Old 01-17-2003, 10:58 AM   #3781
No problem Ling.
James Nguyen is offline   Reply With Quote
Old 01-19-2003, 10:53 AM   #3782
yodace's Avatar
R/C Tech Charter Subscriber
Sort of a weird question. How do you adjust rear Toe in and Toe out?
I had my Tc3 on the Hudy Set up board. The left side rear is off compared to the right side,by at least 2deg.
How does a person fix this problem?
yodace is offline   Reply With Quote
Old 01-19-2003, 11:00 AM   #3783
Moderator
Speedo's Avatar
When you put the rear toe in block on, you need to make sure to put each hinge-pin in at the same time. Otherwise you will ruin the piece, the problem is it is made out of very cheap material. I suggest you buy a new part and put it on carefully.
Speedo is offline   Reply With Quote
Old 01-19-2003, 11:28 AM   #3784
yodace's Avatar
You need to make sure to put each hinge-pin in at the same time.you need to make sure to put each hinge-pin in at the same time.
Could explain this step by step?
Old 01-19-2003, 12:22 PM   #3785
Moderator
Speedo's Avatar
Well if you put one hinge pin first, then put the other one in, you are bending the plastic so it causes unequal toe in. The best way I can explain it is to carefuly line the piece up with both hinge pins, and push it a little bit so heach hinge pin is seated slightly, then apply even pressure to each side so slide the pice on .
Good luck,
Josh
Old 01-19-2003, 12:53 PM   #3786
TurnNBurn's Avatar
Yodace,
How old is your TC3? There was problem with one of the rear carriers in early production. The complaint from people was that one side had more toe than the other. Associated had to re-tool the mold for that part. I know that this was discovered early in the TC3's production, so if your car was purchased rather recently, that wouldn't be the problem; on the other hand, if you bought it used, or don't know how old the car is, you might want to try buying new rear carriers.
TurnNBurn is offline   Reply With Quote
Old 01-19-2003, 01:28 PM   #3787
if you install a new rear hinge pin mount make sure you dont stretch the part over the other hinge pin that can cause unequal toe like speedo said.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 01-19-2003, 06:06 PM   #3788
yodace's Avatar
I got my Tc3 late last year.
Old 01-19-2003, 06:10 PM   #3789
yodace's Avatar
Does hardcore make a rear carrer mounts?
Old 01-21-2003, 04:25 PM   #3790
I dont think that hardcore makes em. But Im sure that Team Trinity makes them. There alum. and they have replaceable plastic bushings. they look nice, Im gonna pick me up some as soon as I make some money.
racerdx6 is offline   Reply With Quote
Old 01-21-2003, 04:32 PM   #3791
rc-zombies's Avatar
I have megatech arm mounts on mine and they work just as good as Trinity's and half the price. Plus you have a choise of different toe-ins and kick-ups. available in purple and blue.
see:
http://www.ahc1931.com/cgi-bin/miva?..._Code=TC3Parts
scroll down for the blue parts...
Old 01-21-2003, 11:43 PM   #3792
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Default rideheight
i didnt have any probs with ride hieght either..i have the standerd arms...i have nothing done to my chasis accept the rear shock tower in front...im dont know much about set ups..but i think the car feels like..more "planted" i nthe turns..like its not roling over so much i guess...i run the shocks on the ouyt holethey are almost standign strait up..i was told n o to run them like that so i moved them in..to the middle and it jsut made the car very loos feeling..evenly front and rear..i dunno ..it was wierd...also..i run foems on carpet...with white springs in the front and yellow in the rear..and plaid and purple tires...let me know what you guys think...other than that its a sean cochran set up.
AlanHall is offline   Reply With Quote
Old 01-23-2003, 07:31 AM   #3793
Regional Moderator
Send a message via AIM to Mike F
Talking Will the real TC3 Thread please stand up
Mike F is offline   Reply With Quote
Old 01-23-2003, 08:58 AM   #3794
lem2's Avatar
Default how come??
alot of tc3 threads are coming out?
lem2 is offline   Reply With Quote
Old 01-23-2003, 10:13 AM   #3795
johnbull's Avatar
Hi guys. Greetings from Malta.
THIS IS THE ORIGINAL TC3 THREAD.
I don't know why guys keep opening others. It's so much more practical to have all TC3 related contributions in this thread.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
