Old 02-08-2003, 09:09 AM   #3976
Dingus's Avatar
I tried to use the F block in the rear, but the holes didn't line up. The F block was too narrow for the drop in holes in the rear bumper, so I had to mill the inside of the posts on the F block to get it to drop in. I felt that I couldn't get them lined up properly and still have even toe from left to right. It was much easier to to use the R+2 block and the Losi 1 deg hubs reversed. Plus, I think my stock hubs weren't quite straight either.
Dingus is offline   Reply With Quote
Old 02-08-2003, 01:02 PM   #3977
Send a message via AIM to lilshortyc3
So wut block did u use when the F block did not fit?
lilshortyc3 is offline   Reply With Quote
Old 02-08-2003, 01:08 PM   #3978
Dingus's Avatar
R+2+2 with the Losi rear hubs
Old 02-08-2003, 01:10 PM   #3979
wut wuz the other block u used other than the R-2-2 in the back?
Old 02-08-2003, 01:12 PM   #3980
Dingus's Avatar
Sent you a PM
Old 02-08-2003, 01:20 PM   #3981
check ur PM
Old 02-08-2003, 01:57 PM   #3982
jsp
Dingus: The "F" block goes in front of the rear transmission. It does not go behind the transmission with the bumper. The combination of "F" and "R 2 + 2" gives you about 1 deg. toe-in and 2 deg anti-squat.
jsp is offline   Reply With Quote
Old 02-08-2003, 02:01 PM   #3983
Dingus's Avatar
Guess that's why it didn't work for the rear. The one I milled was for the front of the car. I really like the setup I have now though. The Losi rear hubs allow for more camber link adjustments (2) and a vertical ballstud.
Old 02-08-2003, 11:17 PM   #3984
shrekair's Avatar
Trader Rating: 9 (91%+)
An F block in the rear w/ 2+2 gives you 0* anti squat and 0* rear toe. If you run a 2+0 you will have pro-squat which will take away even more rear traction, and it wont be as consistent upon acceleration. pro-squat would work best w/ foam on carpet but not recomended for other situations. you can also get pro-squat in the front by shimming the F-block.
shrekair is offline   Reply With Quote
Old 02-09-2003, 06:02 AM   #3985
how about the F and the R-3-0 in the back with Losi hubs?
Old 02-09-2003, 08:24 AM   #3986
Jack Smash's Avatar
Trader Rating: 29 (100%+)
2 degrees toe in with about 2 degrees pro squat.
I really liked the losi hubs on the back when I ran the NW carpet champs in stockton. They seemed to keep the car from parking in the middle of the corner.
Jack Smash is offline   Reply With Quote
Old 02-09-2003, 09:30 AM   #3987
jsp
I forgot to mention you need a .030-.035 spacer under the "F" block to maintain the proper anti-squat.
Old 02-09-2003, 04:27 PM   #3988
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default which one?
which is the best for carpet racing...the Evo2, Graphite XXX-s , or the FT TC3??????????
rdub202 is offline   Reply With Quote
Old 02-09-2003, 05:07 PM   #3989
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Being a diehard Associated fan.... I have to say the FT TC3. But since I have only one opinion, I'll probably hear from the rest of the nuts out there.
Flash Gordan is offline   Reply With Quote
Old 02-09-2003, 06:06 PM   #3990
rdub202's Avatar
Default lol
lol ok thx (kinda)
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
