Old 12-27-2002, 04:34 PM   #3556
Default FT TC3 ??
Just picked up my FT TC3 and was curious to know if all the kits come with the blue alum. main shaft as std. or is it just on the FT.
Thanks....
TC3trinity is offline   Reply With Quote
Old 12-27-2002, 04:46 PM   #3557
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I think only the FT comes with the Blue midshaft now.
mike_Webb is offline   Reply With Quote
Old 12-27-2002, 05:39 PM   #3558
Lab-driver's Avatar
Yep, mine came with a blue shaft too.
Lab-driver is offline   Reply With Quote
Old 12-27-2002, 05:58 PM   #3559
kevin2's Avatar
Send a message via AIM to kevin2
Default griphite chassie,alum. main drive shaft,GT7, matched cells?
I have a TC3 and i got 200 bucks for christmas and i dont have a futaba MC230CR ESC.i have a compsite chassie, and aluminem threaded shocks.what should i get with the money?
kevin2 is offline   Reply With Quote
Old 12-27-2002, 06:01 PM   #3560
kevin2's Avatar
Default DUH
DUH sorry i was half asleep i have a futaba MC230CR ESC
Old 12-27-2002, 06:09 PM   #3561
NTC3NUT's Avatar
If you have a complete car, ESC, & threaded shocks, I would concentrate on these items:
- a good stock or modified motor, depending on what you want to run & what your ESC can handle
- a good servo
- a good set of matched battaries
This will consume all of your money, maybe more, but your car will be done, and race ready. I would skip all the eye candy and go racing. All the hop-ups can wait until you get the extra cash, and you can do them in steps, while your racing!
NTC3NUT is offline   Reply With Quote
Old 12-27-2002, 06:55 PM   #3562
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: griphite chassie,alum. main drive shaft,GT7, matched cells?
Right, Nut - the drive shaft is probably a waste of money, at least compared with a good ESC, motors, matched batteries. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-27-2002, 07:21 PM   #3563
kevin2's Avatar
Default thanx
thanx guys i cant get matched cells till i move up into the stock class i have a digital servo. i have a airtronics mx-3 radio i was looking at the novak gt7 esc what do u guys think of that ESC?
Old 12-28-2002, 05:19 AM   #3564
stormperson's Avatar
Send a message via AIM to stormperson
just checking, this mike dumas winner in cleveland sedan mod?
does he have a web site, or do u have to email him personally?
and what parts does he make?
thanks!
stormperson is offline   Reply With Quote
Old 12-28-2002, 05:20 AM   #3565
lem2's Avatar
Default Re: thanx
Happy New Year!!
Actualy if you plan on racing stock ur ESC is good enough, but the added (profiles of a GT7) is also a plus!!
if I wer you, i would get: batteries, sets of tires, pinions and spares for the TC3, the front RPM Bumper is also a must to prevent breakig those front arms!! and motors
Lem
lem2 is offline   Reply With Quote
Old 12-28-2002, 11:00 AM   #3566
I am installing Losi front spindles on my TC3, in ther hope that they are a little more durable than the stockers. I've heard that it's best to use the AE "C" hub carriers, as they are better than the losi parts. Is this true?
I've noticed that the part of the spindle that sticks out for the steering ball stud is shorter when compared to the stock piece. Does this effect anything, or do I just re-adjust the turnbuckles and go with it?
And finally, the anodized Fadtory Team drive shaft is 9 bucks, and the other brands are like $20. Any benifit from spending the additional money?
Thanks a bunch!
todddd41 is offline   Reply With Quote
Old 12-28-2002, 11:12 AM   #3567
Dingus's Avatar
I have the Losi spindles in use. The shorter arm will give the car a little more throw and a little more Ackerman (I think...)
I installed the Losi spindles mostly for this reason, not so much durability. I used the stock c hubs as well. The Losi's are not a direct fit and I found them a little tricky to mill down properly. Too easy to go too far.
I haven't seen the new associated shaft for sale anywhere yet. Where did you find one?
Couldn't tell you the difference at this point. I believe Associated replaced the graphite one due to some defects, and all the team drivers made the switch.
Dingus is offline   Reply With Quote
Old 12-28-2002, 11:41 AM   #3568
b3buggy's Avatar
hi,
are you talking about the blue prop shaft?
if so then some of the factory guys over here have been using the IRS one, and so have I. didnt know anything about a factory one
havenet found anything different in performance except that it looks so good but it is a little heavier.
also got the IRS ally diffs, fastrax blue braces, RPM blue ball joints and all the factory team stuff as well.
I am getting so bored of blue,
see yah
ross
RCR Racing - Worcester MCC
b3buggy is offline   Reply With Quote
Old 12-28-2002, 12:16 PM   #3569
thanks!
yes he is the a main sedan mod winner in cleveland.
his website is www.readytorunrc.com you can find his email there.
as for the parts he makes. he has front and rear arms and front and rear knuckles that he machines from nylotron, which is in the delrin family. i have seen the arms in person and they look indestructable. the front knuckles have more steering throw than stock and also have more equal steering throw left to right. definatly some nice stuff.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 12-28-2002, 05:37 PM   #3570
NTC3NUT's Avatar
I have the Losi steering knuckles and c-hubs up front, and carriers in the rear. All where a direct fit, with no mods needed. The only thing I needed to do was install an extra shim in the rear on each side, the rear carriers are a little narrower than the original AE pieces. The car has an even throw, as well as a longer throw up front, and I can now adj. toe in the rear. Everything worked great.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
