Old 10-15-2001, 04:50 PM   #331
JOHNNY RACER's Avatar
Default wolfeman-
check here for bearings.
http://acerracing.com/store/index.html
JOHNNY RACER is offline   Reply With Quote
Old 10-15-2001, 06:26 PM   #332
I don't usually buy Dynamite's stuff but their Red Seal bearings are fine and inexpensive.
coolrcdad is offline   Reply With Quote
Old 10-15-2001, 10:13 PM   #333
psycho's Avatar
wolfeman09
Also check www.bocabearings.com Their greenseal bearings are among the best on the market and should be a little less than the AE set.
psycho is offline   Reply With Quote
Old 10-16-2001, 03:17 PM   #334
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
coolrc > Is Acer Racing Dynamite?
i will check them out, thanks guys.....
wolfeman09 is offline   Reply With Quote
Old 10-16-2001, 04:15 PM   #335
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Acer Racing and Dynamite are not the same.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-17-2001, 08:50 PM   #336
batteries
what kind of batteries work on the tc3?
In all the pictures i see they are manually assembled with a kit.
What batteries can i buy that will work on the tc3?
Gump0220 is offline   Reply With Quote
Old 10-18-2001, 06:49 AM   #337
Gump0220:
You may commonly see self-built packs (saddle pack) at your local track but the manufacture built stick packs will work fine. The battery brace for the TC3 is a flip/flop bar engineered to work with various battery configurations.
V-Dezign 4.0
Old 10-18-2001, 07:20 PM   #338
Default pinion
what pinion gear should i get for my tc3 with a stock motor.
Also what gear should i get with a mod motor
Old 10-18-2001, 07:44 PM   #339
redsand's Avatar
Send a message via Yahoo to redsand
Out of my curiousity,
Do all TC3s have a slight understeer charateristic ?
redsand is offline   Reply With Quote
Old 10-18-2001, 08:06 PM   #340
Default Re: pinion
Using the stock spur, 72 tooth 48 pitch, use 25-30 pinions. Start out with the 25 tooth pinion.
V-Dezign 4.0
Old 10-18-2001, 08:08 PM   #341
I have not experienced understeer with my FTTC3.
V-Dezign 4.0
Old 10-19-2001, 01:54 AM   #342
Trader Rating: 62 (100%+)
Default Re: batteries
if youre gonna assemble your own batteries, try them in a saddle pack configuration. this way, you can also tune the weight balance of the batteries in 3 ways depending on where you put the foam spacer - in front, rear, or in the middle of the saddle pack. but stick packs and side by side are also fine.
marvi is offline   Reply With Quote
Old 10-19-2001, 04:29 AM   #343
Marvi: Well put, I should have explained the PROS and CONS of the different battery form factors for weight distribution. It does affect the setup and performance of the car. I would reflect upon the pro-racers setup sheets for addition insight and purpose.
V-Dezign 4.0
Old 10-19-2001, 06:36 AM   #344
dcracer's Avatar
Anyone use the center one way on carpet with rubber tires. What are your thoughts?
dcracer is offline   Reply With Quote
Old 10-21-2001, 11:08 AM   #345
tc3screamin's Avatar
Send a message via AIM to tc3screamin
i use a bearing blaster but ive heard of people actually boiling there bearings to clean them... up to u but i think its weird.
tc3screamin is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
