Old 12-01-2002, 02:19 PM   #3136
Lab-driver's Avatar
Hello, I just ordered myself a FT TC3 for christmas and I have a few questions.
1. What body do most of you racers use? I assume either the 'old' stratus or the 'new' stratus.
2. Does the kit include a tapping screw like losi kits, or should I get a 4-40 tap for the graphite parts?
3. Any hop-ups I should get? I was thinking maybe aluminum spur gear adaptor or perhaps IRS pin cushions.
4. Anything else I know?
Lab-driver is offline   Reply With Quote
Old 12-01-2002, 02:39 PM   #3137
NTC3NUT's Avatar
The cars pretty hooked up right out of the box. IRS makes alot of nice stuff, I think their aluminum input shafts make a differance. Alot of people use aluminum spur gear adaptors, supposed to be truer than the plastic one that's included in the kit. Really just build it to suit your tastes. You've picked one of the best touring cars in the world, and the options are unlimited.
NTC3NUT is offline   Reply With Quote
Old 12-01-2002, 02:40 PM   #3138
Dingus's Avatar
It doesn't come with a tapping screw like a Losi, but the plastic is not quite that stiff either.
Get yourself a good set of hex drivers because you will strip every al screw with the allen wrenches that come with the kit. Don't get the Duratrax ball hexes either, they suck.
A nice option would be the aluminum servo/transponder mount. The standard servo mounts are made of soft plastic and will strip over time.
Get a good high speed/torque servo.
Have fun!
Dingus is offline   Reply With Quote
Old 12-01-2002, 02:47 PM   #3139
Lab-driver's Avatar
NTC3NUT and Dingus,
Thanks, I think I'll leave it stock for now. I already have a Hudy hex wrenches, a TC2 and a JR digital servo I'm using in my ghetto Losi street weapon that I plan to use for my new TC3.
Old 12-01-2002, 04:04 PM   #3140
dcracer's Avatar
Definately go with the tap, makes construction much easier and parts are less likely to strip. As for hopups get a Buds front bumper and you are ready to go.
dcracer is offline   Reply With Quote
Old 12-01-2002, 04:25 PM   #3141
gator's Avatar
Originally posted by NTC3NUT
Josh made it himself I believe. The TC3 is stiff, but you can flex it in a "U" shape (or a bow), even without removing any of the center brace. Here's a link to a Japanese company that makes one similar. I have made an inquiry to HK to see if they can get these.
http://www2u.biglobe.ne.jp/~kmodels/tc3parts.htm#breis
i want to contact k.model racing factory , myself... i want the chassis braces, bumper brace, battery brace, and center brace as well. so how do i get a hold of them ?
gator is offline   Reply With Quote
Old 12-01-2002, 04:31 PM   #3142
shrekair's Avatar
Trader Rating: 9 (91%+)
how far in are they grinding their battery slots for 3300's?
also, i'm trying to get PRP to make some graphite stuff for the tc3 some stuff is already out there but it would be nice to have an accessable, clean, and simple versions of carbon fibre parts. is there anything u guys wanna see?
shrekair is offline   Reply With Quote
Old 12-01-2002, 06:25 PM   #3143
shrekair, how about one of those center braces mentioned above, it would be nice to be able to get one from here in the states. i know id be up for one. ill try to think of some more...
Jarrod Langlois is offline   Reply With Quote
Old 12-01-2002, 06:35 PM   #3144
gator's Avatar
Default new losi tools
have you all seen these tools , or tried them ?
http://www.teamlosi.com/newprod/2002prods/tools.htm
Old 12-01-2002, 06:41 PM   #3145
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
shrekair-
Center Brace
Shock Towers with more adjustments (like the XXX-S ones)
Battery Strap
But mostly the towers.
ChristopherKee is offline   Reply With Quote
Old 12-01-2002, 06:52 PM   #3146
shrekair's Avatar
the most prp could do w/ the towers would be brace them onto the current towers. remember, right now prp is just carbon fibre cutting, nothin machined or aluminum yet
Old 12-01-2002, 07:00 PM   #3147
shrekair's Avatar
i personally would like to see the center brace, side braces. towers would be killer but i dont know how they'd do it/
Old 12-01-2002, 08:17 PM   #3148
NTC3NUT's Avatar
shrekair
I measured my battery slots at 2". That's after removing 1/2 of the center backbone. Start at the out side of the original batery slot, and measure in. As far as CF parts go, I would like a US source for the center bracket also.
Old 12-01-2002, 08:38 PM   #3149
Craig's Avatar
Send a message via AIM to Craig
I would also like a center brace.I also wish someone would make a graphite bumper brace.It would use to mount a personal transponder and stiffen the bumper like on the NTC3.
Craig is offline   Reply With Quote
Old 12-01-2002, 08:53 PM   #3150
NTC3NUT's Avatar
Craig,
K.Models has a CF bumper brace, but it's nothing to write home about. You can also get CF body mount braces from Square. Josh has a nice plastic bumper brace on his car, but he probably made it.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
