Old 12-11-2002, 11:53 AM   #3286
omalley's Avatar
Send a message via AIM to omalley
IRS Solid Axle
anyone using the IRS Solid Axle? If so what are your thoughts? What scenarios are you using it in?
omalley is offline   Reply With Quote
Old 12-11-2002, 06:11 PM   #3287
rayhuang's Avatar
so you can order them ray? if so from where and how much.
E-mail me for how you can get them!! I am sure you can get them from Mike directly at www.readytorunrc.com and I should have a couple sets next week I ordered from him to try. They are not on his website yet-but he has them.
Ray
rshuang@ameritech.net
Old 12-11-2002, 07:42 PM   #3288
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Default Rayhuang..
Just a quick question... Did you race 1/12th scale @ cleveland??
if you did what car did you run.. a buddy by the name of mark met you and kinda hung out with you...
RCFREAK is offline   Reply With Quote
Old 12-11-2002, 08:45 PM   #3289
ray ygm
Jarrod Langlois is offline   Reply With Quote
Old 12-11-2002, 09:48 PM   #3290
Default Titanium Outdrives
Hey guys, is there anyone out there making Titanium outdrives for the TC3?
DaWolf is offline   Reply With Quote
Old 12-11-2002, 10:03 PM   #3291
Titanium Racing makes them. They retail at 39.99 for a set. Titanium Racing
James Nguyen is offline   Reply With Quote
Old 12-12-2002, 12:46 AM   #3292
JimmyMac's Avatar
I have ran the IRS Solid Axle and Love it on my local track! I've always used oneways and was skeptical of the front spool. But once I used it, it was amazing! I think it works well here because of the technical turns. I've tried it on carpet at Cleveland and didn't like it much. Went back to diffs up front. So I just think it really depends on the track and your driving style. If you get one, make sure you use IRS pin cushions or just get the IRS Dawg Bones. This will save wear and tear on the outdrives as I've already worn down a spool and outdrive by not using them.
JimmyMac is offline   Reply With Quote
Old 12-12-2002, 06:10 AM   #3293
NTC3NUT's Avatar
Here are a few photo's that I promised you guys. FT/TC3 with fan, NTC3 steering, extended battery slots, ect. Let me know what you think, and be gental, this was my first attempt.
Here's a close-up of the fan to get you started.
NTC3NUT is offline   Reply With Quote
Old 12-12-2002, 06:14 AM   #3294
NTC3NUT's Avatar
Close-up of the fan wiring. It's wired directly to the underside of the speed control, thru a Novak switch. It can run independently of the speed control. I don't have actual temps, but before the fan you couldn't touch the motor after a heat, now you can hold you fingers on it. Total cost was about $20.
Old 12-12-2002, 06:15 AM   #3295
NTC3NUT's Avatar
Just another close-up of the wiring for the fan, from another angle. It could be done cleaner, again this was a first attempt.
Old 12-12-2002, 06:17 AM   #3296
NTC3NUT's Avatar
Close-up of the motor & mounting. Custom made (by me) motor clamp & cam. Both polished aluminum. You can see a few other things in this photo as well.
Old 12-12-2002, 06:20 AM   #3297
NTC3NUT's Avatar
Here's a photo of the battaries, after moving the slots in to the center of the chassis. I used a Trinity bumper ($5) for the super stiff foam padding (I cut it up to fit). The battaries are way in!
Old 12-12-2002, 06:22 AM   #3298
NTC3NUT's Avatar
Photo of the bottom "top". This shows the new mounts for the NTC3 steering. It also shows the radiused corners & the wet sanded chassis.
Old 12-12-2002, 06:25 AM   #3299
NTC3NUT's Avatar
Photo of the bottom "bottom". This shows the longer battery slots, and the larger cooling hole for the motor. You can also see the aluminum nuts that hold the fan on with titanium screws. The entire chassis has had the corners radiused on the bottom, then it was wet sanded smooth.
Old 12-12-2002, 06:31 AM   #3300
NTC3NUT's Avatar
Super good close-up of the NTC3 steering rack on the car. Use the bearings, I think it makes a differance. I also used Robinson racing ti-pillow balls everywhere. 99% of the screws on the car are blue alum., or titanium. I like to keep the car looking clean & neat, while being light & performing well. As it's been shown the car is easily under 48oz, ready to race, minus the transponder of course.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
