Old 02-13-2003, 01:16 PM   #4051
Peter Busch's Avatar
R/C Tech Charter Subscriber
Is it possible to adust the gear mesh with the upper deck on the stock chassis or do you have to take it off each time?
Peter Busch is offline   Reply With Quote
Old 02-13-2003, 03:59 PM   #4052
Does this mean to keep my TC3 competitive I need a 250 dolaar chassis set?
Is anyone here having success with a stock TC3?
I know I am.
RC Paperboy is offline   Reply With Quote
Old 02-13-2003, 04:05 PM   #4053
Lab-driver's Avatar
I know I am.
Heck No! I do fine with my stock TC3, and I've seen people take first and second in the A main with Racer kits. Don't worry about it!
Lab-driver is offline   Reply With Quote
Old 02-13-2003, 04:18 PM   #4054
Mike D's Avatar
Send a message via Yahoo to Mike D
RC Paperboy - You also don't need a 200 hp car to drive 65 mph on the highway... but people still buy them.
Mike D is offline   Reply With Quote
Old 02-13-2003, 04:46 PM   #4055
No, you do not need to remove the upperdeck to adjust
gear mesh or to remove the motor.
Mr Warpspeed is offline   Reply With Quote
Old 02-13-2003, 05:09 PM   #4056
Thats what I thought
Thanks for the reassurance
Old 02-13-2003, 06:33 PM   #4057
mab_man20's Avatar
Send a message via AIM to mab_man20
Originally posted by Hooked
When you say "relubed the gears" are you lubing the ring and pinion gears?
Im not sure exactly which ring (the spacers??) you are talking about. This is exactly what i did. The cases seem fine.
I lubed all the spacers (on all three outputs front and back) and both the gears in each gear case with the clear associated lube.
I have heard that white lightening from bike shops works well, would that solve the problem or would the gears still make a lot of noise.
Thanks.
mab_man20 is offline   Reply With Quote
Old 02-13-2003, 10:14 PM   #4058
Generally an upper deck will make basically no difference and if the car does flex it doesn't matter greatly anyway. I think an upper deck would be a bad thing in general for the following reasons:
1 Adds weight
2 The weight is up high
3 It will slow down the build, disasaembly process of the car.
4 It will be another cost
cya
ixlr8nz is offline   Reply With Quote
Old 02-14-2003, 01:28 AM   #4059
johnbull's Avatar
Hi Guys. Greetings from Malta.
RC PAPERBOY.
If there is one car that is competitive out of the box, and cheap, it is the TC3. The fact that Associated have not needed to make any major changes in almost 4 years speaks for itself.
You buy some other cars on the market, that already cost twice as much as a TC3 and you have to spend that again to keep them competitive. New, expensive gimicks from the manufacturers each month whose only scope is to line the manufacturers own pockets. They don't really make the cars much faster, as proven by race results.
Yes, the real proof of the pudding is results. Three big races held so far this year - 2 in the states, one in Europe - one winner in all three, the TC3.
There is no doubt in my mind what the best value for money car out of the box is. And I sell them all.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-14-2003, 04:45 AM   #4060
gator's Avatar
Default stock tc3
most hop up parts are really for show (pretty). my plain ft tc3 is winning just like it is.. it just takes some tlc in the car to make it do what you want it to do.... just stay w/ the stock ,except get the graphite kit though. but as for the other aluminum, woven graphite, ect... spend your hard earned money on more important items, like a charger,esc,radio,battery,lathe,tweak station,alignment station, motors....these are the important things to have....
gator is offline   Reply With Quote
Old 02-14-2003, 06:40 AM   #4061
Regional Moderator
Send a message via AIM to Mike F
Default Re: stock tc3
Mike F is offline   Reply With Quote
Old 02-14-2003, 08:14 AM   #4062
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Ok I now have a reason for the upper deck and I will order one from warspeed. I milled the webbing in the front of the chassis so I could install the ntc3 steering assembly now I have a little excess flex.
KINGZJ is offline   Reply With Quote
Old 02-14-2003, 12:49 PM   #4063
rc-zombies's Avatar
Default Losi rear hubs on TC3...
I've noticed that after installing the Losi rear hubs on my TC3 that the upper camber links are on an angle from the shock tower to the hub. I was able to find a solution to make the camber link more parallel with the CVD's. I have the GPM woven graphite shock tower on my car. By installing it in the back of the mounts..the camber link is now even with the CVD's. I did the same for the front links as well, but moved it forward. Haven't seen any difference in performance after the change ..alignement just looks more correct. you can see what I've done at:
http://groups.msn.com/RCZOMBIES/tc3.msnw?Page=2
Old 02-14-2003, 01:00 PM   #4064
Mike D's Avatar
rc-zombies - Nice looking car! The camber link angles do look better. Good work.
Old 02-15-2003, 04:20 AM   #4065
How often would i have to rebuild the diffs in a RTR TC3? as i wouldn't be very good at it i dont think! I race an HPI Sprint at the moment but the diffs dont need any mantinence because there sealed
Martsie 89 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
