Old 02-07-2003, 09:02 AM   #3961
rayhuang's Avatar
SORRY TC3 guys for cluddering up Our TC3 thread!!! Sometimes you gotta ask a question while youve got a guys attention though!!!
Rc-zombies-I'll look for it and e-mail you from my yahoo account so i dont take up anymore TC3 space!!!
Old 02-07-2003, 09:13 AM   #3962
TC3
TC3's Avatar
Originally posted by TC3
should i get the trinity or irs lowprof locknuts?
is 3076 the right part number for the trinity ones?
has anyone the new new asso polished hingpins?
i have the yokomo ones and they are very strong and i have a very smooth suspension now, but they are alittle too short, just about 1 or 2mm. i was wondering wether i should try the new asso ones..
or maybe they are both the same, just as the new heavyduty oneway ist the same as the yok one, i heard
no answer?
TC3 is offline   Reply With Quote
Old 02-07-2003, 09:44 AM   #3963
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The 3076 should be the right part number. At least it has the right description.
I have not seen the polished hinge pins for the TC3. To be honest, I forgot about them. A lot of people have purchased the BRP kit. Most have polished them up.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-07-2003, 12:30 PM   #3964
Question for all you drivetrain experts. My drivetrain seems to roll more free if I leave the screws holding the bearing cap (in front of teh spur) loose. Is this an indication of a tweaked chassis?
todddd41 is offline   Reply With Quote
Old 02-07-2003, 12:40 PM   #3965
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
No, it's just when you squash a bearing, it won't rotate as free. Just snug up the screws, don't put any muscle into it. Same with the diff cases.
pimpedaccord is offline   Reply With Quote
Old 02-07-2003, 02:26 PM   #3966
Jack Smash's Avatar
Trader Rating: 29 (100%+)
If you relieve the edges of the bearing holes you can tighten up the bearing cap and the diff cases and yet still have a free rolling tranny. Makes a huge difference in rolling resistance. ALso gear mesh is absolutely critical.
Jack Smash is offline   Reply With Quote
Old 02-07-2003, 04:14 PM   #3967
Send a message via AIM to lilshortyc3
When you use the F, R-3-0 and the Losi hubs on the back of the TC3, where do you put the F block, and the R-3-0 block? And wut Losi hubs do you use, is it for the Losi XXX-S?
lilshortyc3 is offline   Reply With Quote
Old 02-07-2003, 04:54 PM   #3968
Dingus's Avatar
I tried the F Block, but it needed too much precise milling to get it to sit even from left to right. It didn't pop right in like a direct replacement.
Currently, I have the R+2+2 block with Losi XXX-S hubs (1 deg) installed backward to get 1 deg per wheel of rear toe in.
I also had to run the car short because the Losi hub uses a vertical ballstud and that creates an angle with the camber links.
Dingus is offline   Reply With Quote
Old 02-07-2003, 04:58 PM   #3969
When you say backwards, is it upside down, or did you put the left one on the the right one? And wut wuz the other block u used besides the R-2-2 block?
Old 02-07-2003, 05:17 PM   #3970
TurnNBurn's Avatar
Does AE have the new FT shaft on the website yet? I went to the site last night, but couldn't find it... It wasn't listed with the other FT parts either.
TurnNBurn is offline   Reply With Quote
Old 02-07-2003, 07:12 PM   #3971
Dingus's Avatar
Installed the hubs reversed from left to right. No way to mount them upside down.
I got the new shaft from Stormer for $6.25
Old 02-07-2003, 07:35 PM   #3972
How much? do you have pictures?
Racin Rev is offline   Reply With Quote
Old 02-08-2003, 05:17 AM   #3973
you will just have to take out a little at a time and refit and check the freeness of the bearing.
for the diff cases just take out some of the side wall where the bearing site and then put the diff back in the case and if it falls out just by turning it upside down then your set. do this for top and bottom halfs of the case.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 02-08-2003, 05:26 AM   #3974
Wut wuz the other block u used with the R-2-2? Is it the one that was already there?
Old 02-08-2003, 08:57 AM   #3975
Dingus:
Hi,
you should try the front "F" block. ( the one the goes behind the transmission case) in place of the "R" block in the rear. you will need to shim it up about .030" ( I use the motor screw washers and cut some off so it will line up with the holes). I run the R+2+0 block in the rear . I haven't tried the Losi rear hub carriers yet....... Losi parts are hard to come by where I live.
Fakk2 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
