Old 12-06-2002, 02:19 PM   #3226
mike_Webb's Avatar
Send a message via AIM to mike_Webb
buy the Corlite Niftech Woven Graphite sheet for $45 and make 10 braces, 5 battery straps. and 3 Front Body mount post.
mike_Webb is offline   Reply With Quote
Old 12-06-2002, 02:38 PM   #3227
Dingus's Avatar
Where can I get the woven graphite material website?
d
Dingus is offline   Reply With Quote
Old 12-06-2002, 02:39 PM   #3228
mike_Webb's Avatar
http://www.niftech.com/catalog/index...ode=1000series
down towards the bottom
Old 12-06-2002, 07:02 PM   #3229
Lab-driver's Avatar
OK, I have read through this entire thread and the one on RadioControlZone about what I should do while building my new FT TC3. So far, this is what I should do to make the most of it, correct?
1. Remove one seal on all drivetrain bearings and degrease them.
2. Trim part of the motor cam so it doesn't hit the chassis.
3. Remove some material where the diff bearings sit to reduce friction.
4. No shims on the plastic diff, and only 2 shims on the shaft.
5. Check for counter-sinking on the bottom of the car.
6. Sand diff rings. (I found this on the IRS website)
7. Polish my ballstuds and hingepins.
8. Pre-tap plastic and graphite parts, and put grease on aluminum screws.
9. Buy BRP bumpers, RPM ballcups, and a machined spur gear.
10. Put marks on the shock collars to see how many times you've turned it.
Does anyone object to this list, or is it generally right?
Lab-driver is offline   Reply With Quote
Old 12-06-2002, 07:59 PM   #3230
RBLove's Avatar
Trader Rating: 71 (100%+)
Default Warpspeed
Mr. Warpseed,
Could you e-mail a pic of the chassis you are designing? Or can you provide us with some details on what you are doing?
fleetwoodracing@yahoo.com
RBLove is offline   Reply With Quote
Old 12-06-2002, 09:01 PM   #3231
Peter Busch's Avatar
R/C Tech Charter Subscriber
Lab buy the new RPM front bumper, its better then the Buds. I would also stick with the stock ball cups, The RPM ones will rub on certain rims.
Peter Busch is offline   Reply With Quote
Old 12-07-2002, 07:15 AM   #3232
redsand's Avatar
Send a message via Yahoo to redsand
the stock ballcups only last a few runs for me. then one minor hit is enough to pop it off.
redsand is offline   Reply With Quote
Old 12-07-2002, 04:31 PM   #3233
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I get months out of my stock ball cups. I've used RPM in the past (10 years ago) and it seemed like some were nice and free and some would bind up. Have they fixed them since?
Jack Smash is offline   Reply With Quote
Old 12-07-2002, 06:07 PM   #3234
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I have not had any problems with the RPM ballcups yet. They last forever and I havent broken one either.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-07-2002, 06:20 PM   #3235
Lab-driver's Avatar
OK, thanks everybody!
Old 12-07-2002, 06:27 PM   #3236
RandyB's Avatar
roblove,
let me know if you want to move you evo2
thanks
randy
RandyB is offline   Reply With Quote
Old 12-08-2002, 05:39 PM   #3237
Kenneth Tan's Avatar
Hi,
I melted 2 plastic diffs yesterday... The diffs were built according to the instructions - gradually tightened and turned until I felt the spring compressed and then I release 1/2 turn. Ran the car and re-tightened if necessary. Any ideas on what did I do wrong?
Thanks.
Kenneth Tan is offline   Reply With Quote
Old 12-09-2002, 12:54 AM   #3238
johnbull's Avatar
Kenneth Tan.
PLASTIC DIFFS.
We have run ours for quite a while. So long as you don't let them slip too much they are all right. However if you hear them slipping on acceleration out of corners and carry on racing you knacker them.
I usually set diffs so that if you hold both diff halves and try and rotate the crownwheel it will only slip under lots of pressure. They remain smooth but don't slip. Try it.
My son runs plastic diffs in his car with pretty hot mod motors. He had a problem once last season when the diffs were set a bit too loose. But other than that there have been no more problems. I have heard that some people actually glue the diff rings to the diff outputs just as a safety measure. good idea actually. The main thing is to keep them well maintained. I rebuild Josh's diffs every third meeting - just wash out and regrease.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 12-09-2002, 01:10 AM   #3239
Thanks John Bull, I would try them out when I get the new parts again... So the 1/2 turn out method doesn't really work all the time right? I saw in the catalog that the plastic diffs are being sold by the entire assemblies at USD20. Does the assembly include EVERYTHING required to build a diff? Carbide balls, rings outdrives and other innards? Same like the steel diff assembly?
Old 12-09-2002, 03:13 AM   #3240
Lonestar's Avatar
Default Ballcups
Stock ballcups are POS's... No doubt about that.
From my experience, Schum ballcups are bulletproof...
Paul
Lonestar is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
