Old 12-23-2002, 12:08 AM   #3496
shrekair's Avatar
Trader Rating: 9 (91%+)
kingzj - do u race at trackside? i was one of the minnesota gang that was up there this weekend and i liked the track and the facility a lot. we have you in track size here in minnesota, but ur hobby shop is better.
shrekair is offline   Reply With Quote
Old 12-23-2002, 06:40 AM   #3497
omalley's Avatar
Send a message via AIM to omalley
Default Warpspeed
Does warpspeed have a web site? if so what is it?
omalley is offline   Reply With Quote
Old 12-23-2002, 07:34 AM   #3498
PW
PW's Avatar
Send a message via AIM to PW
The Warpspeed website is under construction and should be ready after the holidays.
Happy holidays to all.....
PW is offline   Reply With Quote
Old 12-23-2002, 07:37 AM   #3499
omalley's Avatar
Default re: warpspeed
thanks for the info. do you have the address by chance?
Old 12-23-2002, 07:43 AM   #3500
rayhuang's Avatar
Default Dumas Arms short term test
Hello,
I ran the Dumas-Delrin arms yesterday and they performed great!! I used the steering knuckles in Losi Castor blocks (stronger than Associated ones) and car steered consistently. I also used the new camber link position on the rear hubs with good results. I was on the way to a TQ in 19 turn Touring when glitching took me out of the race. I also finshed second in A-mains in both Stock and 19 turn yesterday. So I am very happy with the Dumas parts. And they do have near zero slop, but do not bind!!! Its nice stuff.
Ray
Old 12-23-2002, 10:24 AM   #3501
highx's Avatar
Thanks, found the info I was looking for on the conversion. My car has been really good to me the last month or two since I first began experimenting with all the changes so I will keep on making them. Thanks to all who post pics and take the first plunge.
highx is offline   Reply With Quote
Old 12-23-2002, 10:44 AM   #3502
well i tryed the milled center brace mod yesterday, and had good results with it. the car felt more responsive through the chicanes. although i had newer tires on the car and did not get a chance to true them down i also did not limit my droop as much as i should have for the larger tires so the car could have been better. so before my next outing im truing the tires down a few millimeters and limiting a little more droop all around then car to get it a little closer to my previous setup before i milled the center brace.
ray sounds good about the arms. im stuck between getting some new cells or the dumas arms and knuckles. decisions decisions.
Jarrod Langlois is offline   Reply With Quote
Old 12-23-2002, 10:48 AM   #3503
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I hope to get my arms this week when I get home from the holidays. They were suppoe to go out last Thursday or Friday but I don't think that he got them out. I may try them once but then not use them until Snowbirds.
mike_Webb is offline   Reply With Quote
Old 12-23-2002, 12:28 PM   #3504
Default fan type and battery?
I have been running my TC3 (19 turn and stock) for a while now and noticed that MVP's 2 gears under p2ks run about 200 F so i thought i would use a fan, what fan do you use and what type of battery do you use, I should have enough space because i have some of the smallest elctronics available (GM V8 (same size as V12 with less profiles) and KO micro reciever(smaller than XXL))
AustinS is offline   Reply With Quote
Old 12-23-2002, 01:13 PM   #3505
Send a message via AIM to Tc3punk Send a message via Yahoo to Tc3punk
what are all the parts needed for the NTC3 steering conversion?
is it just one part?
Tc3punk is offline   Reply With Quote
Old 12-23-2002, 07:14 PM   #3506
Kenneth Tan's Avatar
Anyone using NTC3 diffs on the TC3? Is it a direct fit with no modifications? Any forseen advantages or disadvantages?
Kenneth Tan is offline   Reply With Quote
Old 12-23-2002, 07:17 PM   #3507
Default Warpspeed Demon TC3
I would like to appolagize for my comments about the IRS chassis in my previous post. They make excellent products. I was merely trying to point out the difference in their products and ours. It just came out kind of harsh.
With that said, I wanted to address the freeing up the drivetrain issue. Warpspeed racing will soon have available trans cases that are worked over and will make your drivetrain super free. The cases get bolted together and the bearing journals get matched and enlarged slightly. They will also be fitted with heli coil threaded inserts. This will make them very strong and the cases wont strip or wear out from assembly and disassembly from maint. You will also be able to tighten the upper section of the trans case without binding up the drivetrain instead of running them loose and potentially tweaking the suspension mid run.
Art Jensen is offline   Reply With Quote
Old 12-23-2002, 08:23 PM   #3508
Now thats a good idea!
ixlr8nz is offline   Reply With Quote
Old 12-23-2002, 10:22 PM   #3509
Deves's Avatar
Ho Ho Ho .....Merry Christmas everyone!!!!
Deves is offline   Reply With Quote
Old 12-23-2002, 10:30 PM   #3510
lem2's Avatar
Default Merry Christmas
to my fellow TC3 owners!!
Happy Christmas and may 2003 bring more wins, innovations and hop ups to the TC3!!
lem2 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
