Old 01-31-2003, 12:10 PM   #3871
Northerner's Avatar
Send a message via ICQ to Northerner
or just use the Niftech dog bones, they have flat swivel drive pins, instead of the round pins
Northerner is offline   Reply With Quote
Old 01-31-2003, 12:12 PM   #3872
Mike D's Avatar
Send a message via Yahoo to Mike D
Don't those niftech swivel pins cost alot? $$$
Mike D is offline   Reply With Quote
Old 01-31-2003, 01:54 PM   #3873
rayhuang's Avatar
NIftech-good stuff-but you wont find anything more expensive!! Except his diff balls and-beleive it or not his CVD's. They really arent anymore than the Ti Racing or any other high end make!!!
What ever happend to the carbon fiber TC3 chassis that was being talked about a few weeks ago. Is it still a go?
Ray
Old 01-31-2003, 02:19 PM   #3874
theisgroup's Avatar
Default Carbon fiber tc3
If you are talking about the warpspeed one, here is the info I got from them yesterday.
The WARPSPEED DEMON retails for $250.00 US Dollars, and street cost is about
$190.00 US Dollars. The kit includes chassis, upper plate, stand-offs, battery
brace and motor mounts.
The chassis was released about a week ago. We are sold out. Next batch should
be sometime in February. We are taking pre-orders at this time.
If you would like to place an order, please email me.
Here is a new picture.
Victor
Owner of WARPSPEED RACING
When you're ready to get serious!
theisgroup is offline   Reply With Quote
Old 01-31-2003, 06:16 PM   #3875
driftmaster's Avatar
North: pretty trick, do you know how much they cost?
driftmaster is offline   Reply With Quote
Old 02-01-2003, 04:03 PM   #3876
robk's Avatar
Trader Rating: 22 (100%+)
ok i sketched this picture in about 2 minutes but maybe it will make the idea clearer. i guess it's an insert for the notch in the outdrive
Old 02-01-2003, 04:09 PM   #3877
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Thats a good idea rob.
KINGZJ is offline   Reply With Quote
Old 02-01-2003, 07:46 PM   #3878
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
it's a very good idea.
It would breath some life into somewhat old outdrives. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-02-2003, 10:42 AM   #3879
Northerner's Avatar
the pre-assembled niftech cvd's cost $40 pair, but if you think of how much longer the outdrives will last, it should be cost effective in the long run?
and the complete shaft assembly
Includes:
1. 2 drive shafts
2. 2 axles
3. 2 aluminum lock nuts
4. 2 crush sleeves
5. 2 spirol&tm; roll pins
6. 2 couplers
7. 6 axle shims
** SWD vesrions come pre-assembled with Niftech's #2350-SWD Precision Swiveling Flat Drive Pin Assembly for Dog Bone Axles. Helps prevent damage to aluminum outdrives.
Complete CV Assembly for Associated TC3 Sedan with SWD Ends Installed (#2308-SWD)
$69.95 / pr
or get two sets of just the swivel ends for do-it-yourself installation at $20
check out all of Niftechs products
Old 02-02-2003, 12:25 PM   #3880
lem2's Avatar
Default Pin Cushions!
Hello and Greetings form Manila,Philippines!
YOu could make custom pin cushions yourself, I did!
Use the plastic tubing of your regular "BIC" ballpen heat the end part (a bit) and insert on the PIN then cut! Just be sure there is no more ink or it will be messy!!! hehehehehe
YOu could also place a little CA and you may have to trim the plastic tubing a little! (but that's fun to do!)
doing it won't cost your $2.
Peace to all men!!!!
lem2 is offline   Reply With Quote
Old 02-02-2003, 12:45 PM   #3881
Default Warpspeed carbon fiber chassis
How is this different from the one made by IRS, better materials? Thicker? I is true that the batteries on the right side (like TB Evo II)?
elnitro is offline   Reply With Quote
Old 02-02-2003, 03:21 PM   #3882
Peter Busch's Avatar
I heard the Niftech ones are not that good because the pins snap off. Just spend the $4.00 and get the IRS pin cusions, problem solved.
Peter Busch is offline   Reply With Quote
Old 02-02-2003, 06:03 PM   #3883
Default fried motor
Hey guys i got the tc3 rtr and i fried my stock motor today. I think its because i have a gp 3300 batt pack in it. With the stock esc i cannot use a modified motor in it. Is there a stock 17 to 19 motor out there i can use with this batt pack?
bbmfkp is offline   Reply With Quote
Old 02-02-2003, 06:07 PM   #3884
Dingus's Avatar
It probably was not the pack in and of itself. With a higher capacity batt, you tend to drive longer than 5 minutes because you can. Stock motors are not designed to run for much longer than 5 minutes. Their advanced timing and a lack of bearings makes them run quite hot.
If your intention is not racing (you didn't indicate), maybe try a 19t chameleon. Even then, you have to be careful of the motor's temp.
Dingus is offline   Reply With Quote
Old 02-02-2003, 08:15 PM   #3885
have any of you guys heard of having your diff and pinion gears machined to match perfectly? a guy at my lhs was talking to a guy that said some of the factory guys have had their diff and pinions machined to match perfectly, he said they had a fan blowing on the car from 15 ft away and the drivtrain was slightly spinning. sounds nice!
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
