Old 10-31-2001, 05:39 AM   #361
Regional Moderator
daniz24's Avatar
Originally posted by redsand
Since I have to exit the corner wide, this seems to be my weak (or other tc3's) point, others can pass me right at this moment.
What gives ?
I know what your problem is : Your car is understeer all the way.
You can't compare your car with others because they are already have their setups.
Especially the Yokomo guys .... hehe.....
daniz24 is offline   Reply With Quote
Old 10-31-2001, 11:38 PM   #362
redsand's Avatar
Send a message via Yahoo to redsand
it's understeer esp when taking right hand corner.
btw, i got 6F batt placement. I might be reducing caster block from 4 to 2 sometime next week.
redsand is offline   Reply With Quote
Old 11-01-2001, 12:45 AM   #363
Garapata's Avatar
wat causes understeering?
Garapata is offline   Reply With Quote
Old 11-01-2001, 07:39 AM   #364
TPhalen's Avatar
R/C Tech Charter Subscriber
Understeering is caused by to much rear traction...the front has less traction than the rear, causing the car to push into a corner.
If you post your setup people here can help tell you what you need to change to get more turn-in. Setup correctly, the TC3 should have incredible turn in.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 11-01-2001, 08:36 AM   #365
JOHNNY RACER's Avatar
i agree w/ tony. if you already have a GREAT turn in, then preload the left rear shock by just a 1/8 to 1/4 turn of the spring collar. i like to check for even on power steering (actually rear traction equality) by trying to do donuts (from a stand still) and tweak the spring collars until turn radius is even. one last test is to make sure the car is steering straight, then punch the throttle (from a stand still also) and see if the car accellerates in a straight line. again, preload the rear on the side the car is arcing towards. if you have to preload so much that your ride height is being effected, take a little out on the opposite side as opposed to preloading the side w/ less traction. b.t.w. i also run a 6f batt setup.
JOHNNY RACER is offline   Reply With Quote
Old 11-01-2001, 09:53 AM   #366
ernestf's Avatar
Send a message via ICQ to ernestf
I used to run Yokomo 600wt in front and 400wt in rear. Blue spring all around. I found this setting is still a little bit "push" when entering high speed corners. I rebuilt all shocks by using Yoko 400wt, keep the same spring rate. Hope the car can turn faster next time.
ernestf is offline   Reply With Quote
Old 11-01-2001, 06:22 PM   #367
redsand's Avatar
Tony, here's my current setup:
FRONT END:
Red Spring w/ 50wt/ 2 hole piston
Mid hole shock position
4 block caster
2 kickup
0 toe in/out
Stock camber link position
6.5mm ride height
-1 camber
REAR END:
Gold/50wt/ 2 hole pston.
mid hole shock pos.
2 antisquat
-2 toe in
Outer lower camber link pos
-2 camber
6.5mm height
short wheelbase
forward batt pos.
no swaybars attached.
HPI 35r all around with firm inserts.
100% Dual rate
+35 Str EXP
I've tried rear swaybar, it somehow reduced understeer just a little.
Hey Tony, would increasing steering exp help corner better ?
Old 11-01-2001, 07:00 PM   #368
im having a lot of trouble assembling the turnbuckles into the ball end cups.
is there an easir way of doing it?
Gump0220 is offline   Reply With Quote
Old 11-02-2001, 01:25 AM   #369
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Redsand: Have you tried a softer rear spring or the batteries at the back? I think it will generate more steering. btw, are you using the oneway diff?
And get rid of that positive exp steering. If anything you should have a small percentage of negative exp.
Airwide is offline   Reply With Quote
Old 11-02-2001, 05:27 AM   #370
Regional Moderator
daniz24's Avatar
I think i don't agree with you, because softer rear spring means more rear tractions and the result is more understeer or less steering
Old 11-02-2001, 07:29 AM   #371
TPhalen's Avatar
Daniz is correct, as long as you keep the shock in the same location. If you move the rear shock (top) out, this will give the effect of a slightly stiffer spring, thus, giving more steering. You COULD go one stop down on the rear spring, and move the rear shock out, and this MIGHT give you a slight amount of steering, but I can see a few other things that will be a bit more drastic...
First, on the front, for more turn in:
2 or 0 degree front caster blocks
0 degree kickup (this isn't something I'd do as it sometimes causes weird handling problems, but it's a choice...)
LOWER THE CAR!!!! 6.5 is really way to high. We run at about 4-4.5mm. Of course, this depends on the type of track you run on!!! Maybe it's pretty bumpy...!!!
On the rear:
2 degrees of toe in causes more steering OUT of a corner, less in. You could go back to the 3 degree block. Also, try the R3-0 block. The 0 antisquat will allow the car to accellerate harder in and out of corners, but make it a little washy in a straight line. Might be something to try.
0 out the steering EXP. Like Airwide said, most people run 0 or a tad negative.
I tried the battery forward and it made the car too twitchy into corners. Didn't like it.
And lastly, LONG wheelbase. Believe it or not, LONGER wheelbase gives the car more steering. It doesn't make sense, but, for most r/c cars, this is true in relation to the rear hubs-to-outdrive placement.
Hope this helps out...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 11-02-2001, 08:24 AM   #372
Airwide's Avatar
With the track conditions here, a softer rear spring gives more steering, but however less initial steering. And that's with the oneway installed.
If you don't use the oneway, I recommend you to install it. The corner speed is so much better with it at all corners but hairpins.
Old 11-02-2001, 07:41 PM   #373
redsand's Avatar
Thanks a bunch gang..
Theyre definetely worth it to try sometime this weekend if it doesn't rain.
Tony and Airwide, speaking of steeering EXP, on what kinda track layout do you use + EXP ?
Old 11-02-2001, 11:23 PM   #374
TPhalen's Avatar
I've personally NEVER used + EXP...I usually set the car up to have gobs of steering....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 11-03-2001, 09:51 AM   #375
Talking STEERING GOOOD!!!!!!
i believe that one can always steer a little less, but one can't steer more if the car has no more steering to offer. more steering than the average bear means more alternative lines and places to pass the average bear. Just don't expect to pass Tony!!!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
