Old 02-03-2003, 07:50 PM   #3901
Send a message via AIM to AssocaitedRacer
I believe its K factory.
http://www.kfactoryracing.com/main.htm
AssocaitedRacer is offline   Reply With Quote
Old 02-03-2003, 08:06 PM   #3902
Northerner's Avatar
Send a message via ICQ to Northerner
the only thing i know about it its from K.Models in Japan i think?
Northerner is offline   Reply With Quote
Old 02-03-2003, 09:31 PM   #3903
lem2's Avatar
Default K. Models RACING Factory
yep and its only exclusively sold in JAPAN!!! Its not even sold at Hobby SHOPS!!! They make aftermarket parts for Tamiya, Yokomo, HPI and recently TC3!!!
Hope TEAM PRP will come up with the upper deck soon for the TC3, I heard from previous post that he is developing an upper deck!!!!
TEAM PRP: Ben when will be the upper deck be out for the TC3?
Here is the correct Website for K.Models Factory Racing, sorry its in Japanese only, I tried using ALTA VISTA but still could not understand. Enjoy the view
http://www2u.biglobe.ne.jp/~kmodels/tc3parts.htm#hitora
lem2 is offline   Reply With Quote
Old 02-04-2003, 08:41 AM   #3904
Peter Busch's Avatar
R/C Tech Charter Subscriber
That sucks. It looks pretty simple to make. I'll have to "encourage" Ben to make one next time I see him.
Peter Busch is offline   Reply With Quote
Old 02-04-2003, 08:43 AM   #3905
Whats the latest on the Warpspeed chassie? Pictures would be nice.
Old 02-04-2003, 11:07 AM   #3906
Smile Shims under rear shock tower
Hello all you TC3 mad heads
Could anyone please tell me why some of the team drivers are putting shims under the rear shock tower and what efect this has on the car?
Many thanks
simo is offline   Reply With Quote
Old 02-04-2003, 11:18 AM   #3907
Mike D's Avatar
Send a message via Yahoo to Mike D
Placing shims under the rear tower will raise the camber link mount holes. Raising (and lengthening) the camber link mount location on the rear tower will increase rear traction but reduce side-to-side stability.
If you raise the rear arm mounts equal with the rear tower, you will keep the standard camber gain properties of the stock suspension geometry but raise the rear roll center. It's hard to determine the purpose without knowing any other modifications to the rear suspension.
Mike D is offline   Reply With Quote
Old 02-04-2003, 11:23 AM   #3908
Thumbs up Mike D
Thanks for the quick reply all i know is that they are just putting between 1 & 2mm spacers under the rear tower with no other mods.
Old 02-04-2003, 12:37 PM   #3909
Scrad's Avatar
Trader Rating: 15 (100%+)
Need a little help. I need more rear end traction. I'm running on Carpet. I'm pretty much running Bakers setup out of the magazine. Rear tower on front, spool and all of that. The front end hooks up great, but the rear end want to slide around in the middle and exits of the turns when I get back on the throttle. Any thoughts of suggestions will get greatly appreciated. Thanks.
Setup
Front
Blue springs40 weight
Top middle hole
bottom arm out side
camber links long
F-0 plate or Block
Rear
Silver
35 weight
Top inner
bottom out (old arm) one hole
links long
short wheelbase
R+3+2 plate
Batt rear, Take Off 27 tires
The only thing I can think of doing is going to the green spring in the rear or trying some Sorex28 tires with green and red inserts.
A softer insert would help rear traction correct?
I'm at my whits end with this thing. I can't really do anything else to make the car hook up in the rear that I haven't already tried. It sucks because my car isn't the fastest, but I'm mostly finishing 4th or 5th. If I could get the car to hook up better in the rear I could win some races.
Scrad is offline   Reply With Quote
Old 02-04-2003, 12:59 PM   #3910
try adding 1mm of droop to the front end and/or lower rear roll center.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 02-04-2003, 01:02 PM   #3911
Jack Smash's Avatar
Trader Rating: 29 (100%+)
It seems like you are way too light on oil and springs for carpet.
Try 60 wieght with #3 pistons and copper springs in front and 40 weight with #3 pistons and red or gold springs on the rear.
Jack Smash is offline   Reply With Quote
Old 02-04-2003, 01:26 PM   #3912
rc-zombies's Avatar
Have you guys seen the new drive shaft from Yokomo for the TC3? Combination graphite and aluminum... best of both worlds.
Old 02-04-2003, 01:54 PM   #3913
he is running rubbers on carpet, although im not at all experienced with rubbers on carpet but it seems like most guys like lighter oil with running those.
rc zombies do you have a part # and a place you can order from, i want one!!
Old 02-04-2003, 01:57 PM   #3914
rc-zombies's Avatar
found it on RainbowTen..won't be available til feb. but can be pre-ordered...don't know when it will reach the states if ever.
SP-3924 TC3 CARBON CENTER SHAFT 2800YEN (approx. $24.00usd.)
http://www.rainbowten.co.jp/english/index.html
Old 02-04-2003, 03:04 PM   #3915
Scrad's Avatar
If I run heavier oil then it would hook up worse correct. You want lighter oil and springs to make the car hook up. It could be rolling too much though... My droop is the same as when you build the car.
Anyone run the Sorex 24s on carpet?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
