Like Tree4Likes
Old 02-10-2003, 07:17 PM   #4006
robk's Avatar
Trader Rating: 22 (100%+)
Mr Warpspeed : is the 12l chassis available?
Old 02-10-2003, 07:22 PM   #4007
Default WARPSPEED 12
The 12 scale is not available yet. We are working on it.
Hopefully, by next month, we are still testing.
Mr Warpspeed is offline   Reply With Quote
Old 02-10-2003, 08:31 PM   #4008
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I guess I don't understand why the warspeed chassis is the way to go. Why is it so much better? What is wrong with the original chassis? Basically why should I spend so much money on a allready good car. I am not trying to be a DI-K I am just curious.
KINGZJ is offline   Reply With Quote
Old 02-10-2003, 08:44 PM   #4009
The WARPSPEED CHASSIS is a graphite chassis. It will not warp
under heat, like the molded chassis. The heat from the motor and
batteries will warp the molded chassis. My chassis is perfectly
balanced. It comes with an upperdeck, which makes the chassis
super stiff. Associated does make an excellent car. We have
made a conversion kit to convert your TC3 into a
WARPSPEED DEMON. The car handles awesome with these
new features. It comes with the swing rack holes and also
the batteries are moved in closer to the drive shaft.
Old 02-10-2003, 09:00 PM   #4010
Do you have a chassis that has the orig battery position, ie on the left?
elnitro is offline   Reply With Quote
Old 02-11-2003, 01:43 AM   #4011
Glue-Stick's Avatar
Hi Jack Smash amd Dingus -
Nah i'm not selling them, it's just a one-off thing for my self!! but it's really not that hard to make a top deck. Mine was laser cut with the rest of the main chasis etc, but it would not be very hard to hand cut it with a dremel or whatever.
Glue-Stick is offline   Reply With Quote
Old 02-11-2003, 03:16 AM   #4012
Default WARPSPEED RACING
NO, WE DO NOT HAVE A CHASSIS WITH THE ORIGINAL
BATTERY POSITION.
Old 02-11-2003, 06:16 AM   #4013
theisgroup's Avatar
Default warpspeed demon
Did I hear that the battery position is also centered? What I mean is the original factory chassis has a front and back position. I have heard that the demon has the battery position inbetween the two locations.
theisgroup is offline   Reply With Quote
Old 02-11-2003, 07:24 AM   #4014
rayhuang's Avatar
Default Warpspeed chassis
Theisgroup-yup-they centered the batteries somewhere between fully back and fully forward. I am sure its feels like a split pack-3 forward, 3 back.
Old 02-11-2003, 11:26 AM   #4015
Default WARPSPEED DEMON
The batteries are centered on the WARPSPEED DEMON for
better weight distribution.
Old 02-11-2003, 12:16 PM   #4016
CSF0623's Avatar
Does the battery mod (cut out on the ctr brace) on the chassis throw off the tweak ie weight distribution?
CSF0623 is offline   Reply With Quote
Old 02-11-2003, 12:30 PM   #4017
theisgroup's Avatar
I think you are looking at 2 different thing. moving the battery will never get rid of the "tweek" in your chassis. It may compensate for it. But to what extent? Moving the battery more center (front/back) helps with weight distribution. It seems that many have found that the batteries all the way forward give too much weight to the front and batteries all the way back takes away too much weight from the front. So this will help weight distribution and ultimately weight transfer(front/back). I think moving the batteries more inboard help reduce the weight difference between the 2 sides of the car. with more mass further from the center point, the more the mass affects the car. so the batteries more inboard just help ballance right to left.
But tweek is tweek and moving the batteries does not change that.
Old 02-11-2003, 04:35 PM   #4018
does anyone know the part # for the inner bushings for aluminum outdrives. i know there is 2 different sizes, one for plastic and one for aluminum just not sure the #s.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 02-11-2003, 04:52 PM   #4019
theisgroup's Avatar
part number is 6909 for the bearings for the steel diff. And if you are using the irs alum. ones, then you would use the same ones.
Old 02-11-2003, 06:35 PM   #4020
i am using the hardcore aluminum ones, so 6909 is what i need? thanks
[email protected]
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
