Old 02-11-2003, 06:39 PM   #4021
would you happen to know the # for the bushings instead of the bearings by any chance? thanks
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 02-11-2003, 07:00 PM   #4022
theisgroup's Avatar
i am not sure there are bushings for the steel diffs. from my original tc3 manual with the steel diffs. it shows bearings not bushings for the diff
theisgroup is offline   Reply With Quote
Old 02-11-2003, 07:24 PM   #4023
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Bearings go in the Steel Diff's. Bearings go in the IRS Aluminum Diff. Bushings go into the Plastic Diffs.. Don't do like I did at snowbirds and put Bearings in Plastic Diff... it will melt.
3907 is the part number for the bushings
mike_Webb is offline   Reply With Quote
Old 02-11-2003, 07:42 PM   #4024
ok thanks, i built a spool from a set of steel outdrives and used the bushings and everything fit fine, i just need to have the diff to run mod this weekend after the weekend is over i will invest in some bearings for them but i may only be able to get the bushings for now. thanks for the info.
Old 02-11-2003, 07:48 PM   #4025
theisgroup's Avatar
hey mike_webb
associated has bearings for the plastic diff. part numb#3916. these are not as thick as the 6909
Old 02-11-2003, 08:01 PM   #4026
mike_Webb's Avatar
Theisgroup-
I heard about them but a person at my local track tried them and they say that the bushings work better in the plastic diff.
I thought the Bearings would work in the plastic diff for just 1 stock class run but they did not . Big mistake..cost me a really good run. unfortunatly the hobbyshop at the race was not open at the time so I could not buy the bushings.
Old 02-12-2003, 12:39 AM   #4027
johnbull's Avatar
Hi guys. Greetings from Malta.
DIFF BEARINGS.
I have always fitted the narrower bearings on TC3 plastic diffs without problems.
I don't think they are really necessary - the plain bushings will work perfectly well, but once we have the bearings we use them.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-12-2003, 01:32 PM   #4028
Default WARPSPEED Upperdeck
Here is a pic of the WARPSPEED upperdeck on the TC3 chassis.
Mr Warpspeed is offline   Reply With Quote
Old 02-12-2003, 01:33 PM   #4029
Here is another angle of the WARPSPEED Upperdeck.
Old 02-12-2003, 01:33 PM   #4030
Here is another.
Old 02-12-2003, 03:53 PM   #4031
Mike D's Avatar
Send a message via Yahoo to Mike D
Warpspeed - How thick is the graphite on your chassis and upper deck?
Mike D is offline   Reply With Quote
Old 02-12-2003, 05:05 PM   #4032
Default WARPSPEED RACING
The graphite is 3mm thick on the chassis and upperdeck.
Old 02-12-2003, 05:27 PM   #4033
Default steel cvds
Does anyone make steel CVDs for the TC3?
coolrcdad is offline   Reply With Quote
Old 02-12-2003, 05:35 PM   #4034
Mike D's Avatar
MIP has steel CVD's for the TC3. The IRS oversized aluminum bones are stronger - I've run both.
Old 02-12-2003, 08:36 PM   #4035
Send a message via AIM to AssociatedRacer
Hey, Why would the tc3 need to be "stiffer". It is already stiff, why would you need a upperdeck?
AssociatedRacer is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
