Old 01-27-2003, 04:53 PM   #3841
driftmaster's Avatar
I ran my TC3 for the first time sense I milled the chassis and did the battery mod. I have to say it made transitions much better. It turned the same left as it did right. on the scales it balance out side to side perfect 13 oz's on each back tire and 11 oz's on each front tire. I think I got the most added performance
out of the battery mod than any other mod I have done. If you have not done it I would highly recommend it.
As for the spool made out of delrin it broke an ear of the first time I nicked the wall. Carpet plus foam's plus 2 by 4's plus tight track = a lot of broke cars. We are going to make the spool's out of aluminum and try that. I ran the Robinson aluminum diff after breaking the delrin and it does not give any. It transferred the force to the bottom of the front hub and broke
at the screw. The plastic diff seamed to be the best for me on that track. If you hit the boards hard it would just push the dog bone out without breaking any thing, I liked that a lot better.
driftmaster is offline   Reply With Quote
Old 01-27-2003, 10:33 PM   #3842
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Driftmaster, I've been using the IRS spool since it came out (Dave Irrgang is local to South Jersey so he brought the first batch to the track for us to buy....gotta love it...) and have had ZERO problems with it and I have run it both inside and outside, with some nasty hits....I know the IRS is probably the highest price, but it is well worth it in quality....
TigeRyan is offline   Reply With Quote
Old 01-28-2003, 07:55 AM   #3843
NTC3NUT's Avatar
driftmaster, YGPM
NTC3NUT is offline   Reply With Quote
Old 01-28-2003, 10:20 AM   #3844
Northerner's Avatar
Send a message via ICQ to Northerner
i was curious what is the best way to initially scale a car? take the shocks off and then add weight to chassis to get it fairly equal on all four corners?
then reinstall the shocks and fine tune with the shock collars (for threaded shocks)
what is a good bias to have? 50/50? 40/60? etc...
Northerner is offline   Reply With Quote
Old 01-28-2003, 12:07 PM   #3845
Smile FTTC3 Balance
I just made one thing to change the balance. I scaled my batterys and here it come:
SMH3000 360g
HV3000 370g
GP3300 390g
I desided to use my TC`s extra weight with my HUDY`s center chassis weight ( i used two of them normally in my T1 ). I drill two holes (almoust center of the chassis) near to my LRP V7.1 esc to right side of chassis.
Put that bigger 20g weight inside chassis and smaller one 10g outside chassis and tight them with two scruw, and thats it. They are wery tight and i don`t think they fall off easily.
Rest of them (20g) are locedid rear, motors side block, so now balance is near wright (or better when use HV`s or SMH`s) when i use those GP3300 how are heavier than others.
I look Juho`s set-up when he drove last DHI-cup and he put 50g extra when he drove GP batterys. I made it that way because i use piece of lexan top of the servo ( transponder is safety place than outside chassis) and can`t put leads on the top of servo wright now, but maybe that is better....i think
Btw: My tweak tell the same - it`s ok now
Proto pilot is offline   Reply With Quote
Old 01-28-2003, 01:43 PM   #3846
Lightbulb
I am attempting to degrese my bearings. What do you guys use to do this? and what, if anything do you use to relube them? I am thinking about graphite but would be open to suggestions.
Racin Rev is offline   Reply With Quote
Old 01-28-2003, 01:58 PM   #3847
Hey North,
What I do keeps me in the ball park I know its not right on, but its close.I went to office supply store and bought 4 16oz postage scales, $5 apiece. Get your car RTR and place a scale under the center of each tire. Lift the car up and down a couple of times to make sure its reading right. Check your scales also, zero them in. Like you said use the collars to fine tune. I like 40% on the front and 60% on the rear.
Old 01-28-2003, 02:01 PM   #3848
I use nitro fuel. It lubes and cleans at thr same time.
Just dont smoke, lol.
Old 01-28-2003, 02:01 PM   #3849
when i clean the bearings in my car i remove both seals then put 4 or 5 of them in a small tube filled with motor spray and seal then shake for a few minutes then rinse and repeat then spray each individually with motor spray and blow out w/ compressed air and lube with trinity royal oil. and replace seal ( i only run outer seal on hub and diff bearings)
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 01-28-2003, 02:06 PM   #3850
Thanx for the info,
Making some out of alum tonight. The only thing is I feel like
it will wear faster. It will be better then breaking.
Old 01-28-2003, 02:12 PM   #3851
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Wink Solid front diff's
Originally posted by driftmaster
Thanx for the info,
while your at it try to make some aluminum ones for the 'Cuda'
Thanks'
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-28-2003, 02:18 PM   #3852
rc-zombies's Avatar
Thanx for the info,
to lessen the wear...use the IRS CVD outdrive pins. works great!
Old 01-29-2003, 12:20 PM   #3853
yodace's Avatar
how often should a person clean their bearings? How many runs?
yodace is offline   Reply With Quote
Old 01-29-2003, 12:21 PM   #3854
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I clean mine after every day at the track..
mike_Webb is offline   Reply With Quote
Old 01-29-2003, 12:35 PM   #3855
TigeRyan's Avatar
Mike,
I've seen many ways people clean their bearings...do you or anyone else want to give a step-by-step how-to on this, I am still pretty new (about a year + half into racint) and I am not sure if I am doing it right...
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
