Old 12-16-2002, 01:49 PM   #3361
Mike D's Avatar
Send a message via Yahoo to Mike D
Titanium is strong but very bad with frictional wear.
Mike D is offline   Reply With Quote
Old 12-16-2002, 03:32 PM   #3362
lem2's Avatar
will it be safe to say, that using Ti as hinge pins will not be that pratical because of frictional wear?
wanted to get Ti hinge pins for my kits but if the cost is to much against the longevity of the product then it will not be worth it.
thanks.
lem2 is offline   Reply With Quote
Old 12-16-2002, 03:53 PM   #3363
I was thinking of getting titanium hinge pins for my tc3. But I didn't have enough money at the moment . Mabey the wear on the hinge pins would be ok because it's plastic on metal. The plastic would probaly wear out first. Mabey I'll just stick with the steel hinge pins .
racerdx6 is offline   Reply With Quote
Old 12-16-2002, 04:07 PM   #3364
omalley's Avatar
Send a message via AIM to omalley
Default Touring Guide
anyone have the XXX Main TOURING CAR CHASSIS guide? I have the Associated TC3 Guide I am willing to trade for
omalley is offline   Reply With Quote
Old 12-16-2002, 04:23 PM   #3365
NTC3NUT's Avatar
I have heard nothing but bad things about titanium hinge pins in the TC3. On the flipside though, I have Titanium Racing hinge pins in my NTC3, and they hold up very well. They are much larger in diameter though. I wanted them in my TC3 also, but was told by just about everyone I race with to use the BRP hardened pins. I have not bent one of these yet.
NTC3NUT is offline   Reply With Quote
Old 12-16-2002, 05:03 PM   #3366
NTC3NUT's Avatar
Check out all the weight I had to add to my car to meet the min 50oz for the CRL Toledo race. I put 3/4oz on top of the servo, 1-1/4oz behind the ESC, then I had to add the nickle on the battery strap. I couldn't believe how much lead you need to make up 2oz!
Old 12-16-2002, 06:10 PM   #3367
one of my friends put titanium hinge pins in his tc3 and put a 90 degree bend in 2 of them!! and he didnt even hit that hard just a couple of small hits was all it took. i dont think ill go for the titanium. he must have hit just the right way.
Jarrod Langlois is offline   Reply With Quote
Old 12-16-2002, 06:45 PM   #3368
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Here are the Two Chassis..
mike_Webb is offline   Reply With Quote
Old 12-16-2002, 06:53 PM   #3369
mike_Webb's Avatar
3.35 Chassis Cut
Old 12-16-2002, 06:53 PM   #3370
theisgroup's Avatar
Default ntc3nut
where did you get the battery brace?
theisgroup is offline   Reply With Quote
Old 12-16-2002, 06:56 PM   #3371
mike_Webb's Avatar
6.45 Chassis Cut
Old 12-16-2002, 06:58 PM   #3372
mike_Webb's Avatar
Chassis 6.45 with the Electonics
Old 12-16-2002, 07:07 PM   #3373
rayhuang's Avatar
The battery brace can be bought from PArma PSE. Sweet aint it??? Light and ultra stiff. I love mine.
Mike Webb-nice job!!! Can I drive it??? Lovin that IRS Transponder mount. Blue makes the car faster you know!!
Also-Pro-Match Panis-Tons of PUNCH!!! I cannot beleive people dont know how good those batteries are!! My car at Champs went through Tech at 50 oz exactly for the main with Panis in!!!!
If Panasonic stops making batteries-its gonna suck since this is the best battery they ever produced!!!
Old 12-16-2002, 09:07 PM   #3374
Peter Busch's Avatar
R/C Tech Charter Subscriber
Mike where did you get that foam around your battery, is that the same stuff for front bumpers?
Peter Busch is offline   Reply With Quote
Old 12-16-2002, 11:12 PM   #3375
PizzaDude's Avatar
Spongebob,
I do not know what Mike used.
But foam-gasket (industrial seal) works great!
BTW Mike looks nice.
Did you notice any difference in handlang?
Which o fthese 2 cuts, balances the car the best?
CU
Pizza
PizzaDude is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
