Old 01-02-2003, 01:36 PM   #3631
Northerner's Avatar
Send a message via ICQ to Northerner
well i have a new factory team kit coming so i hope the new arms and driveshaft are included!
i did order an extra one from my lhs for $8 for my other car, it will be here next week
Northerner is offline   Reply With Quote
Old 01-02-2003, 07:40 PM   #3632
Default loose fitting screws
I have built a few tc3's in the past couple of months. I found a couple screws in each kit that had threads that weren't sharp. In fact, if you were to mic the threads, the threads were a couple thousandths smaller. Pull out the screws that don't fit tight and compare them to ones that fit tight. look very closely to the sharp edges of the threads. If the problem is stripped holes, you can buy a 4-40 heli-coil kit for about 39 bucks at a local hardware store. These work great and you should never have any problems again.
Art Jensen is offline   Reply With Quote
Old 01-02-2003, 09:29 PM   #3633
omalley's Avatar
Send a message via AIM to omalley
Default Two Speed Tranny
Can you get a two speed tranny for a Elec TC3? I know there illegal for racing but just for kicking around .
omalley is offline   Reply With Quote
Old 01-02-2003, 10:03 PM   #3634
Northerner's Avatar
i see one on ebay for sale once in awhile, it attaches to your motor, dont know how well it works
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3104200883
Old 01-03-2003, 04:08 AM   #3635
johnbull's Avatar
JAHAYA.
When the screws on my son's TC3 started to get sloppy I simply replaced them all with 3mm metric ones. No drilling or tapping required. Just a tighter fit.
We haven't had any more trouble, and in Europe metric screws are more readily available. I got mine from Titanium Racing.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 01-03-2003, 06:02 AM   #3636
omalley's Avatar
Default Two speed tranny
thanks for the info
Old 01-03-2003, 09:41 AM   #3637
omalley's Avatar
Default titanium screws
i got my set of ti - screws from http://www.titaniumracing.com/
Old 01-03-2003, 11:39 AM   #3638
johnbull / Muffin- thanks for your info.
J.
DoCoMo is offline   Reply With Quote
Old 01-03-2003, 02:14 PM   #3639
superk's Avatar
Default Broken Shft!
Guys! I have a race last night...and some how in the main I broke my driving shft!! Although ..I didn't notice much on the car handling...since I sux..bad.. last night LOL...
Any ways... I have a FT TC3 and wondering if I should go get the factory one or aluminum one?? witch one is lighter and give me batter performance?
superk is offline   Reply With Quote
Old 01-03-2003, 02:24 PM   #3640
rc-zombies's Avatar
Default Re: Broken Shft!
The black graphite drive shaft has beed discontinued and no longer available. The new AE aluminum one is more durable and cost around $6.00. The down side is that they will bend.
Old 01-03-2003, 02:25 PM   #3641
Northerner's Avatar
looks like the new factory team shaft is made of aluminum and about 35% smaller in diameter then the IRS shaft i had. and its a third the price!
the part number is listed on this post somewhere! mine will be here next week for $8
Old 01-03-2003, 02:32 PM   #3642
superk -
Aluminum Driveshaft:
Depending on which one you get it (Associated ,IRS, etc) can be almost 2x as heavy as the graphite one.
The aluminum unit will be stiffer and make the car more responsive (torque-ier) because it wont flex as much.
Increase drivetrain efficiency as more power can be transfered the the wheels without much loss due to flex.
If it bends, it will stay bend.
Graphite shaft:
Lighter but more flexible.
Will allow a faster spool up, but its flexibiltiy will make acceleration appear to be soft.
It it bends, it flexes but returns to its original shape.
Keep in mind that an increase in rotational mass is equal to increasing sprung weight threefold.
For example: say the stock shaft weighs 1 oz. The aluminum shaft weighs 2oz. Under rotation that 1oz difference actually becomes more like 3oz. Those 3 oz will increase the weight of the car.
In the end its a trade off - light and flexy, with a faster spool up or efficient but heavier.
ZERSHNL is offline   Reply With Quote
Old 01-03-2003, 02:35 PM   #3643
Mike D's Avatar
Send a message via Yahoo to Mike D
ZERSHNL - Good thoughts.
Mike D is offline   Reply With Quote
Old 01-03-2003, 06:12 PM   #3644
rayhuang's Avatar
Default Pics of my milled chassis!!
Finally-a couple (dark) pictures of my milled chassis'. Notice that the battery box has been milled dwon and slots are added.
Old 01-03-2003, 06:13 PM   #3645
rayhuang's Avatar
This picture is from the bottom. Notice extra lightening holes under the tranny cases and the bigger opening under motor.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
