Old 01-03-2003, 10:57 PM   #3646
Please don't take this the wrong way, but if you were going to remove weight it is much better to remove high weight. Your centre of gravity will be lower with that chassis undrilled if you car is already near the weight limit.
ixlr8nz is offline   Reply With Quote
Old 01-04-2003, 02:19 PM   #3647
Has anyone seen or used the GPM bottom motor heat sink before? I have no idea how this is supposed to go on. It looks like it is made to bolt on under the motor adjustment cam, but that Of course throws off the pinion placement to the spur, that and the one screw is not long enough. Am I missing something here? Did I waste my cash?
I was looking for a way to suck a little more heat from my p2k and cover up the open holes in the motor because I often drive in very dirty places.
troll is offline   Reply With Quote
Old 01-04-2003, 04:33 PM   #3648
Talking
hey, i need a way to get a little more speed from my tc3. i already have a reedy ti nine turn single motor. if i bought a reedy x-rated 3000 pack would it go faster or just run longer.
Reedy9t is offline   Reply With Quote
Old 01-04-2003, 06:28 PM   #3649
I know if it has more voltage it will make it go faster, or will it just make it have more punch. Hmm, I'm still new to the battary thing , it would probaly be smarter to take advice from someone that knows more about battarys. But I know that more higher voltage will either improve top end or acceleration, or mabey both.
racerdx6 is offline   Reply With Quote
Old 01-04-2003, 06:33 PM   #3650
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Depends on the type of batteries your running now. If your running some no name unmatched batteries, it will make a difference on speed and punch. If your running something like good 2400 matched batteries then you would only notice a difference in run time. this could however allow you to gear up and get a little more straight line speed.
Jack Smash is offline   Reply With Quote
Old 01-05-2003, 11:50 AM   #3651
FYI -- I have some Factory Team aluminum parts for sale on the for sale thread.
coolrcdad is offline   Reply With Quote
Old 01-05-2003, 12:30 PM   #3652
Northerner's Avatar
Send a message via ICQ to Northerner
i just got my new factory team kit yesterday and it has the new driveshaft and the two hole a-arms.
im looking forward to putting it together cause actually its my first new car. i have had new cars before but everything has already been assembled. so this will be my first from scratch!
gonna give me some time to put all the great ideas and tips given on here to use!
Northerner is offline   Reply With Quote
Old 01-05-2003, 07:58 PM   #3653
Jeff Werner's Avatar
Send a message via Yahoo to Jeff Werner
man sounds like most of the new FT kits have been coming with the new stuff in them...did not know if the old stock would still be out here...would suck to get an older FT...
Are they upgrading just the FT kit or does the team and racer car come with the new stuff as well???
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-05-2003, 08:04 PM   #3654
Im not sure about the new kits coming with the upgrades. But Im guessing that the racer and team come with the new suspension arms in the composit material. I dont know if the team kit will have the new main shaft, but Im pretty dang sure the racer kit wont.
Old 01-05-2003, 08:07 PM   #3655
Northerner's Avatar
i thought i read here or someone had stated in another thread that AE discontinued the composit driveshaft?
Old 01-05-2003, 08:08 PM   #3656
Thanks for the info....I did not think the Racer would get teh new shaft but heck does not cost much more to put in the stock material arms with a second hole in them...lol
Old 01-05-2003, 08:12 PM   #3657
Dingus's Avatar
My brother just bought a racer kit and it came with the new al shaft and the two hole arms.
Dingus is offline   Reply With Quote
Old 01-05-2003, 08:15 PM   #3658
Northerner's Avatar
i wouldnt think they would charge more, the two hole arms is just a different mold and shouldnt change cost at all. the driveshaft on the other hand might be a different story? but then again maybe not? its a solid shaft with two pins through it, as the composit shaft was three pieces and then the two pins, so maybe less labor putting it together will keep the aluminum shaft at the same cost?
but then again maybe im just dreaming?
Old 01-05-2003, 08:54 PM   #3659
Registered User
OB42TC3's Avatar
where's the oft rumored warpspeed pics and website??
OB42TC3 is offline   Reply With Quote
Old 01-06-2003, 12:06 AM   #3660
driftmaster's Avatar
A freind made me a spool out of delrin, 5.5g's.
driftmaster is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
