Old 12-21-2002, 11:18 AM   #3466
Hey, whats up guys? I juts got a FT TC3, do you guys have any tips for building and setups? I run rubbers on a tight parking lot track.
viper9703 is offline   Reply With Quote
Old 12-21-2002, 12:15 PM   #3467
KingZJ,
What kind of drying type teflon are you using on the diff gears? White lightning?
Thanks.
James Nguyen is offline   Reply With Quote
Old 12-21-2002, 12:31 PM   #3468
Tech Legend
Wild Cherry's Avatar
15teen sec`s ???
You still can work on it ....
You can get 30 sec`s.....at least.....
But your gona need to grind a few places to get those extra seconds....
And yeah don`t need weighted tires or drivetrain to get that time ...( my personal best is 30 )
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 12-21-2002, 02:10 PM   #3469
How do I get my drivetrain that free?
Old 12-21-2002, 02:23 PM   #3470
TC3
TC3's Avatar
Default megatech delrin arms
ther are delrin aarms from megatech and gpm..
has anyone tried them yet?
TC3 is offline   Reply With Quote
Old 12-21-2002, 02:38 PM   #3471
TC3
TC3's Avatar
here is a pic of the gpm arms, the megatech ones are even more thickly
Old 12-21-2002, 02:50 PM   #3472
KINGZJ's Avatar
Send a message via AIM to KINGZJ
the stuff I use on the gears is called dri slide it is made by Lilly Industries in Fremont, MI. I have used White Lightning and it work very well but this stuff I get for free at work .
KINGZJ is offline   Reply With Quote
Old 12-21-2002, 07:07 PM   #3473
Correct me if I'm wrong but those arms are no good for racing as there is no droop adjustment.
Can somebody please tell me why there is an advantage of running the batteries down the right side of the car as Warpspeed have done.
If it is to stop torque steer I cannot see how?
I think I will buy the IRS chassis instead.
Cya
Mike
ixlr8nz is offline   Reply With Quote
Old 12-21-2002, 08:44 PM   #3474
KINGZJ's Avatar
What seems to be the problem with the stock chassis? I have been running a tc3 for 3 seasons now and have seen many people try different chassis but they always seem to go back to the stock one. Cliff Lett is da man he designed the chassis and did a very good job with it.
Old 12-21-2002, 09:08 PM   #3475
patelladragger's Avatar
Send a message via AIM to patelladragger
Originally posted by Wild Cherry
15teen sec`s ???
30 seconds? That is a LONGG Time! I mean I thought 15 was quite a spin but 30?
patelladragger is offline   Reply With Quote
Old 12-21-2002, 09:42 PM   #3476
I know these are minor things but you asked the question:
1 My car is 50 grams overweight
2 With a grahite plate type chassis you get much better motor cooling
3 More space to put a fan on eg in front of the motor rather than next to it.
They are the main reasons
cya
Mike
Old 12-21-2002, 10:38 PM   #3477
Hi,
you should e-mail Mike Dumas about the Delrin arms has produces. they come with both holes drilled for the lower shock mounts. he also has the rear hub carriers and the steering knuckles drilled for either the TC3 or Losi.
www.readytorunrc.com
thanks
Fakk2
Fakk2 is offline   Reply With Quote
Old 12-22-2002, 10:47 AM   #3478
BendingCorners's Avatar
Location: Orange County TrackMasters "The Home of R/C Champions"
Default You all are Sick! Just TC3 Sick!
I have spent the last 4.5 hours reading every single post on the TC3 and I have come to an conclusion, you are all SICK! and my other conclusion is that I will always be slow unless I step up to the plate with some practice, cutting, practice, grinding, practice shimming and more practice with my TC3.
Keep the information coming!
Thanks for all the help in becoming a faster Weekend TC3 Warrior!
BendingCorners is offline   Reply With Quote
Old 12-22-2002, 03:54 PM   #3479
highx's Avatar
Default NTC3 Steering mod?
I thought I seen a post that listed all the parts with instructions on how to do it. If you can tell where it is located or just list the parts and a how to, that would be great.
highx is offline   Reply With Quote
Old 12-22-2002, 04:19 PM   #3480
KINGZJ,
How much white lightning should i put on the gears?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
