Old 12-31-2002, 05:11 AM   #3586
Send a message via AIM to Tc3punk Send a message via Yahoo to Tc3punk
Default warpspeed
anyone have any updated info?
when there gonna be available
price
how to order?
I'm gonna order a new "flat" chassis in the next few days, and I havn't chosen between IRS, Megatech, and this warpspeed one...
any info?
Tc3punk is offline   Reply With Quote
Old 12-31-2002, 08:32 AM   #3587
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Rev, I usually carry them to the track. They are hot items so they do go fast though.
The drive shaft is ASC3937. I believe it has a retail price of $7.99.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-31-2002, 10:26 AM   #3588
Northerner's Avatar
Send a message via ICQ to Northerner
the factory team tc3 aluminum driveshaft on my friends car is all one piece.
do you know if that #3937 is all one piece?
Northerner is offline   Reply With Quote
Old 12-31-2002, 11:16 AM   #3589
Super Moderator
Kraig's Avatar
I don't have one in front of me right now but it is the same one that is coming in the kits now. I highly doubt they are making 2 different kinds.
Old 12-31-2002, 11:20 AM   #3590
Northerner's Avatar
what surprised me the most was the size of it, it was a LOT smaller then my IRS shaft which would save a ton of rotating mass!
Old 12-31-2002, 11:29 AM   #3591
TeamPRP's Avatar
Default TC3 upper deck?
Hey guys, I've had a few requests for a TC3 graphite upper deck to run from the front gear box to the end of the center shaft near the spur. I've done some initial measuring and concept work but would like to know if there would be enough interest for this part from the racers? Let me know what you think, teamprp@attbi.com
Thanks!
Ben
TeamPRP is offline   Reply With Quote
Old 12-31-2002, 12:08 PM   #3592
Regional Moderator
Send a message via AIM to Mike F
do you have any in stock now?
Mike F is offline   Reply With Quote
Old 12-31-2002, 12:26 PM   #3593
An upper deck would be cool! But what would we need it for? Cuz we already have room for the electronics. Would it help stiffen up the chassis? Mabey it would help a lot with flat chassis's. But it sure as hell would look cool !!
racerdx6 is offline   Reply With Quote
Old 12-31-2002, 12:45 PM   #3594
i would definately be interested in a top deck. keep us posted.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 12-31-2002, 12:53 PM   #3595
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
I believe that the tc3 guys that are cutting down the spine of the car to bring the batts more into the midline of the car are needing the top plate like what Josh used in Cleveland. I think it would be a great product with the amount of racers that are doing that mod.
Jeff Werner
Team Promatch
Jeff Werner is offline   Reply With Quote
Old 12-31-2002, 02:06 PM   #3596
AGR#7's Avatar
An improved (lighter) Driveshaft for the TC3 - very cool!
AGR#7 is offline   Reply With Quote
Old 12-31-2002, 02:11 PM   #3597
Super Moderator
Kraig's Avatar
Mike, I am out of them right now. I am trying to track more of them down.
Old 12-31-2002, 04:05 PM   #3598
How much material are you guys taking away on the tranny cases? Should i use a dremel tool at low speed to do it. I scraped some of it off with an x-acto knife but the drivetrain is still not spinning for that long. I have already deshielded one shield on all of the bearings and degrased them. Also, I am using two shims on the input shafts right now, should I reduce it to one shim? What else should i do to get the drivetrain freer? Any help is appreciated.
James Nguyen is offline   Reply With Quote
Old 12-31-2002, 05:42 PM   #3599
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I used an exacto knife to shave out the plastic on the cases. I cut out quite a bit though. You just want ot get it so it doesnt pinch the bearings. You should be able to just set the bearing into the slot without having to push it in and t should fall out if you turn the case over. Do this on top and bottom. Doing that and getting propper shimming frees up the drive train a ton.
Jack Smash is offline   Reply With Quote
Old 12-31-2002, 06:16 PM   #3600
Why not just take out the thin diff spacers that go behind the bearings? Why shave it out?
rcpilot is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
