fit well in the original gear box. Our nitro TC3 gearbox is shaped a little differently on the inside and the drive pinion fits fine in it. Has AE updated its gearboxes and diff gears?
coolrcdad is offline   Reply With Quote
Old 02-15-2003, 10:35 AM   #4069
big al's Avatar
Glad to hear it scrad! I think my next outing I will try out the thicker oils as well. What camber did you end up using? I'll talk to you later--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 02-15-2003, 10:38 AM   #4070
Hooked's Avatar
Default TC3 Diffs
How often would i have to rebuild the diffs in a RTR TC3? as i wouldn't be very good at it i dont think!
I got almost 3 months out of my last rebuild (4 races per week x 12 weeks = 48 races [approx.]) and my last rebuild was just to get them smoother ... they still worked fine.
As for not being very good at it ... use the manual (either from your kit, or get the .pdf from the Associated website) and reuild as per the instructions ... after the first time you probably won't even need to look at the manual.
Hooked is offline   Reply With Quote
Old 02-16-2003, 06:04 PM   #4071
tirbolag's Avatar
Default bump steer
any of you out there that uses the .100 spacer for bump steer...are you still using the lock nut to secure the ball stud? on my set up 0 caster block/2 kick up....i used the .100 spacer for bump steer and the ball stud is too short to use the lock nut.
anyone come across this?
tirbolag is offline   Reply With Quote
Old 02-16-2003, 06:11 PM   #4072
Trixter's Avatar
Default Diff Rebuild
Years ago I bought a diff rebuild tool from RPM and It has been one of the best investments I ever made. It really makes the repuild go smoother and after you are done, you can check the tightness also. I have spent less money and time on diff rebuild and adjustment. Get one it is really worth it.
Rick
Trixter is offline   Reply With Quote
Old 02-16-2003, 07:44 PM   #4073
big al's Avatar
tibolag--
I ran into the same situation,but didn't really consider it a problem. The car definitely was more stable than without the bump steer spacer. I've ran the car with tis paticular set up and didn't have any stripping problems--Al
Old 02-16-2003, 08:33 PM   #4074
Peter Busch's Avatar
R/C Tech Charter Subscriber
check these out.
http://www.rdlogics.com/products.htm
Peter Busch is offline   Reply With Quote
Old 02-16-2003, 11:28 PM   #4075
tirbolag's Avatar
Originally posted by big al
tibolag--
right on big al! thanks for the response. i noticed that yer from san jose...so you must race at castle? been racing there too...hehehjust made the switch to the tc3 from a pro2.
Old 02-17-2003, 05:45 AM   #4076
Trader Rating: 37 (100%+)
Default 1 way diffs...
Just looking for feedback on when people are using a 1 way diff on their TC3s.
open track?
tight track?
ect.
thank.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-17-2003, 11:44 AM   #4077
TigeRyan's Avatar
Send a message via AIM to TigeRyan
I tend to use them on large, open, sweeping tracks....on tight technical tracks I lean towards using a front spool and on intermediate tracks I will use a standard diff....
TigeRyan is offline   Reply With Quote
Old 02-17-2003, 12:02 PM   #4078
Jon Kerr's Avatar
Default Rear toe
Anyone have any opinions on reducing the rear toe angle. I'm running the stock 3 degree and was thinking of going to 2. Is there a way to go as far as 1 degree? Someone mentioned one time that if yo do, there were some other changes you had to make to get everything to align right. Any opinions?
Old 02-17-2003, 12:30 PM   #4079
mike_Webb's Avatar
Send a message via AIM to mike_Webb
For about 1 degree
Use the F block in the rear. Use the R+2+2 block to get about 1 degree of toe in.
or
Use the F block in the rear with .040 spacer under the F block. Then use the R+2+0.
When you do not use the spacer you have to use the 2 Antisquat becuase the F blocks are lower so the 2+2 give it 0 antisquat.
When you use the Spacer the F block in the Rear is at the stock height so use the 0 antisquat block for 0 antisquat.
This was told to me by barry baker.
mike_Webb is offline   Reply With Quote
Old 02-17-2003, 02:18 PM   #4080
less toe in
Why do you see less toe-in as an advantage?
spdyrc is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
