TC3 Forum
#316
I just bought a racer kit and it also came with the plastic outdrives.
#317
Johnny > you have a place to get this? I am in southern california as well. Thanks....
Tony > where are you racing this weekend? HobbyPeople Riverside? I want to talk to you about my tweak board order
#321
BEARINGS
does anyone know where i can get the full bearing set from Acer? i hear those are metal shielded. can i put my teflon seals on those? if not, is there a noticable difference in performance between the metal and the teflon shield bearings if i flush them and leave the inner seal off?
any good bearing deals out there?
#322
ling > If HobbyPeople is Sunday, then Im going to Socal Sundy is for Football.
Tony > then its socal? what time do you usuall get there?
#323
Re: BEARINGS
I remove all the seals from all the bearings and clean them after every race day. Our track is well prepared so the risk of running without seals is marginal. I would prefer the teflon over the metal shielding myself but there was no noticeable difference in performance.
#324
Anyone tried graphite rims? They are supposed to be light and very stiff. I guess this will have an effect on how you set up the car as the wheels are very different.
Any info on what setup changes might be needed would be most welcome.
I race indoors on carpet using either foams or Schumacher Carpet Dragon Tyres
#325
Bosscat.....I race indooors on carpet(astro turf..the green stuff)and the tire of choice is the Schue Dragons,we used to run the Schue pin spikes, but they wore out too quickly.The Dragons hook up really well.
#327
Dragon Slayer,
I was beginning to think that the UK was the only place using Carpet Dragons as I'd never seen them mentioned elswhere.
What sort of insert are you running?? Care to share setup info??
#329
I am in the process of buying new bearings, any suggestions?
I really do not feel like paying $120 for a full set of bearing from AE. All i need is the 8 bearings in the wheel hubs. The other ones are fine.
#330
yeah!!!! me too.
