Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-13-2003, 04:13 AM   #3736
NTC3NUT's Avatar
PizzaDude, I run Losi 4deg, or 6deg, depending on what I think works at the time. I didn't have a ride height problem with either. The rubber tire thing makes sense, I'm willing to buy that theory.
Fakk2, I follow the TC3 & NTC3 posts here, on Radio Control Zone, and on the Hobby Talk board. I have seen a few of the things Walter posted on Hobby Talk. I'll go back and scan thru it again to see if I can track it down. Thanks.
NTC3NUT is offline   Reply With Quote
Old 01-13-2003, 04:56 AM   #3737
theisgroup's Avatar
Default rear oneway
I am not a world class driver yet. But think of it. there is no reason for the rear of the car to have brakes. If you look at a 1:1 car, tge majority of the braking is done up front. And if you look at the physics behind it, more brakes on the rear creates out of control or spin conditions.
So with a spool, I would have the slowing down capabilities, and with the oneway in the rear, all wheels would be providing drive. I hate the idea of the diff. i can only assume that when the car is turning, the car loads the outside wheel. With more load on the outer wheel, the diff would tend to not drive that wheel. So exiting a corner, you would not be applying power down on all 4 wheels. With the oneway in the rear and a spool up front, power would be to all 4. I would think this would pull you around the turns faster.
theisgroup is offline   Reply With Quote
Old 01-13-2003, 05:58 PM   #3738
NTC3NUT: I noticed back in the post you showed pictures of the ntc3 steering set-up. What parts are required to do this conversion?
rcpilot is offline   Reply With Quote
Old 01-13-2003, 06:42 PM   #3739
Registered User
OB42TC3's Avatar
Default Re: rear oneway
We tried this a few years ago with the Nitro Rs4s and rubber tires and it overloaded the fronts to where it couldn't turn. Couple that with a spool and a free wheeling rear(no slide=no rotation) and it might be push city. You'd have to compensate with a snappy front end setup. Try it!
OB42TC3 is offline   Reply With Quote
Old 01-13-2003, 06:49 PM   #3740
theisgroup's Avatar
Default push city
the push might be a consideration. but i am running on a pretty open track. race on same track as nitros. I have also done the rear tower on front, the batteries moved inboard and up front and the ntc3 steering rack. With these mods and my setip, i let a few guys running tc3 with spools run my car. they were surprise how little push i was getting with the spool going into the corner. So maybe the rear oneway would actually help get more speed through the corners. I would imagine that the line through the corners would be critical.
i would like to try, but how do you get the bearing out of a oneway and thenreverse them.
Old 01-13-2003, 06:52 PM   #3741
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
TheIsGroup :: Are you racing with us on carpet the 25th?
BTW, don't try the one-way in the rear, trust me.
TEAM EPIC :: HOT BODIES RACING :: HPI RACING
David Galdo is offline   Reply With Quote
Old 01-13-2003, 06:57 PM   #3742
theisgroup's Avatar
Default carpet
don't think i can. wife has friend with bridal shower in houston. and i think i have the kido for the weekend.
you running at joe's this weekend?
Old 01-13-2003, 06:59 PM   #3743
Yeah I will be there. Hey I need to put new brushes on that motor for you so don't put it in your car just yet.
Old 01-13-2003, 07:02 PM   #3744
theisgroup's Avatar
ok, will leave it out. you guy running full mod?
Old 01-13-2003, 07:03 PM   #3745
Yeah, running Mod again!
Old 01-13-2003, 07:51 PM   #3746
Northerner's Avatar
Send a message via ICQ to Northerner
i have a rear one way diff for tc3 if anyone is interested in trying it?
$40 shipped
email me directly if interested
Northerner is offline   Reply With Quote
Old 01-13-2003, 08:42 PM   #3747
driftmaster's Avatar
hey cadet are you guys talking about running in shreveport?
driftmaster is offline   Reply With Quote
Old 01-13-2003, 09:53 PM   #3748
Yeah Drift, you gonna be there?
Old 01-13-2003, 11:58 PM   #3749
Yeah pretty sure I will. I'll see ya there.
Old 01-14-2003, 03:30 AM   #3750
hoj
Default Ride height with rear shock tower on front
To get ride height correct (<5mm), when you are using rear shock tower on front: cut down lower eyelet (7217) by 1...2 mm from threaded end. This modification moves lower spring cup down and the car is dropping just as much.
This modification has no effect to roll center.
hoj is offline   Reply With Quote
Forum Jump
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Exclusive Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
