Old 02-04-2003, 03:18 PM   #3916
big al's Avatar
Hey scrad, give this set up a try next time. It's almost identical to yours.
Front
rear shock tower up front
blue springs
50 wt (trinity)
middle hole in shock tower
outer hole in ver.2 arms
1.5 degrees camber
one way
sorex 28's w/hpi green insert
rear
outer hole on shock tower
silver springs
40wt. (trinity)outer hole on shock tower
1.5 degrees camber
Stock hole on rear arm
Sorex 24's w/hpi green insert
If you find that car wants to traction roll try camber at 2 and then 2.5 degrees. almost all the tc3 drivers use this basic set up out here on our carpet track. Oil weights range from 50/40 to 70/60. Strangely enough,this set up also works well on low traction outdoor tracks. I'm assuming you're running stock class!! good luck--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 02-04-2003, 03:22 PM   #3917
big al's Avatar
Almost forgot....f+2 and r+3+2,short wheelbase,long links,batts at rear!!
Old 02-04-2003, 04:44 PM   #3918
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by Scrad
If I run heavier oil then it would hook up worse correct. You want lighter oil and springs to make the car hook up. It could be rolling too much though... My droop is the same as when you build the car.
Anyone run the Sorex 24s on carpet?
If I can try to analyze the problem just a touch -
With weight transferring forward (braking) you're fine.
With weight transferring back (off brakes and on throttle) you're oversteering.
It may be that you're transferring weight to the rear faster than your tires and suspension can handle, thus breaking you loose.
Try putting a bit thicker oil in the rear. Oil only controls the SPEED of weight transfer, the springs control the amount, so if you want to slow the weight transfer down a touch, thicken the oil and you shouldn't transfer weight back so quickly and you should, hopefully, get a bit more control back there.
Tell me if my reasoning sounds, ummm, reasonable!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-04-2003, 04:45 PM   #3919
Send a message via AIM to AssocaitedRacer
Originally posted by rc-zombies
Have you guys seen the new drive shaft from Yokomo for the TC3? Combination graphite and aluminum... best of both worlds.
Wasn't the original shaft CF?
Aww cr@p i spelled my name wrong...
AssocaitedRacer is offline   Reply With Quote
Old 02-04-2003, 04:53 PM   #3920
Dingus's Avatar
I just got the replacement Associated shaft for $6.25. It sure seems lighter than the original graphite shaft...and prettier too.
Dingus is offline   Reply With Quote
Old 02-04-2003, 04:57 PM   #3921
Thats weird that aluminum would be lighter then Graphite.
Old 02-04-2003, 05:22 PM   #3922
Scrad's Avatar
Trader Rating: 15 (100%+)
Big Al
I'll give it a try. It can't hurt to try it and I can always go back. You run 24's in the rear and 28's in front? Thats kinda weird, but if it works. Its also close to what I have so that will be fine to change. What caster do you use?
Thanks for the replies guys.
Scrad is offline   Reply With Quote
Old 02-04-2003, 05:41 PM   #3923
The new AE shaft is definitely prettier and definitely more straight. However, the graphite weighs 6 grams while the new aluminum one weights 10 grams. So the new one is heavier, but not by very much.
Shiloh is offline   Reply With Quote
Old 02-04-2003, 06:14 PM   #3924
big al's Avatar
Hey scrad, I just use the f+2 mount and 0 deg. castor blocks. let me know how it goes. maybe we can find a really good set up. I'm gonna try and get to the track this weekend and try a few tweaks--Al
Old 02-04-2003, 06:49 PM   #3925
Scrad's Avatar
Ok I have the f+0 block with 4 caster block. I'm going to try that first. Because I don't want change it just yet. Plus carpet is smooth and I like the aggressive steering that it gives. Do you run a shim under the ball stud? I won't get to the track for 2 weeks. We have some friends visiting from out of state and I plan on going snowboarding. But let me know how your tweaking goes.
Old 02-04-2003, 06:57 PM   #3926
Peter Busch's Avatar
Whatever became of running the nitro TC3 conversion, is it worth doing?
Peter Busch is offline   Reply With Quote
Old 02-04-2003, 09:08 PM   #3927
Default WARPSPEED RACING
We are trying to send some pics of the WARPSPEED CHASSIS,
if they do not go thru just email me at
warpspeedracing@aol.com I will send you some pics.
Mr Warpspeed is offline   Reply With Quote
Old 02-04-2003, 09:21 PM   #3928
Pics are too large to send. I will try tomorrow.
Old 02-06-2003, 09:00 AM   #3929
Default WARPSPEED DEMON
Here is the pic of the DEMON!!!
Old 02-06-2003, 09:05 AM   #3930
Here is another pic!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
