Old 01-24-2003, 09:22 AM   #3811
And this is the new location for the upper turnbuckles.
Michael
siebenelch is offline   Reply With Quote
Old 01-24-2003, 10:13 AM   #3812
omalley's Avatar
Send a message via AIM to omalley
where did you get those sweet looking ball cups for your turnbuckles?
omalley is offline   Reply With Quote
Old 01-24-2003, 11:15 AM   #3813
Peter Busch's Avatar
R/C Tech Charter Subscriber
Whats the purpose of relocating the rear turnbuckles?
Peter Busch is offline   Reply With Quote
Old 01-24-2003, 01:23 PM   #3814
robk's Avatar
Trader Rating: 22 (100%+)
I saw the AE team drivers at the Carpet Nationals in Maryland do something very similar. They came out of the middle trans cover hole instead. Basically you are moving the upper link more horizontal, which reduces camber change, in fact it can be positive at times. It also lowers the roll center. They were doing this since the track 's carpet was pretty worn out. Maybe someone else can give a better explaination. Also check out this thread w/ Walter Henderson of team AE
http://www.hobbytalk.com/bbs1/showth...&pagenumber=24
Old 01-24-2003, 02:54 PM   #3815
Regional Moderator
Send a message via AIM to Mike F
siebenelch - awesome looking car. Is that chassis manufactured or did you have someone mill it out for you
Mike F is offline   Reply With Quote
Old 01-24-2003, 03:24 PM   #3816
Good morning!
Yes, the reason of the relocation is correctly answered. And itīs better, easier and faster to adjust the car.
The chassis had a heavy contact with my Dremel. Itīs really hand-worked.
The ballcups are from HPI.
Greetings
Michael
Old 01-24-2003, 04:18 PM   #3817
Regional Moderator
I went onto the website, pretty cool. I did not see any set ups listed, maybe they were there but I don't read German. Can you help?
Old 01-25-2003, 03:11 AM   #3818
snoopy's Avatar
Siebenelch,
Great work on your car.
It's like sweet sweet candy!!!!!
snoopy is offline   Reply With Quote
Old 01-25-2003, 01:46 PM   #3819
Send a message via AIM to lilshortyc3
Talking
I have a little problem wit my car, when I drive my car, I feel like the car has too much steering. Like if I turn the steering wheel a little bit, I get more of a turn than expected. I have blue in da front and silver in back. My ride height is at 5mm and 5.5mm back. Thx!!!
lilshortyc3 is offline   Reply With Quote
Old 01-25-2003, 02:07 PM   #3820
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Adjust your dual rate for the steering problem. Easiest Fix.
mike_Webb is offline   Reply With Quote
Old 01-25-2003, 06:50 PM   #3821
stormperson's Avatar
Send a message via AIM to stormperson
I dremeled out my chassis to move the batts closer as alot of people have done, however i have a few questions:
-i couldnt get the cell furthest back as far in as the others, since i would of have to dremel alot out of the bearing support thing on the spur gear shaft, is it okay to do it?
-i was using the foam that HPI includes with the micro to keep my batteries from moving outside, however it wasnt thick enough, what are people using to keep the batteries in?
-Also i dremeled out a little bit of my motor opening on the bottom, just like a few mm's on each side, i want to do more, but have people had problems with the chassis warping or anything running mod? also i saw josh cyrul dremeled out his motor clamp to allow air to pass through, anyone else tried this? know if it works?...
thanks!
stormperson is offline   Reply With Quote
Old 01-25-2003, 08:12 PM   #3822
stormperson, i had to dremel out the rear bearing support on my chassis when i moved the batts in. i used a small disc on a dremel to do the job. also i had to really shave down the rear drive cup since i went in so far with the batts and ended up blowing in out in mod so i think i will get the irs input cups.
but i havnt experienced any problems since dremeling it.
as for the foam i have used an old trinity foam bumper. i just cut it into shape.
i have taken out all of the area around my motor opening.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 01-26-2003, 01:49 AM   #3823
NTC3NUT's Avatar
I had to grind the rear support as well. Get the IRS cups, you won't run into any clearance problems with those. As far as foam goes, most of the guys I have seen with this mod (myself included) have used foam strips cut from a bumper of some sort. Nice and dense, but light.
NTC3NUT is offline   Reply With Quote
Old 01-26-2003, 04:12 AM   #3824
anybody have pics of this mod?
Racin Rev is offline   Reply With Quote
Old 01-26-2003, 06:41 AM   #3825
heres some pics, sorry for the quality my camera is not top quality lol
siebenelch i liked what you did to your battery slots that i decided to do the same to mine. hehe
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
